Old 02-02-2009, 11:00 PM   #1
Default Co-ax question
Prior to this afternoon, we have always roughed in coax in each bedroom and run the cables back to one location, a "master location" if you want to call it that.
Today was the first day that we installed 2 TV coax cables at 2 separate locations in one large bedroom.
What is the danger of only running one of those 2 cables back to the master location and using a splitter to feed the other coax?
Do both cables need to be run to the master location or is this acceptable?
Thanks,
Rick
subelect is offline   Reply With Quote
Old 02-02-2009, 11:16 PM   #2
cdnelectrician's Avatar
Yes they SHOULD be, it's not a good idea to have splitters all over the place. Everytime you put a splitter in a line you will loose some of the signal. For the price of a good splitter, and 4 compression connectors not to mention the time to try and squeeze that all into a 2104 box why not run an extra RG-6 to the other outlet from the basement.
Old 02-02-2009, 11:52 PM   #3
lectric_hand6855's Avatar
I agree, go ahead and make 2 homeruns. Splitters can be he11 on a high speed internet connection.
lectric_hand6855 is offline   Reply With Quote
Old 02-03-2009, 12:26 AM   #4
Fredman's Avatar
Thanks,
Rick
If they are indeed placing 2 TV's in this one bedroom, then it's a bad idea. On the other hand maybe they know there will only be one TV. The first split point being the preferred placement option. The the end of the line would be the 2nd "maybe" spot. Then they would use a pass thru barrel connector (not a splitter) at the split point and blank cover it. I like to use low voltage rings when possible. No craming required.
Just a cheap insurance option for some.
No I've never done this.
Fredman is offline   Reply With Quote
Old 02-03-2009, 01:06 AM   #5
Wanna be Guru
mikeg_05's Avatar
LV rings are a must when using splitters.
Old 02-03-2009, 08:34 AM   #6
thank you.
Rick
Old 02-03-2009, 10:03 AM   #7
You cannot use a splitter on satellite feeds.
Greg C is offline   Reply With Quote
Old 05-04-2009, 12:18 AM   #8
I usually pull this Structured Wiring Triamese Cableforan application
like this. Includes (2) Rg6 and a (1) Cat 5e. They also have 2 plus 2 which is 2 Cat 5e and 2 RG6 Cables. I always pull a combo cable. Saves some serious time and time is money!
http://www.cablegiant.com/Default.as...Product_id=701
ElectricalMAN is offline   Reply With Quote
Old 05-04-2009, 12:24 AM   #9
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
As Greg said.. DONT PUT SPLITTERS IN.. just pull homeruns.
~Matt
Old 05-04-2009, 12:36 PM   #10
Phone Flunkie
Thanks,
Rick
Run the dual coax. The customer may be planning on installing a product such as DirectTV with a DVR, which requires a dual coax run.
chrislovo is offline   Reply With Quote
Old 05-04-2009, 06:50 PM   #11
steelersman's Avatar
Only a total bufoon would use an actual box instead of the intelligent option of a ring. Doh!!
steelersman is online now   Reply With Quote
Old 05-04-2009, 06:53 PM   #12
Well if you were actually paying attention to what the OP stated you would understand that there are two, that's 2 (two) locations. Again that's TWO (2) locations. Also the DVR doesn't requite 2 cables to work. It can work off of one cable althoug it is desirable to have 2 so that you can record on one channel and watch a different channel at the same time.
Anyhow, just homerun everything that way you don't have to worry about it.
Old 05-05-2009, 12:52 AM   #13
Phone Flunkie
I was paying attention, and understood the question the way that it was written. Simply saying that they installed two (dos) coax cables at two (deux) separate locations could be construed as two (II) drops at each of the locations.
I apparently misinterpreted Rick's question.
Old 06-22-2009, 10:40 PM   #14
Local 150 Lake County,IL
I never use boxes ha ha
running dummy is offline   Reply With Quote
Old 06-27-2009, 01:43 PM   #15
Question
Homerun EVERYTHING??? Nobody uses signal amplifiers???????
Old 06-27-2009, 01:49 PM   #16
There area lots and lots of fine reasons to homerun everything, and signal strength is pretty low on the list. In my own home, for instance, I have my TiVo box centrally located at the distribution point with IR passing from every set. I can watch TiVo from any set in the house. I'd never be able to do that without home runs. My driveway camera has a modulator at the distribution point, and I can watch that camera on any set in the house too. I'd never be able to do that without home runs. I used one run to pipe audio to the back patio using a balun. I'd never be able to do that without home runs.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 06-27-2009, 02:05 PM   #17
And there you have it. More reasons to homerun everything. If you homerun everything, then the sky is the limit. If you don't homerun everything then you are very very limited to what you can do as Marc explained.
Old 06-27-2009, 02:10 PM   #18
Thumbs up
And so I learn something new. Thank you for that. LV/phone&cable is something I am not all that bright with. Thanks Marc, thanks steelers!!!!
Old 07-04-2009, 04:04 AM   #19
Larry Fine's Avatar
Send a message via AIM to Larry Fine
I have for two outlets installed in a single room for flexibility. Home run to one outlet, and an extension from there to the second.
If the TV's at the first outlet, the extension just sits. If the second outlet is used, a barrel joiner connects the extension to the home run.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
Old 07-04-2009, 03:04 PM   #20
Toronto Sparky's Avatar
Splitters really mess up anything digital.. Home runs are always better run to a main splitter probably fed from a high freq amp if you are using a few outlets.
Keep in mind some amps do not allow two way communication though them.. Very important these days.
All unused ports in the splitter must be caped with a terminating resister.
Also keep in mind the old splitters do not work well (if at all) on digital signals.
RG59 also is useless
RG6 all the way..
