Experience with Ubiquiti - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
Old 04-20-2017, 04:46 PM   #1
RePhase277's Avatar
Rewards Points: 3,238
Default Experience with Ubiquiti
Out on the Super-Secret Off Grid RePhase Remote Property, I have no utility access, nor do I want any, except internet. The closest fiber is on the main road, about 2000 feet as the crow flies. A friend suggested Ubiquiti broadband antennas. So I'm going to set a pole with a weatherproof enclosure for the fiber modem, battery, and charge controller, powered by a 50 watt solar panel.
Does anyone have any experience with a setup like this?
Old 04-20-2017, 04:53 PM   #2
Band Member
emtnut's Avatar
Rewards Points: 7,450
Nope I've used Ghostbridge , with either a morningstar or xantrex charge controller ... totally different
I'm the roughinest toughinest rootinest, tootinest bobtailed wildcat north, south east or west of the Pecos
Old 04-20-2017, 05:42 PM   #3
Jlarson's Avatar
Rewards Points: 2,954
Used a lot of it, both for networking and for SCADA. It's been reliable.
RePhase277 likes this.
Jlarson is online now   Reply With Quote
Old 04-20-2017, 05:53 PM   #4
RePhase277's Avatar
What kind of speeds vs. distance did you see? I've read good reviews, but I want some live person feedback. Any particular model that's better than another? I'm getting a 1 Gb/s drop, so I'll want to get as close to that throughput ability, even if I don't actually approach it.
Old 04-20-2017, 06:07 PM   #5
drsparky's Avatar
Rewards Points: 390
How about a Ubiquiti PowerBeam M2 wireless bridge? Just like having a real long ethernet cable. Good for over 10 miles line of site. Simple to set up. Cheap cost.
emtnut, MikeFL and RePhase277 like this.
Old 04-20-2017, 06:41 PM   #6
Rewards Points: 2,204
Ubiquiti is the best choice IMO but Gigabit is a challenge! You have to bump up to the Airfiber.
Are you SURE you really need gigabit?
Old 04-20-2017, 07:02 PM   #7
Band Member
emtnut's Avatar
Gigabit ... In the bush
You running a server back there
The Ghostbridge is an outdoor unit, up to 150Mb/s , and around $500 US for the pair ... not sure how that compares to the ubitquiti.
50 watt panel seems small, unless you are going to have it powered off when you're not there.
Old 04-20-2017, 07:42 PM   #8
RePhase277's Avatar
I've decided to go with the less expensive 100 Mb/s drop, which is still over 3 times faster than what's available at my house in town. All I need to upgrade later is a different modem according to the ISP.
I get by OK at 30 Mb/s, but my son has some game issues when we're full bore on Netflix simultaneously. I think it's hilarious that I can get better out in the woods.
MechanicalDVR and HackWork like this.
Old 04-20-2017, 08:16 PM   #9
Click Here
Rewards Points: 1,502
Wow, that is crazy cheap. What else do you need?
RePhase, I have gone the opposite direction with bandwidth. I went from a 100/50 fiber connection back to Comcast cable with a 25/5 connection (realistically measured at about 29/6) and 2 of us could still stream Netflix HD at the same time and still surf fine.
So 100 Mb/s should be great for you.
Old 04-20-2017, 09:00 PM   #10
Cow
Rewards Points: 2,396
We're working a large dairy project right now and one of the automation contractors is using Ubiquiti antennas to bounce all the PLC signals around. He's pretty anal about his stuff so I know it has to be good.
But I honestly know nothing about it.
Old 04-20-2017, 09:00 PM   #11
RePhase277's Avatar
The antenna transmits at less than 1 watt, but call it 3 for safety. My current modem has a power input requirement of 12 V at 0.75 A, so 9 watts. Call that 15. So less than 20 watts is what I figure on using at most. I think 50 watts would be plenty and should provide good output even on overcast days.
But if I have to, I'll just put a bell box with a switch on the pole. I have to drive by it to get to the property, so I'll just stop and flip it on or off.
Old 04-20-2017, 09:03 PM   #12
drsparky's Avatar
Rewards Points: 390
That's it, I just looked on Amazon, was expecting $300 only $80 bucks.
go for it.
Old 04-20-2017, 09:03 PM   #13
Click Here
You run this place off a generator?
Old 04-20-2017, 09:10 PM   #14
RePhase277's Avatar
At the camp there is currently a battery box with 410 Ah and 300 watts of solar. The water pump is 12 V. A 2000 watt inverter gives me all I need for 120 V. I brought the generator out to run some power tools just in case once, but the inverter handled it all just fine.
Old 04-20-2017, 09:15 PM   #15
Click Here
If you ever want to run power, I know this guy named Plooktard who can get power the 2,000 feet to your place. It will only take him 17 years.
macmikeman likes this.
Old 04-20-2017, 09:26 PM   #16
RePhase277's Avatar
Why, that's over 117 feet per year! That's NASCAR speed compared to what I'm going to do it at!
Old 04-20-2017, 10:13 PM   #17
Jlarson's Avatar
Yeah if you want gig you'd need the air fiber. For your new plan I'd use the powerbeams.
They are 24v Poe.
Old 04-20-2017, 10:54 PM   #18
RePhase277's Avatar
So, with as much vegetation in the way as I have, I don't think even the 900 MHz equipment will do, according to my research. I'm going to have to get these darn things above the the trees, or at least high enough that the tree density is low. Damn stupid Super-Secret Off Grid RePhase Remote Property
Old 04-21-2017, 06:50 AM   #19
Band Member
emtnut's Avatar
I just read that the Ghostbridge is a re-branded Ubiquiti M5 .... at 3X the price
Son of a beech's
Old 04-21-2017, 07:28 AM   #20
That has to be some deep dark jungle. If you have something like a nice tall straight pine, I bet you could hang it IN the tree, as long as it's down far enough it doesn't whip around in the wind. It's only PoE.
Florida unlimited electrical license experience requirements CoreyJ General Electrical Discussion 2 10-17-2016 09:12 AM
Generator experience NC Plc General Electrical Discussion 16 08-03-2016 08:57 PM
Aspiring apprentice. Experience applying with local 191 and 46 asdfsa2377 Union Topics 0 04-14-2016 11:45 AM
Primary NEC Experience & Traffic Signal Installation theForce General Electrical Discussion 14 03-06-2016 11:49 PM
Work Experience Database NJWVUGrad General Electrical Discussion 0 02-04-2016 12:18 PM
