Old 07-28-2009, 08:55 AM   #1
Default Small cover for pulled throw thermostat wire, thermostat to be installed in fall
Have a client where I pulled a thermostat wire through the sheetrock.
Client does not want to install thermostat now as he is thinking about upgrading the boiler controller.
Looking for a small cover/plug that will hold the thermostat wire until a later date. I realize I could put a one gang low voltage ring there and a decora blank cover but client is most likely looking at using a small tekmar thermostat which is smaller then single gang..
Does anyone make a small round plug (paintable) that could be used in this situation?
personalt is offline   Reply With Quote
Old 07-28-2009, 10:34 AM   #2
Why not just use a single gang blank and attach it to the wall with screws and anchors? That way he will only have to patch at most the two anchor holes if the new stat doesn't cover.
-Hal
hbiss is offline   Reply With Quote
Old 07-28-2009, 11:08 AM   #3
rexowner's Avatar
Don't know how big your thermostat is, but I believe
that these round cover plates are smaller than single gang.
I think holes are required 2-3/8" apart which presumably
is hidable under the thermosat, vs. holes ~4" apart
for a regular single gang blank plate
Only place I could find them online at the moment:
http://www.twacomm.com/catalog/model...3D5DEC1A2F645E
but they are available elsewhere.
Or look for a plastic rivet to screw into the wall.
rexowner is offline   Reply With Quote
Old 07-28-2009, 11:24 AM   #4
drsparky's Avatar
Hang a photo over the hole and get on with life.
"Pay attention son, this is for your own good." - Foghorn Leghorn
Old 07-28-2009, 06:28 PM   #5
Another idea is a KO plug of a size to fit your round hole. Use a little caulking to hold it in and paint to match.
-Hal
Old 07-28-2009, 06:31 PM   #6
When the phone company still prewired homes, they'd just coil a bunch up and staple the loop to the stud loosely. Drill a little hole and fish it out when you need it.
Sounds like yours might be tailed out of the drywall already? I like the knockout idea. You could also use a METAL wall box without plaster ears, since they are quite small. Even the smallest thermostats should cover them.
-Marc, ABC, XYZ, PhD, 1-2-3
Old 07-28-2009, 10:51 PM   #7
This sounds like good use for one of those round door bell button inserts.
You could connect the wires to the screw terminals to keep them from falling down inside the wall.
Maybe even make it into a conversation piece by hanging a little sign over it that says “Press To Launch” or some such thing.
Old 07-28-2009, 10:58 PM   #8
Speedy Petey's Avatar
If you do go the box route cut it in horizontal. Most digital t-stats have a horizontal configuration.
Old 07-29-2009, 02:29 AM   #9
Master RAT!!!
Shado's Avatar
Good idea!!! I will have to remember this next time I run into similar issue.
- Dave ........
"Beware of the Rat....he has no Master...he works how & where he wants...."
Shado is offline   Reply With Quote
Old 08-02-2009, 11:02 PM   #10
I would attach a blank cover plate with only the top screw. One screw will hold the plate and the small coil of wire behind it just fine. When the thermostat comes in, reuse that anchor and screw.
SideWorker is offline   Reply With Quote
thermostat wiring sourmash Residential Electrical Forum 1 07-18-2009 05:44 PM
3 phase thermostat jjdrees General Electrical Discussion 3 11-18-2008 07:20 PM
Advice please: Programmable Room Thermostat dipsb_13 UK Electrical Forum 5 02-24-2008 06:10 PM
Connect Honeywell RTH230B thermostat one pole 240 gilamor General Electrical Discussion 3 07-05-2007 02:11 PM
Help to set up thermostat on gas heater jayendra General Electrical Discussion 5 06-22-2007 09:39 AM
