Originally Posted by reddog552
I just did a job for these gugs with there brand parts. We did 4,500 drops of Cat 6e of data & the same of voice.I was not impressed with the quality of the Chineese made parts.On 1 phase of the job we had pulled and punched down 2000 runs,RECALL there plentum rated wire wasnt? pulled them all out.Reran them all.We used 24 & 48 port 110 blocks.10% failed,Coroded contacts bent contacts, No conection between punch down block and contacts. http://www.blackbox.com/ Have any of you guys done any work with these guys parts.
Wow, that's quite a large job!
Just to clarify, you have done 4,500 dual drops? Meaning one data (Cat6a) and one voice (Cat3 or Cat5e) to each location... 9,000 cables total?
I'm sure it was just a typo, but
Cat 6e (as you typed) is not a recognized cabling standard by the TIA/EIA.
Category 6a is however a recognized standard and also, sold by BlackBox.
Next, I can't imagine their cable marked as "PLENUM or CMP" is not. That is easily checked against a
UL certification database record though, if memory serves.
Also, as you reference "Chinese parts", there cable is always advertised as
Made in the USA. As for their parts (66/110 blocks, patch panels, etc.) I would estimate at least 50% is also advertised as
Made in the USA. The items that are not advertised as such... I'm not sure of the origins.
I have done work for BlackBox in the past (on a much smaller job) and their quality of cable and endpoint items (110-66 Blocks, jacks, panels, etc.) was on par with any other brand name (Hubbell, Ortronics, Panduit, etc.) items I've used in the industry. Corroded contacts on the blocks is very rare, as there has to be a significant presence of moisture, over a period of time to have corrosion occur on out of the box items... meaning the box it came in would be noticeably weathered from water damage. If that was the case, it should have been returned immediately to the supplier for a replacement. I find corrosion even more of an oddity with BlackBox, as every endpoint item I have received from them on a job was wrapped in plastic as it came out of the cardboard container. I will say that on a job that size, bent connectors may come into play, by sheer percentage of failure rate compared to the quantity of items. 10% does seem a little high, though. Keep in mind that an improperly trained technician, in the art of cable termination, could lead to bent pins/connectors very easily.
I also
strongly agree with -Hal's statement about a project manager :
Originally Posted by hbiss
...With a job of that size wasn't there a project manager that required submittals and approved the materials before hand?
I think a little clarification on specific details will help on determining what the exact origin of the fault was. The more details you can provide, the better!
Thanks,
Tony
