Old 01-20-2007, 04:05 PM   #1
Default Poor Man's cable cutters.
Low voltage cable manufacturers recommend that cables like Cat5 and Coax be cut with a cutter that will maintain the cable's round profile. These cutters cost at least 50 dollars and up. My poor man's version costs about 4 dollars at WalMart, and are sold in the pet department as dog toe nail trimmers. They work fantastic !
Old 04-03-2007, 02:15 AM   #2
Licensed Pro
Magnettica's Avatar
Rotf
Vince Lombardi
Old 07-06-2007, 02:38 PM   #3
Don't like know it alls
ha ha priceless !!!
Exactly the same cutters that i use and they came from walmart (asda) in the UK.
chrisb271 is offline   Reply With Quote
Old 10-23-2007, 01:58 AM   #4
rbj
IBEW approved? I don't have a picture of my hand, but they are the most economical wire strippers and the fingernails regrow themselves.
rbj is offline   Reply With Quote
Old 10-23-2007, 06:28 AM   #5
"A" inside wireman
randomkiller's Avatar
I will say, I find a pair of the minature Klein (D275-5) flush cutters are @$10 and do the exact same job as the $70 medical nippers for ingrown toe nails.
As for my curved jaw cable cutters, one of the guys in my shop picked up 9 pair in Home Depot on close out for like $6. We all do the same, when we see something at a good price, we buy all they have and bring them in. Last was Klein (J213-9NE) 9" Journeyman linemans for $19 (reg $35), clearance from Sears.
"One Nation Under God"
Old 10-23-2007, 05:45 PM   #6
Low-Vo
Never saw the point for cat5 since if crimping or punching you are removing the jacket and stripping back from the end.
With coax I still use my yellow handled wire strippers, but I usually have to straighten the core out
GregS is offline   Reply With Quote
Old 10-23-2007, 05:49 PM   #7
"A" inside wireman
I see the new Klein multi pliers now have curved jaws.
Old 06-13-2008, 05:38 PM   #8
electrical artist
lutronharvey82's Avatar
in a pinch just use your teeth.
lutronharvey82 is offline   Reply With Quote
Old 06-13-2008, 06:18 PM   #9
what if you ain't got none
comp is offline   Reply With Quote
Old 06-13-2008, 07:55 PM   #10
"A" inside wireman
If you did they won't last long biting through cabling.
Old 06-13-2008, 09:58 PM   #11
IBEW Local 661 JW
Rong's Avatar
Hey I gots teeth..I keep them home in a jar!!!!!!!!! True!
I too am bilingual :
I speak bad English and worser English.
Rong is offline   Reply With Quote
Old 06-14-2008, 09:25 PM   #12
electricalperson's Avatar
i think those fancy cable cutters are a bunch of junk. i use my linesmen to cut. you always strip back the outer covering and punch them down right?
electricalperson is online now   Reply With Quote
Old 06-15-2008, 01:15 AM   #13
Hawkeye_Pierce's Avatar
Soooooo . .. Where do I get that fancy sticker?
_________________
Our failures are known, our successes are not.
Hawkeye_Pierce is offline   Reply With Quote
Old 06-15-2008, 08:09 AM   #14
IBEW Local 661 JW
Rong's Avatar
Maybe at the hall??
Old 06-15-2008, 11:35 PM   #15
Low voltage cable manufacturers recommend that cables like Cat5 and Coax be cut with a cutter that will maintain the cable's round profile. Low voltage cable manufacturers recommend that cables like Cat5 and Coax be cut with a cutter that will maintain the cable's round profile.
I kinda know where that came from only it's not UTP like CAT5 or RG type coax. Really doesn't make much difference what you cut those with. They are talking about hard cable, the solid aluminum sheathed coax that cable companies use. You don't want to squish the end too much out of round although that does get cut back also when you prep it for a connector. There are several manufacturers like Klein who make cutters for that.
-Hal
hbiss is offline   Reply With Quote
Old 06-16-2008, 11:35 PM   #16
Originally Posted by Rong View Post
Maybe at the hall??
Dairy Queen.
scrooge is offline   Reply With Quote
Old 06-17-2008, 05:59 AM   #17
"A" inside wireman
Originally Posted by scrooge View Post
Dairy Queen.
Wow, the local by you has a DQ in the building, that's awesome. I guess McDonalds wouldn't go for a small venue.
Old 06-17-2008, 07:56 PM   #18
For every connector that you put on like this, you are causing a cable technician a hell of a time locating an intermittent problem. Proper preparation of the cable is a must. Trust me, I deal with it everyday.
www.carolinasoutdoor.com
carolinasoutdoor is offline   Reply With Quote
Old 06-17-2008, 08:40 PM   #19
I hope someone isn't suggesting that coax cable be stripped with that that thing.
-Hal
Old 06-18-2008, 11:34 PM   #20
Default Missed.
Dairy Queen.
ratchet cable cutters paul d. Tools, Equipment and New Products 10 09-21-2008 12:20 PM
Anyone try Greenlee 9.5in. Side Cutters ? BP_redbear Tools, Equipment and New Products 17 08-01-2008 01:13 PM
Poor man's line tool bucket. MDShunk Linework 20 03-21-2008 02:48 PM
Poor advice / poor products Trimix-leccy UK Electrical Forum 9 01-06-2008 11:18 AM
Poor man's cable unreeler MDShunk Tools, Equipment and New Products 19 03-25-2007 11:39 AM
