Cat5e in EMT,do I need to ground emt? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 07-19-2016, 06:49 PM   #1
Default Cat5e in EMT,do I need to ground emt?
So I have some outdoor survellience cameras to install. The cat5e is going to have to go into emt. Each camera is going to have it's own run from camera back to poe switch. I can't find any concrete information on if I need to ground conduit somehow and if so what is the grounding requirement? This install is residential and I'm coming out their office wall(Sheetrock and wood paneling) with a weatherproof box mounted on the exterior,low voltage trim ring on interior wall with conduit from weatherproof box to each camera location. Any help is greatly appreciated.
newvision is offline   Reply With Quote
Old 07-19-2016, 07:35 PM   #2
NRA Member
backstay's Avatar
Rewards Points: 794
So all the EMT is exterior, and not continuous. I say no.
Old 07-19-2016, 07:39 PM   #3
Yes emt is all exterior, mounted to soffit of house. I didn't think I needed to, but just wanted to make sure.
Old 07-19-2016, 07:44 PM   #4
NRA Member
backstay's Avatar
Rewards Points: 794
When low voltage systems come into the structure from elsewhere in conduit(metal) you have to ground it(bond). Metal water piping systems have to be. But I don't know of anywhere a noncontinuous metal system has to be, think fence, hand rail, ect.
Old 07-19-2016, 07:48 PM   #5
Click Here
Rewards Points: 1,356
I've installed a couple thousand EMT sleeves for low voltage wiring and never even thought about grounding. Never failed an inspection either.
Old 07-19-2016, 08:31 PM   #6
Thank you guys for your help! It's greatly appreciated!
Old 07-20-2016, 04:30 PM   #7
gnuuser's Avatar
Rewards Points: 1,616
while it may not need to be bonded it should be (if anything it can act as emf shielding)
while a camera system is not a vital communication network the cabling can still pick up induced voltages powerful enough to damage equipment.
the crucial thing to remember is never run communications and power cabling in the same conduit or raceway without shielding between them
(poe voltages are not of sufficient amplitude to induce any significant current within the other conductors in the cabling) but a circuit feeding a refrigerator or electric dryer or range is another story all together
Old 07-23-2016, 11:05 PM   #8
EJPHI's Avatar
Rewards Points: 232
Doesn't Colorado get some serious thunderstorms?
Are you exterior/exposed EMT runs fairly long? Do they penetrate to the interior?
I would ground them.
EJPHI
Cl906um likes this.
Old 07-25-2016, 07:56 AM   #9
Rewards Points: 1,506
in the cec anything under 50vac or dc doesnt need grounding/bonding.
LuckyLuke likes this.
Old 09-23-2016, 10:28 PM   #10
Same in the us, it's not needed. It's actually proba ly provided in the cat5
Tom the lecrician is offline   Reply With Quote
Old 09-23-2016, 10:30 PM   #11
Yeah it's low voltage, and your conduit runs are not going to any other hox...I say you're ok
Old 09-24-2016, 04:40 PM   #12
ponyboy's Avatar
Rewards Points: 707
EJPHI
You're reaching.
Big John, TGGT and Majewski like this.
Old 09-24-2016, 06:07 PM   #13
Deplorable-Electrician
Rewards Points: 24,634
A bonding conductor?
Majewski likes this.
Old 09-24-2016, 08:04 PM   #14
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 278
I've run miles of EMT with communications and class 2 power conductors in it. I sincerely don't even care if something says that should be bonded: There's no hazard there, it ain't happening.
Big John is online now   Reply With Quote
Old 09-24-2016, 08:11 PM   #15
Click Here
I should start a service making people's houses safer by running a #6 wire around their house and bonding their railings, mailboxes, shutters, door knobs, swing sets, lawn jockeys, bushes, etc.
Old 09-24-2016, 08:45 PM   #16
Rewards Points: 2,096
If someone has lightning / surge worries, and the digging isn't too awful, adding a loop of #4 around the perimeter to the GES is not a bad buy.
Old 09-24-2016, 09:04 PM   #17
Big nosed attic troll
Majewski's Avatar
Rewards Points: 1,696
But how many times have you gotten a job like that? I don't know a house around here with that.
Old 09-24-2016, 09:26 PM   #18
Zero!
I get a lot of calls for help with lightning and surge damage but the digging always been prohibitive.
It's a tough sell with new construction, nobody's that interested until they have the problem, can't get them to add it when they build.
Old 09-24-2016, 09:31 PM   #19
Majewski's Avatar
That's what I figured. Not that I dislike the idea, I just see it as a tough sell for many reasons.
Old 09-24-2016, 09:49 PM   #20
Same here and I feel the same way.
interesting question: what if there is no bonding between ground and neutral? mike883 General Electrical Discussion 35 05-29-2016 02:18 PM
Ground fault, ship dwong General Electrical Discussion 0 05-22-2016 01:44 PM
installer cut off ground on SER cable cubgirl Residential Electrical Forum 43 05-21-2016 08:12 PM
Phantom Voltage? touchtester Residential Electrical Forum 9 04-25-2016 09:20 PM
Ungrounded Delta 480 Station Service with ground reference App4DaWin General Electrical Discussion 30 04-14-2016 12:12 PM
