Old 07-28-2009, 12:08 AM   #21
Wanna be Guru
mikeg_05's Avatar
off subject, but I heard it was "against the law" to daisy chain your phones together. Ive been waiting for the low volt police for awhile and they have not shown up
Old 07-28-2009, 08:43 AM   #22
It's against the Standards.
crazyboy is online now   Reply With Quote
Old 08-13-2009, 06:20 PM   #23
Thought I'd post a picture of a connector installed on .320 cable. I was doing a bit of this work earlier this week and took a picture, since some people seemed unfamaliar with .320. It's pretty darned close to RG-11.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 08-13-2009, 06:28 PM   #24
Hack and Rat all in one
Peter D's Avatar
That's the most interesting thing I have seen in quite some time.
Old 08-13-2009, 08:19 PM   #25
Wanna be Guru
mikeg_05's Avatar
What do you even use RG 11 for? CCTV?
Old 08-13-2009, 08:23 PM   #26
RG-11 is for times when RG-10 isn't quite enough and RG-12 would just be overkill.
Old 08-16-2009, 11:02 PM   #27
Lighting Contractor
Lighting Retro's Avatar
Lighting Retro is offline   Reply With Quote
Old 08-19-2009, 02:10 AM   #28
Speaking of coax fittings...
T&B has a Snap-N-Seal fitting designed for 320 cable, but it specifies CommScope only. Would it work for others?
The right-angle 6/6QS fitting is pretty slick, too.
http://www.tnb.com/pubint/docs/snapnseal.pdf
kornbln is offline   Reply With Quote
Old 08-19-2009, 10:24 AM   #29
What does ONLY mean? This is what I'm saying. If somebody has to ask a question like that they have no business doing this kind of work.
Never seen them used nor can I think of a reason to use them. If you provide space for the proper cable bend radius, straight fittings are all you need- and at a much lower cost too I suspect.
-Hal
hbiss is offline   Reply With Quote
Old 08-19-2009, 10:53 AM   #30
Lighting Contractor
I bet Hal NEVER had any questions growing up. He just knew everything. Ya'all need to get it together.
Old 08-19-2009, 12:23 PM   #31
No, I didn't have all the answers. I learned how to get information and learned by doing from the work of others who had been in the trade for years whose work I respected. I didn't have the internet to get a quick answer that may or may not be correct. I didn't expect to make any money doing something until I was competant enough to know and do work at least as good as the people I learned from. I know my limitations and won't do something that I am not knowledgeable about or competant doing. If I want to do something bad enough I will learn how to do it first. There is no such thing as telling a customer that I can do a job so I can get it then trying to figure out later how to do it.
Stick to that philosphy and be anal and a perfectionist and you too can be as smart as me.
-Hal
Old 08-19-2009, 12:28 PM   #32
Lighting Contractor
Good enough brother!
Old 08-19-2009, 06:03 PM   #33
I've made a pretty good living.... nay, an entire lifestyle, out of telling customers that I could do something and figuring out how to do it as I go. Education is expensive. I get mine on the customer's dime, and I'm not the least bit ashamed of it.
Old 08-19-2009, 06:29 PM   #34
Somehow I knew that.
-Hal
Old 08-19-2009, 07:11 PM   #35
steelersman's Avatar
All I wanna know is, what the hell is .320 and RG-10,11,12 and any other number out there? All I've heard of is RG-6 and 59. Is RG-6 bigger than 10,11, and 12 or smaller?
steelersman is online now   Reply With Quote
Old 08-19-2009, 08:52 PM   #36
Lighting Contractor
According to Hal, if you ask that question, you should not be allowed to utter the word electrician.
Old 08-19-2009, 11:35 PM   #37
Marc is pulling your leg with RG-10 and 12, kinda like the 220, 221 whatever it takes thing. I would have to look to see if there are such numbers, there may be but it wouldn't be used for anything we would be interested in.
The RG designation dates back to WWII and the military. The numbers are meaningless unless you look up the spec. So if there is a RG-10 and an RG-12 they probably would have no resemblance to each other.
Although some true RG spec cables are still made, (RG-59 is widely used for video) the CATV cables we are familiar are only called RG-59, 6 and 11 and are of a completely different construction than the military spec. The RG designation is only maintained as a size reference. There is a recent RG-7 that never had an actual RG equivalent and is a bit larger than RG-6.
Cables like .320 are a modern departure from this antiquated designation system. The number represents the actual outside diameter of the shield or outside conductor. All solid sheath or hardline cables are designated this way by their OD.
-Hal
Old 08-19-2009, 11:50 PM   #38
Peter D's Avatar
Tell me...do you have any shame whatsoever? I'm really curious. From reading your replies over the years, it seems like there is nothing you won't stoop to to make a buck. To put it bluntly, you kind of seem like a whore to me.
This is actually a serious question and not my usual nonsense.
Old 08-20-2009, 12:44 AM   #39
Lighting Contractor
Old 08-20-2009, 01:11 AM   #40
My observation... Hal is a world-class d!ckhead. Too bad he's actually knowledgeable too. Such as waste of knowledge.
Hal... Comcast phased out RG-11 in my area several years back in favor of .320.
Is the .320 they are using still RG-11 or is RG-8 or variant of it? Most specs still list 11 as the predominant head end cable. What's the application video, cctv, dbs other?
monitormix is offline   Reply With Quote
Motor Terminations Burning up?! HOW? msoucy General Electrical Discussion 22 06-27-2009 08:22 PM
Torque on bolts lugs & terminations nick General Electrical Discussion 43 04-20-2009 10:40 PM
hot tub bigger pain than it's worth ewjussila78 Other Codes and Standards 13 01-01-2009 10:04 PM
