Small project with underground - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 4 Post By splatz
  • 1 Post By LawnGuyLandSparky
  • 1 Post By emtnut
  • 1 Post By splatz
Old 01-24-2017, 03:14 PM   #1
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,894
Default Small project with underground
We have a small project that is about 250' total and has about 30' or so of underground out to a portable classroom.
They will be using cloud based curriculum. Two classrooms, each side with 14 students using Surface Pro devices via WiFi, plugged in will be a printer, one Prometheus board, three student workstations, instructor desk.
I wanted to do something a bit different to distinguish us from others by installing fiber from the server room out to a switch in one side of the portable and then cat 5 or cat 6 ( is cat 6 really necessary). I might be overly concerned about running underground with data cable, having to purchase 300' of underground cable due to a short piece running underground.
I see that fiber media converters are only about $100 or so for the server room side and 300' of outdoor SM with terminated ends is about $120.
Price of a Cisco 2960 looks to be about $150
Cat5E underground or regular is very cheap.
Question:
Is fiber just as plug and play as ethernet?
I dont see a massive difference in pricing.
Old 01-24-2017, 03:40 PM   #2
Rewards Points: 3,066
You should definitely run fiber underground. The benefit of not having to surge protect it tips the balance on the gear.
Media converters are not usually the thing for this, you'll want SFPs for the switches, no big deal.
The best thing to install is singlemode but that's less forgiving than multimode, if you haven't worked with it. Neither is real forgiving compared to copper.
NICE SIG WISE ASS
"The thought is in the question, the information is in the answer." -Nehemiah Hawkins
Suncoast Power (01-24-2017)
Old 01-24-2017, 06:30 PM   #3
Semper Fidelis
NICE SIG WISE ASS
I have to take a regular ethernet port from the main server rack and convert it to fiber, the switch I have in mind for the classroom side will take fiber.
Im only supplying and connecting, the IT guy is doing the smart work. He wont throw cables.
Old 01-24-2017, 09:36 PM   #4
Rewards Points: 3,530
I like the fiber idea. Besides, isn't 250' of Cat5 kinda pushing it anyway?
The Following User Says Thank You to LawnGuyLandSparky For This Useful Post:
MechanicalDVR (01-25-2017)
Old 01-25-2017, 06:37 AM   #5
You can go right up to the distance limit without any problems.
You can usually go a LITTLE further with plenum rated cable.
Old 01-25-2017, 07:16 AM   #6
Semper Fidelis
The "limit" at this point is unknown. I do know that they are planning a second portable and will require cameras in the near future.
Old 01-25-2017, 07:19 AM   #7
I meant the 328' ethernet / UTP distance limit.
Old 01-25-2017, 12:03 PM   #8
Semper Fidelis
Splatz,
You seem to have some expertise.
We will be going from copper to fiber and back.
Do you have a preference of any media adaptors for FC SM fiber and an 18 port switch for the classroom side?
Will Cisco 200 series work such as SLM2016T-NA?
John
Old 01-25-2017, 01:02 PM   #9
Band Member
emtnut's Avatar
Rewards Points: 8,296
You could offer them the option to leave the existing switch, and just install a media converter ... save them a few bucks.
Splatz,
John
I'd talk to the IT guy, and or replace with the same brand they are using if you go this way.
Cisco is $$$ !!
all wiyht, rho sritched mg kegtops awound
Old 01-25-2017, 03:13 PM   #10
Cisco is $$$ !!
The nice thing about giving them a media adapter is you don't have to make it work with their gear to prove your part of the install is OK and punch out.
Cisco's flagship line is really overpriced. They also have a small business line that came from when they bought Linksys, it's not awful but I don't like it.
Old 01-25-2017, 04:12 PM   #11
I like Allied Telesis for a good reasonable priced media adapter, not hard to use.
I'd buy a media adapter with LC ends so you have the same combination at both ends - you will only find SFPs for today's switches with LC connections. If you use an FC terminated cable you'll have to use an FC-LC patch cord.
That Cisco you picked out is not bad and it has the magic "C" word stamped on it.
Old 03-08-2017, 09:11 AM   #12
Rewards Points: 14
Splatz knows what he's talking about, fiber underground runs are the best call for in between portables, especially if they add one further out in the future, you already have the equipment in place rather than later having to quote fiber interface if the run is more than 350'
HitDaLights is offline   Reply With Quote
Old 03-17-2017, 05:40 PM   #13
Rewards Points: 531
I disagree. Multimode is much more forgiving. It's ideal for short runs like this. Singlemode is long runs and huge bandwidth. Multimode is also more economical. The media converters will have max bandwidth and distance in the specs.
Fiber Optic Review:
The larger diameter- think of it as a big tunnel- lets the light take different paths, creating multiple rays, or modes (hence multi-mode). The light bounces around more, which means the connectors and splices for multimode are more forgiving than for singlemode, but the bouncing causes dispersion and fidelity loss. On the other hand, singlemode has a much smaller diameter core, giving the light one straight path, or mode, through the cable. Because of this, singlemode offers higher throughput and longer distance, but the light equipment and connectors are much more finely-tuned. Which, of course, means singlemode is much more expensive.
Plug and play. Not necessarily. Dust and dirt can get on the connector ends. No matter how careful or clean you are. Always a chance of a damage connector than can only be seen with a scope. The trouble is there is no way of knowing if the install is good without a fiber microscope and optical loss test set. Just because it works is not a good standard. As the loss is expected to degrade with time.
Your looking at a few thousand in testing and cleaning materials to do it right. Testing could be subed out.
Old 03-17-2017, 05:53 PM   #14
I see what you're saying but I'd still go with singlemode. Your thoughts above are how I thought of it when I started installing fiber 20+ years ago, but I think gigabit and certainly 10GB have changed things. (Very few customers I deal with are running 10GB other than within their data centers right now, but who knows what the future holds.)
I still install plenty of multimode, but in most cases in a facility with no legacy fiber to match, I'll recommend singlemode. This run was quite short but who's to say the next one isn't beyond the distance limits for gigabit over multimode?
You could use multimode for the short ones and singlemode for the long ones, but it's nice to have just one type of fiber so all the electronics and patch cords work with everything else, you can move equipment around freely, swap patch cords and components to test, etc. The price of singlemode is really not significant in most jobs, and even the electronics are cheap these days.
active1 likes this.
Hiring Project Manager/Electrical Estimator Everette WA Robin.v Looking To Hire 0 01-06-2017 01:11 PM
Is PVC underground considered a wet location? Canaduh Canadian Electrical Code Forum 10 10-08-2016 03:58 PM
PVC underground kd129 Commercial Electrical Forum 25 06-03-2016 12:14 AM
Canadian Electrical Code 8-104 (8) - underground conductor sizing jjdoerksen Canadian Electrical Code Forum 7 04-19-2016 03:50 PM
Southern Cali- Ontario Project Niguel Electric Looking To Hire 0 01-14-2016 10:19 PM
