Old 04-11-2012, 04:01 PM   #1
Default Camera wiring
Can anybody help me out!? I have a customer that has a simple closed circuit camera system, there is power and a rg59u going from the camera to the monitor. We originally got called to replace the camera as the monitor had a blue screen we replaced the camera and nothing still. Blue screen. After that they wanted us to replace the ends so we did bingo it started working, or so we thought it worked for 20 minutes and back to blue screen. Tried going out and now replacing the monitor and it same thing worked for about a half hour and back to a blue screen. Any ideas what I could be before I go and pull new wire between the two? Voltage at the camera and monitor is constant doesn't drop out or anything.
Sparky480 is offline   Reply With Quote
Old 04-11-2012, 05:01 PM   #2
976-EVIL
mcclary's electrical's Avatar
Did you determ the coax on both ends and read between the core and shield for shorts?
Old 04-11-2012, 05:05 PM   #3
B W E's Avatar
This is why I only use cat5
Old 04-11-2012, 05:08 PM   #4
976-EVIL
Do what????????????
Old 04-11-2012, 05:51 PM   #5
Yes no shorts rings out clear going to try and megger it tomorrow with 500v
Old 04-11-2012, 06:05 PM   #6
976-EVIL
What was the ohm value?
Old 04-11-2012, 06:14 PM   #7
B W E's Avatar
do what????????????
i only use cat5
Old 04-11-2012, 06:18 PM   #8
976-EVIL
i only use cat5
sorry to hear that.
Old 04-11-2012, 06:19 PM   #9
B W E's Avatar
sorry to hear that.
Whys that?
Old 04-11-2012, 06:33 PM   #10
B W E's Avatar
sorry to hear that.
Do tell, don't be shy....
Old 04-11-2012, 07:40 PM   #11
B W E's Avatar
That's what I thought...
Old 04-11-2012, 07:42 PM   #12
Take the camera down, put it next to the monitor with a short patch cable and see if it works that way. Could be an issue with the camera. Cable faults almost always look like something other than a blank blue screen.
Old 04-11-2012, 07:50 PM   #13
animal lover /rat bastard
wildleg's Avatar
there are several things that can go wrong with camera systems, especially the cheap piece of crap kind. besides the normal cable connection issues, and systems where the unit was built so cheap that the connectors on the back of the unit practically flop around on their own and can't handle any strain, cheap cameras have a whole nother range of issues. I had some cheap cameras start blanking out when the IRs kicked on after about 6 mos of use, and cheapo power supplies can also cause problems.
Old 04-11-2012, 08:58 PM   #14
976-EVIL
It's hackwork. Twisted cabling should not be used for power supply. It's possible, but limits the run due to VD. Just run the right seimese cable.
Old 04-11-2012, 10:04 PM   #15
B W E's Avatar
You're crazy. Cat5 allows for multiple cameras per run. It allows for PTZ. It allows for 2-way audio and video. It can be ran upwards of 750'. It's smaller and cheaper, and easy to terminate.
Not everything that's different than how you do it is hackwork.
Old 04-12-2012, 01:36 AM   #16
CDN EC's Avatar
PoE dude.
If you let the smoke out, you void the warranty. - NK
CDN EC is offline   Reply With Quote
Old 04-12-2012, 08:25 AM   #17
IT/Phone Guy
I've run cat5e with baluns for video (single pair) and twisted the remaining 3 pairs together for power. Works perfectly.
jeffmoss26 is offline   Reply With Quote
The Following User Says Thank You to jeffmoss26 For This Useful Post:
B W E (04-12-2012)
Old 04-22-2012, 10:53 PM   #18
VanIsleNorth's Avatar
I wired 16 cameras at a plant with cat 5 and it worked great. You can do four cameras with two runs. I always keep the power and signal separate, but I have found it works fine in the same cable.
VanIsleNorth is offline   Reply With Quote
Camera questions psd7.3 Structured Wiring 16 06-17-2012 06:07 PM
Inpection Camera vchewjr Tools, Equipment and New Products 4 03-01-2012 05:00 AM
Wish I had my camera. Jmohl Code Violation Discussion 7 05-17-2011 05:10 PM
New camera slickvic277 Off Topic 3 03-28-2011 08:31 PM
Camera Lighting Wireless Lighting Design 3 01-13-2008 12:03 PM
