Old 04-19-2012, 03:54 PM   #1
MollyHatchet29's Avatar
Default Patch Panel
Ok, data tech masters... Which would you prefer; the first or second photo.
MollyHatchet29 is offline   Reply With Quote
Old 04-19-2012, 04:17 PM   #2
Data Tech/Apprentice.
chewy's Avatar
Try something like this and move that slack up the loom to where you cannot see it. I only wrote velcro because it seems that its generally what you guys use in the states, zip ties are fine because as a proffesional you wont be doing them too tight.
This diagram is feeding from the left, for the next one down I would loom the cables in feeding from the right in a stand alone cabinet or in a data centre with rows of cabinets/racks. In a telco closet we usually put the cabinet against a wall and run tray down the wall and branch the looms off so they will all be feeding from the same way. Yes, I know I cant draw and have the handwriting of a hypothermic four year old
Old 04-19-2012, 04:59 PM   #3
Thanks for the info. I agree that your posted method of dressing the cable is the most appealing, but out of those two photos, is one method preferred over the other? Are there set rules for dressing down a patch panel (other than don't do a slop job, trim your tie wraps...) or is it up to the installer to do it in their own style?
Old 04-19-2012, 05:27 PM   #4
chewy's Avatar
One of the big ones for me is that "real estate" in a panels management and droppers is hard to come by so I always loom in cables in a way that leaves the maximum amount of room for the next time, the IT guys might want to run some interlinks themselves and they appreciate when we take them into account.
The way I posted is the only way I dress my panels from 2RU panels hanging on the wall in a UPS room to 50+ rack data centres and I learnt that off someone else who learnt that off someone else and everybody here seems to do it that way.
The trouble with the first pic is what if someone wants to punch down onto the panel beneath it? there is also no management bar and they arent loomed in a way so that they support themselves so all those cables are hanging by their own weight from the punchdown. It does look the tidiest from an aesthitic sense but just lacks a bit of practicality.
The top one could have been best but is let down by randomly spaced zip ties and cables crossing over from the top panel down to the lower panel and cables are all different lengths or perhaps they were all cut to the same length not taking into account that 1 cable is going to be about 400mm longer than 24 cable. They also need to be combed out and that slack needs to be taken up and put elsewhere.
Old 04-19-2012, 06:13 PM   #5
I would have to say pic 1...... I will take some pics of my work Tomorrow. 2 isn't bad but it gets crowded.
mikeylikesit5805 is offline   Reply With Quote
Old 04-19-2012, 08:38 PM   #6
zwodubber's Avatar
I should be done with the one I'm working on Saturday, I'll get some pics
zwodubber is offline   Reply With Quote
Old 04-19-2012, 10:05 PM   #7
Conservitum Americum
LARMGUY's Avatar
http://www.mercury-group.com/images/...ed_Cabling.jpg
There are 10 types of people.
Those who understand binary and those who don't.
The Following 2 Users Say Thank You to LARMGUY For This Useful Post:
360max (04-23-2012), chewy (04-19-2012)
Old 04-19-2012, 11:12 PM   #8
chewy's Avatar
Originally Posted by LARMGUY View Post
Thats exactly how we loom our cabinets and racks.
Old 04-19-2012, 11:28 PM   #9
In my opinion both pictures look terrible. I will post a picture tomorrow of I, as well as everyone else at my shop, wires a patch panel.
Those Leviton panels come with a rear cable support bar. You should definitely use it.
Dawizman is offline   Reply With Quote
Old 04-20-2012, 12:11 AM   #10
NO high voltage here
two of mine...
Old 04-20-2012, 08:44 AM   #11
Thanks for the info. Theses aren't mine; one is existing, one is new. I did a 110 block (something new to me) but I was trying to illustrate a point to the guy I'm working with that the patch panel should be fixed. Most of the existing cable looks like poop. Then again, we aren't data techs and I've only had the experience of being trained to dress and terminate on a patch by a grumpy old tech who was anal retentive about everything (so am I). Anyway, thanks for the photos. Hopefully they'll help me convince him to fix it.
Old 04-20-2012, 10:53 PM   #12
Electron Flow Consultant
sparky970's Avatar
I would go with the first picture, but with velcro
Old 04-21-2012, 12:27 AM   #13
Heavily Armed Member
HARRY304E's Avatar
First one looks good..
Old 04-21-2012, 12:51 AM   #14
Master Plumber
TOOL_5150's Avatar
Really, the only pictures that look passible [is that even a word] are the ones from mikeh. The 2 panels with the yellow cables are too sloppy as far as standards around here.
Poor planning on your part does not constitute an emergency on my part.
Old 04-21-2012, 10:26 AM   #15
BBQ
BBQ's Avatar
Is this good?
BBQ is online now   Reply With Quote
Old 04-21-2012, 10:32 AM   #16
cog
stuiec's Avatar
Originally Posted by BBQ View Post
Is this good?
Looks like soeone was going for job security
Old 04-21-2012, 11:41 AM   #17
Here are a couple pictures of my work. I'm open to any suggestions for improvement.
The Following 3 Users Say Thank You to Dawizman For This Useful Post:
360max (04-23-2012), CDN EC (05-09-2012), sarness (04-23-2012)
Old 04-21-2012, 12:42 PM   #18
erics37's Avatar
Is this good?
Looks like someone blew chunks on Power Node 2
Old 04-22-2012, 10:19 PM   #19
IT/Phone Guy
Very nice, dawizman!
jeffmoss26 is offline   Reply With Quote
Old 04-23-2012, 09:54 AM   #20
Spaghetti Cleaner
I cant think of any other then I prefer to start on the right as not to block access later, looks real nice otherwise, are they going to use in rack switching?
Thread shorter.
sarness is offline   Reply With Quote
vinyl siding patch job BuzzKill General Electrical Discussion 4 04-15-2012 10:12 PM
24 port Cat6 wall mount patch panel zwodubber Structured Wiring 11 04-09-2012 09:44 AM
Patch Jobs JD_ General Electrical Discussion 2 08-15-2011 06:40 AM
Day Two, smoke free on the patch Shockdoc Off Topic 79 06-25-2011 12:17 PM
Grounding a Data Patch Panel Fuelcellpt General Electrical Discussion 12 03-12-2011 08:57 AM
