Originally Posted by Wireless
I recently installed a DSL jack in an office. The DSL came in on the same line which is used by the alarm to dial out. I split the feed so that the DSL jack was unfiltered and the alarm and line going to the PBX were filtered. The customer is telling me now that the lines keep dropping, they will be talking on the phone and it just cuts out. I initially thought the alarm is trying to dial out for some reason and is causing the line to drop but, they told me it happens on all the lines so it can't be from the alarm. Of course this only started after I was there! What could cause this?
I'm trying to put this scenario together in my head... I'm not sure what you mean by filtered. Isn't the PBX a ground start system?
How exactly did you split the outside POTS/DSL line while also connecting it to the PBX?
Every time the PBX flashes ground to seize the line, won't that outside line be dropped? With most of the phone systems I worked on, the alarm system used an outside line independent of the PBX, but then again, where going back a few years.
