Old 08-11-2009, 10:36 PM   #1
Default Need help w/ AC to DC Mean Well Power Supply
I am needing to set this up but I am not sure how to go about it.
http://www.trcelectronics.com/Meanwell/sp-500-48.shtml
Can anyone help me get this setup.
This needs to be pluged in to a standard AC 110v outlet, the output is going to an electronic equipment.
I'm just not really sure how to cable it.
For the input I cut the end off of a regular computer cable w/ the black green and white insulated cables, I'm not quite sure where to go from here.
Sorry if i sound like a complete idiot, I have just never done this before.
dslam24 is offline   Reply With Quote
Old 08-11-2009, 10:39 PM   #2
What you want to do needs to be done with a UL listed assembly. It's not as easy as slapping a cord on that power supply. You can find 48vdc power supplies that already have power cords from telephone suppliers. Valcom, maybe, comes to mind.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 08-11-2009, 10:42 PM   #3
Here's a 2 amp one, so we're on the right track... http://www.valcom.com/techsupport/po..._ts/vp2048.htm
Xantrex and Sorenson would be a couple more places.
Old 08-11-2009, 10:55 PM   #4
What are you doing with it, by the way? 48vdc is being used a lot lately in the larger power supply sizes for bigger POE installations, like multiple cameras or multiple AP's in a large building. There are some really slick multi-point POE injectors on the market now that solve that issue in one neat box.
Old 08-12-2009, 07:50 PM   #5
This is just a quick setup for a ethernet switch. I just want to bring it up and make sure it's up to par before deploying it. The final location will have DC power this is just a temp thing.
Old 08-12-2009, 09:19 PM   #6
Well then, you sure don't need 10 amps, do you? Get a proper POE injector and quit fussing over some DIY arrangement.
Power Supply Hicksynet General Electrical Discussion 5 07-01-2009 08:51 AM
power supply for RV selectfew General Electrical Discussion 12 06-24-2009 01:28 PM
Custom Power Supply: Help Please :| tigerpushpop Structured Wiring 1 05-09-2009 09:11 AM
Garage power supply fife_sparky UK Electrical Forum 3 03-04-2008 12:25 PM
wiring 2 lights off one power supply? divy Lighting Design 1 02-08-2008 10:29 PM
