Old 07-26-2009, 06:28 PM   #1
Default Bigger terminations
I see that there are a few companies now making ends that work on RG6 and RG6QS (same piece). Anyone know if anyone is making a single end that works on RG11 and .320? They're both so close, it seems to me that someone might be making and end that works on both.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 07-26-2009, 08:35 PM   #2
Black4Truck's Avatar
I use this company for anything new that is out there. I checked their catalog, but found nothing. You can call tech support.. they are good at problem solving.
http://www.adilink.com/services/productCatalog.php
Black4Truck is offline   Reply With Quote
Old 07-26-2009, 08:40 PM   #3
Thanks! I wish I had an ADI around here. Seems like everyone has an ADI but me. I feel left out.
Old 07-26-2009, 08:42 PM   #4
they are great with next day shipping when you need it NOW
Old 07-27-2009, 02:46 PM   #5
Well, first off lets get the terminology right if you want to sound like you know what you are talking about. These are not "ends" or terminations. They are called fittings or connectors.
As to your question about one fitting for both 11 and .320- If you notice the construction between the two cables is considerably different. I expect that would explain why there is no "universal" fitting even though the physical size may be close.
I also don't know of any system that uses .320 but that would be the only way to encounter it. So it's safe to assume that you really shouldn't be messing with this or at least realize that your work installing a fairly expensive fitting will be wasted when a cable tech cuts it off and replaces it.
-Hal
hbiss is offline   Reply With Quote
Old 07-27-2009, 03:06 PM   #6
I will continue to sound like I don't know what I am doing.. thanks anyway
Old 07-27-2009, 03:43 PM   #7
Great attitude.
-Hal
Old 07-27-2009, 06:07 PM   #8
My observation... Hal is a world-class d!ckhead. Too bad he's actually knowledgeable too. Such as waste of knowledge.
Hal... Comcast phased out RG-11 in my area several years back in favor of .320.
Old 07-27-2009, 06:22 PM   #9
Hack and Rat all in one
Peter D's Avatar
Run this by me again...why do you need to be putting ends on RG11?
Old 07-27-2009, 06:23 PM   #10
Peter D's Avatar
A duck head? That's funny.
Old 07-27-2009, 06:24 PM   #11
I guess I never actually said.
Old 07-27-2009, 06:25 PM   #12
Peter D's Avatar
Right...I just assumed that if you were asking for a source for the fittings you would be installing them as well...silly me for assuming.
I've just never heard of that size of cable. Doesn't the cable company put those fittings on for you?
Old 07-27-2009, 06:28 PM   #13
Not if I'm the one that ran it. I normally take RG-11 (now I'm changing to .320) from the cable demarc to the various wiring closets in larger buildings that have, more or less, a star topography cable distribution. These would be buildings that are served with hardline in the first place.
Hal encouraged me to examine the construction differences between RG-11 and .320, which I already had observed. They're dimensionally dissimilar, but not any worse than the difference beween 6 and 6QS, which they do make a combination "fitting" for. That's what spurred me to question the possible availablity of a combination "fitting" (okay, the one new term I can thank the asshole for) for 11 and 320.
Old 07-27-2009, 06:31 PM   #14
Peter D's Avatar
Right...should have known. You always seem to do the most bizarre stuff I've ever heard of.
Old 07-27-2009, 06:32 PM   #15
Yeah, I'm going to take some before and after pictures tomorrow of a nice one that will really get Hal cranked up.
Old 07-27-2009, 06:34 PM   #16
My point exactly. But-
Are you a cable subcontractor for MDUs? If you are not affiliated with the cable company I can't see how you are allowed to do this kind of work. Run the cable for them yes, install fittings no.
-Hal
Old 07-27-2009, 06:36 PM   #17
I've done a few MDU's as part of the overall electrical bid, but very few MDU's going up the last few years in my area. The one coming up here soon is an office building upfit. Why do you care?
Old 07-27-2009, 06:37 PM   #18
Why? The cable police going to swoop down and spank me?
Old 07-27-2009, 08:21 PM   #19
Not necessarily you because you or your company is working for the owner and they are responsible. They do tend to get a little pissy if the work isn't at least done in accordance with a design furnished by them.
-Hal
Old 07-27-2009, 09:35 PM   #20
The great thing is, that after all these years, I have not experienced this pissy-ness you speak about. I must be doing, at least, okay.
Motor Terminations Burning up?! HOW? msoucy General Electrical Discussion 22 06-27-2009 08:22 PM
Torque on bolts lugs & terminations nick General Electrical Discussion 43 04-20-2009 10:40 PM
hot tub bigger pain than it's worth ewjussila78 Other Codes and Standards 13 01-01-2009 10:04 PM
