Old 04-03-2012, 09:16 PM   #1
rrolleston's Avatar
Default Intersystem Bonding Bar Mounting
other than looking ugly is it ok to use bare ground or neutral bars from old panels for intersystem bonding bars?
Old 04-03-2012, 09:20 PM   #2
Hairbone's Avatar
Only if your from Whitehall
BTW, is this from a commercial of residential set up?
BORN TO FISH... FORCED TO WORK
FISH ON
Hairbone is offline   Reply With Quote
Old 04-03-2012, 09:49 PM   #3
rrolleston's Avatar
Residential setup. I just have a bunch bars and thought maybe I would do it so the cable and telephone companies make their connections. And maybe grab one next trip to the supply house. Saving me a 45 min drive one way.
Old 04-03-2012, 10:29 PM   #4
NRA Member
backstay's Avatar
Not made to be out in the elements.
When "deleted" called the Seals, they killed Bin Laden. When the Seals called "deleted", he denied them.
Old 04-03-2012, 10:43 PM   #5
Bababoee
captkirk's Avatar
Im not sure but something tells me it needs to be a listed item...
Full time Bovine Scatologist.
Old 04-03-2012, 11:04 PM   #6
rrolleston's Avatar
It's inside.
Old 04-03-2012, 11:44 PM   #7
rrolleston's Avatar
Does not say it has to be listed in the NEC just has to meet the min 6 gauge copper wire and min 3 terminals.
Old 04-03-2012, 11:59 PM   #8
Edrick's Avatar
Why not just get the grounding devices from Arlington that's for this?
Edrick Smith
ES Productions - Entertainment Solutions
»edricksmith.com
Edrick is offline   Reply With Quote
Old 04-04-2012, 12:08 AM   #9
rrolleston's Avatar
I just need this in place so the telephone company and cable company can make their connections and grab one next time I go to the supply house.
Old 04-04-2012, 06:59 AM   #10
not a union thug
electricmanscott's Avatar
A reasonable person would conclude the op's idea is perfectly acceptable.
The Following User Says Thank You to electricmanscott For This Useful Post:
rrolleston (04-04-2012)
Old 04-04-2012, 07:17 AM   #11
I_get_shocked's Avatar
I agree and have done just what he describes (indoors).
Why buy something you already have?
last shocked on 6/24
I_get_shocked is offline   Reply With Quote
The Following User Says Thank You to I_get_shocked For This Useful Post:
Old 04-05-2012, 09:52 PM   #12
rrolleston's Avatar
Interesting thing today the guy from time warner cable cable comes and asks where my cable goes inside and is there a place to ground the new cable their I said there is a bonding bar fed with some #6. And he says they won't allow him to use it without even looking at it. I say what are the other options. Water main, clip on panel, or strip the #6 ground wire and use a clamp that has a lug for the cable ground. Basically the same thing as using a bonding bar.
I though an electrician was crazy when he said some cable guy put a clip on an outdoor panel cover when there was a nice bonding bar mounted to the ground conduit. This don't make sense the NEC says we have to have it but they won't use it.
Old 04-06-2012, 08:56 AM   #13
NRA Member
backstay's Avatar
Maybe it just hasn't made the list yet.
Old 04-06-2012, 12:48 PM   #14
IT/Phone Guy
I did just that in my basement. Got a 6 space ground bar and mounted it to the wall. One ground comes in and I have multiple connections for phone systems and cable splitters.
jeffmoss26 is offline   Reply With Quote
Old 04-07-2012, 01:04 AM   #15
Ty Wrapp's Avatar
As a TELCO installer, I say Thank You!!1
Ty Wrapp is offline   Reply With Quote
Old 04-07-2012, 12:40 PM   #16
rrolleston's Avatar
Does the phone company actually use it or do they do like they cable company and ignore it adding a clip to the meter or ground clamp on the wire instead. I installed a 20 terminal bar for splinters and all my networking. The cable guy was surprised to see a nice setup with backboard and grounding in a mobile home.
Old 04-07-2012, 04:36 PM   #17
rrolleston's Avatar
What gauge wire do you use to ground the demarc box?
Old 04-07-2012, 07:10 PM   #18
davis9's Avatar
I use the grounding bars inside on my installs. Usually drill and tap it to the side of the panel..Hope that's legal.
Tom
davis9 is offline   Reply With Quote
Old 04-07-2012, 08:50 PM   #19
PGW Professional
Magnettica's Avatar
45 minute drive to SH.
Old 04-07-2012, 09:21 PM   #20
Ty Wrapp's Avatar
If it was available I would use it as long as it is connected to the power ground.
Mounting boxes backstay Commercial Electrical Forum 23 02-09-2012 08:32 PM
PC-30 mounting leland General Electrical Discussion 4 01-14-2012 08:04 PM
250.94 Intersystem Bonding Termination Roger123 Code Violation Discussion 10 04-12-2011 01:05 AM
Mounting a Job Box in the van nitro71 Tools, Equipment and New Products 10 03-15-2011 04:30 AM
Intersystem grounding lug waco General Electrical Discussion 7 08-20-2009 04:20 PM
