Old 04-08-2012, 10:08 PM   #1
zwodubber's Avatar
Default 24 port Cat6 wall mount patch panel
I'm looking for suggestions on units you have used, installed, etc... and prefer. It needs to be wall mounted as the data room has no racks.
Any help is appreciated
zwodubber is online now   Reply With Quote
Old 04-08-2012, 10:11 PM   #2
I just did one! Funny you mention that. Used 3/8" rod nuts as spacers and ran a long screw in opposing corners.
The right answer would be to get a little 1U rack. What do they cost? 20 bucks?
Old 04-08-2012, 10:20 PM   #3
Spaghetti Cleaner
Look for a hinged 2u wall mount bracket, that's typically what I install.
You won't be able to use the cable management bar (if you have one) and if you can, put the hinge on the left side. That way your not blocking yourself when terminating.
Thread shorter.
sarness is offline   Reply With Quote
Old 04-08-2012, 10:43 PM   #4
Spaghetti Cleaner
I've done like 6 in the past five months and only have 2 pictures, one is not that great, 2nd a little better (temp location)
Thread shorter.
Old 04-09-2012, 12:05 AM   #5
zwodubber's Avatar
Who makes that model? Thanks
Old 04-09-2012, 12:16 AM   #6
Spaghetti Cleaner
It's from Leviton 49251-W62 I believe, I think I installed a tripp-lite version some time ago too. I prefer a 2u over a 1u, more stable and expansion room.
Thread shorter.
Old 04-09-2012, 12:49 AM   #7
zwodubber's Avatar
Thanks guys
Old 04-09-2012, 12:56 AM   #8
Data Tech/Apprentice.
chewy's Avatar
I just installed a couple of 2RU in a UPS room last week, they were Dynamix I think and they had a hinge so you only needed to undo one side of the cage nuts to add more at a later date.
chewy is online now   Reply With Quote
Old 04-09-2012, 01:00 AM   #9
chewy's Avatar
APC would have to be the nicest stuff to work with IMO.
Old 04-09-2012, 01:09 AM   #10
I always tended to get most of my miscellaneous stuff from Cables To Go. Price is right, never really had a quality issue, and you can get it tomorrow.
Old 04-09-2012, 01:19 AM   #11
chewy's Avatar
That would be awesome, we have to plan waaaay ahead of our larger jobs, I bet you have never heard "Theres no more Cat6A in the country at the moment" from your supplier, one of our telco closets ended up looking like an abortion because they could only supply us Plenum rated 6a which is white compared to gray and we kept pulling till we got it so didnt have a chance to make sure we pulled 1 -24 all in one colour etc etc.
Old 04-09-2012, 09:44 AM   #12
IT/Phone Guy
Allentel, ICC, Leviton all make those small brackets, up to at least 4U I believe.
http://www.allentel.com/page32.html
http://www.icc.com/products/category...-brackets.aspx
http://www.leviton.com/OA_HTML/Secti...minisite=10251
jeffmoss26 is offline   Reply With Quote
The Following User Says Thank You to jeffmoss26 For This Useful Post:
zwodubber (04-09-2012)
Grounding a Data Patch Panel Fuelcellpt General Electrical Discussion 12 03-12-2011 08:57 AM
I need a wall mount cable tv tuner bracket nrp3 Structured Wiring 12 01-31-2011 11:53 PM
HDTV wall mount rough-in sparkysteve Structured Wiring 42 03-10-2010 09:12 PM
How do you mount a light switch on a glass wall? Jeff000 General Electrical Discussion 21 01-28-2009 03:52 PM
Exterior Panel mount and PVC? Smileyboy NEC Code Forum 10 11-21-2008 01:49 AM
