Cable management at pull points - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 4 Post By Suncoast Power
  • 2 Post By steve@neoitsvcs.com
  • 1 Post By AK_sparky
  • 1 Post By ponyboy
Old 12-20-2016, 03:57 PM   #1
Rewards Points: 14
Default Cable management at pull points
Does anyone have a good solution for managing significant amounts of cable at pull points along the run? I have a fiber project that is going to require 6 or 7 pull points along the run and I really don't have the overhead to have someone just standing there watching the cable on the floor. I was thinking about adding 2 uprights to a sawhorse and then just dressing the cable back and forth between them. The problem is I'm wondering how the cable is going to pull the horse. Normally I have enough of a crew to manage the slack on the floor but this one is SUPER thin on the margins. One of my partners in another part of Ohio got hurt on a job and needed some help getting this done. I don't think he bid it correctly but I'm in a pinch helping him. He has helped me in the past in a pinch so I feel the need to return the favor.
steve@neoitsvcs.com is offline   Reply With Quote
Old 12-20-2016, 04:33 PM   #2
Rewards Points: 14
I'm looking at this process but on an elevated platform.
http://www.thefoa.org/tech/ref/OSP/install.html
For a midspan pull, use these directions:
This procedure eliminates having to flip the cable in the Figure 8 on the ground over.
Place the cable reel a mid point on the long span (ensuring the maximum pulling length in either direction would not be exceeded).
Pull the one end of cable through the conduit to one end of the span.
Roll the cable off the reel and Figure 8 the remaining cable on the ground. The end on the cable will be on the top of the figure 8.
Pull the second end of the cable through the conduit to the other end of the span.
Old 12-20-2016, 05:57 PM   #3
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,894
Honestly,
You need to mitigate your risk damaging that fiber as best as you can.
This means just spending what you need on the labor to get the project complete, do a first class job.
You will forget about spending a few extra bucks and just get it done.
I dont know the length of the pull but its possible to carefully load it in a big trash can and normally it will payout just fine. Alternately, it could be a disaster.
The Following 2 Users Say Thank You to Suncoast Power For This Useful Post:
360max (12-20-2016), hardworkingstiff (12-21-2016)
Old 12-20-2016, 06:18 PM   #4
Rewards Points: 14
The pull is just over 1600', I'm just going to bite the bullet and pay a few of my normal crew to help out.
hardworkingstiff and 360max like this.
Old 12-20-2016, 09:51 PM   #5
Rewards Points: 2,755
I think this is your best option. Thin margins become red numbers if you try to cobble something together and it fails.
360max likes this.
AK_sparky is offline   Reply With Quote
Old 12-21-2016, 05:25 AM   #6
Rewards Points: 3,068
The suggestion linked to despool everything into one big figure eight in the mid span is probably not helpful in this job, it would be useful if you had a third person but that's not necessary.
You only need two people to do this job. Before you start pulling, all the strings should be in place. Start with man #1 feeding from the spool at the starting point, man #2 pulling and piling at the first pull point. When it's all through, man #1 goes to the second pulling point, man #2 feeds, man #1 pulls and piles. I don't think 1600' will take long at all, as long as you're set up and prepared, I can't see it taking a full day.
The most important tool for this job - handsfree radios.
"The thought is in the question, the information is in the answer." -Nehemiah Hawkins
Old 12-21-2016, 06:39 AM   #7
Rewards Points: 12,664
That is a wise decision. Don't let a bid mistake push you into subpar work.
Giving up on unbiased truth.
Old 12-21-2016, 06:53 AM   #8
ponyboy's Avatar
Rewards Points: 709
I've done something similar a few times with fiber pulls. I learned to not change direction with pull points but rather put the box or conduit body directly before or after a 90. There were a couple long pulls we did (1600+') that we could sometimes pull right past a pull point or change of direction eliminating the need for a man at that spot.
Old 12-21-2016, 10:47 AM   #9
Rewards Points: 4,468
We got away with doing the figure 8 method most times, but I remember one long fretful night at Y concourse in Honolulu airport we had a taxi runway shut down for a figure 8 and it got all tangled to hell. We were there till the sun was coming out getting it right and the ''powers'' at the airport were pissed at us .
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Outdoor Telephone Cable shocksystems Structured Wiring 10 11-06-2016 10:13 AM
Ground/Shield VFD cable termination Kris Wu General Electrical Discussion 8 07-07-2016 12:58 PM
No MC Cable Bushings swimmer Commercial Electrical Forum 32 07-04-2016 05:47 AM
Cable strain relief - extreme conditions chrisfnl General Electrical Discussion 16 04-23-2016 07:02 AM
stove cable max length oscar sparo General Electrical Discussion 0 03-21-2016 02:53 PM
