Old 10-07-2009, 11:27 PM   #1
Default Minimized LCD cables
In LCD 128x64, it usually have 8 ports.
Do you think there's a way to connect the device to work by using 4 cables only? Do we have to use all 8?
getthoboy is offline   Reply With Quote
Old 10-09-2009, 09:25 PM   #2
What are you talking about??
-Hal
hbiss is offline   Reply With Quote
Old 10-10-2009, 01:13 AM   #3
Default Minimizing the # use of cables
I'm trying to find a way to decrease the number of cable usage from the LCD Display to connect the Microprocessors. If i use the standard interface by using 8 cables, it'll cost a lot and will be messy.
DO you think it's possible to decrease the amount of cable usage while sending the same amount of data?
Old 10-10-2009, 02:01 AM   #4
cdnelectrician's Avatar
lol HUH?
Old 10-10-2009, 04:40 AM   #5
NO high voltage here
i design cables and lcds.... im lost
the normal is a 14 pin vga cable.
Old 10-10-2009, 10:00 AM   #6
This is an electrician's board. I think you need to be on an electronics board.
-Hal
Ground wires in cables tss-electrical General Electrical Discussion 2 06-10-2009 03:34 PM
400 amp SE cables hembone7 Services and Service Equipment 3 02-18-2009 01:38 AM
Vlf Hipoting Of Cables Lone Crapshooter General Electrical Discussion 1 01-17-2009 07:27 AM
HT Cables Erection Prabhu85 General Electrical Discussion 6 09-08-2008 08:04 AM
NEC Articles 320 and 330 for AC and MC Cables Joe Tedesco NEC Code Forum 7 04-08-2007 03:29 AM
