Static on the phone line - Electrician Talk - Professional Electrical Contractors Forum
Old 08-04-2010, 08:42 PM   #1
Rewards Points: 268
Default Static on the phone line
We wired a new house for a customer; including the CAT-5e for the phones.
Phone company only supplied one phone line; I installed it on blue & white-blue ckt (white-blue is Tip, blue is Ring).
They are an older couple; still using 2 rotary phones and one cordless from the early 90s.
Their son helped them get set up for wireless internet, which comes in on the phone line.
The problem is that the phone line starts out nice and clear, but once you start talking on the line, the static starts getting worse all the time and then the phone cuts out. It will work after you hang up and try again.
I ran 3 separate runs of CAT-5e out to the demarc point. Each run has 2 phone jacks connected to it. Very simple, basic install.
I have to go back there tomorrow and figure this problem out and I am looking for some advice from smart people.
I plan to make sure the problem still exists, then disconnect one line at a time at the demarc point and see if it is the source of the problem.
Then I will connect all phone lines and disconnect the Internet router and see if that makes any difference.
Could it be a bad phone causing interference with the line?
Have you seen this before?
Thanks,
Rick
subelect is offline   Reply With Quote
Old 08-04-2010, 08:48 PM   #2
Rewards Points: 518
See what happens on a new phone.
crazyboy is offline   Reply With Quote
The Following User Says Thank You to crazyboy For This Useful Post:
subelect (08-05-2010)
Old 08-04-2010, 09:19 PM   #3
DGFVT
John's Avatar
Rewards Points: 168
You need filters on the lines for the telephones.
http://www.smithgear.com/900lcc-50.html
R.E.D.
The Following User Says Thank You to John For This Useful Post:
Old 08-05-2010, 01:16 AM   #4
Rewards Points: 3,855
Man, I sure hope they're using a DSL filter on the data feed. Surely the must be, or the data line would crap out every time you pick up a phone.
Just check over all your terminations an punchdowns carefully. Plug a phone in the NID and see if the problem persists. If it does, it's the telco's problem.
If you happen to have a kick meter, you can sort this out in about 2 minutes, but if you don't, it's going to be a painfully long period of troubleshooting.
Old 08-05-2010, 01:23 AM   #5
I agree with John, you need filters on each phone jack that goes to a tel. together with that, you might try removing the rotary phones from the setup. Some of the older phones had a lighted dial which drew a lot of juice. Now they use LED lights , much more efficient.
There was a ringer equivalence number on the bottom of each phone in the old days of the LOL 70's this number told you how much draw a particular phone took.
If I remember correctly the most you could connect was 6, I think they lowered it to 3 now. The older phones may say something like REN 1.5 or 2.1 on the bottom. Worth a shot anyway.
So the new phones might fix part of the problem but you do need the filters
The Following User Says Thank You to JohnR For This Useful Post:
Old 08-05-2010, 01:26 AM   #6
Exceeding the available REN will normally only make phones not ring or ring weakly, and doesn't normally cause static. You start to think about poor terminations or an open sheath on the pole when you hear about static problems. It's usually pretty easy to get the telco guy to pick another pair coming down the road.
Old 08-05-2010, 02:33 AM   #7
I was thinking about the seeming capacitance of the way it gets louder till it blanks out the phone line.
Throwing something out there, seeing what sticks. I don't know anyone who still has a rotary connected. Don't know what it would do for sure.
Old 08-05-2010, 05:34 AM   #8
Tabihu Juhar
76nemo's Avatar
Rewards Points: 2,000
Marc, what is a "kick" meter, and how does it work?
The Following User Says Thank You to 76nemo For This Useful Post:
jwjrw (08-05-2010)
Old 08-05-2010, 02:43 PM   #9
Morally Bankrupt
Big City Electrician's Avatar
Rewards Points: 250
I've never used filters on DSL and never had a problem.
Big City Electrician is offline   Reply With Quote
Old 08-05-2010, 02:44 PM   #10
Morally Bankrupt
Rewards Points: 250
It measures resistance on the local loop also polarity and voltage I think.
Old 08-05-2010, 06:19 PM   #11
Tabihu Juhar
76nemo's Avatar
It's just a loop impedance tester you're saying????
Old 08-05-2010, 06:31 PM   #12
sparky105's Avatar
I just went through this on my own house.
I nicked the phone line with a drill bit doing a wire pull for a new rec. and didn't see it at the time. few days later wife said that she could use the phone but the static got bad as the call went on. it started me thinking and I remebered drilling the holes in the basement went over the cable route and found the nick in the line. new peice and no more static hope this helps
sparky105 is offline   Reply With Quote
Old 08-05-2010, 06:57 PM   #13
Tabihu Juhar
76nemo's Avatar
Is this "kick" meter focused solely on telco apps, and does it have another name it goes by????? I want to check the documentation and specs on one.
Old 08-05-2010, 11:42 PM   #14
Tempo Sidekick is the most common one. Not just an impedance tester.
Old 08-06-2010, 01:17 AM   #15
Here's the training manual on the kickmeter. http://www.tempo-textron.com/docs/7b...g%20Manual.pdf
It's really not that expensive of an instrument, is in common use, and can really help you out of a jam and make you look like a hero.
Old 08-08-2010, 08:17 AM   #16
Can't Remember
Rewards Points: 946
Threw a bid in on a used one. I have a similar problem to tackle, though not so serious or obvious on a comcast phone system. Just static, doesn't drop out.
Old 08-08-2010, 09:58 AM   #17
frank's Avatar
Had a similar problem once and after spending ages checking old phones compatable with new exchange I discovered a piece of multi cored telephone cable installed years ago. Changed this to the correct solid drawn type and the lines were perfect. Just a thought but then you never know.
Old 08-31-2010, 02:05 AM   #18
rbj
Rewards Points: 79
Default Static
Check for moisture in the cable ends. This will cause static like a conductor in ground.
rbj is offline   Reply With Quote
static converter zrul PLCs, VFDs, Motors and Controls 1 05-17-2010 04:40 PM
RCD, Static Caravans jules58 UK Electrical Forum 7 02-16-2009 07:11 PM
"No phone line" telephone intercoms MF Dagger Structured Wiring 2 03-27-2008 09:42 PM
static noise Bkessler General Electrical Discussion 9 02-05-2008 11:08 PM
How to re-wire my phone line. NickAMonzo General Electrical Discussion 1 06-30-2007 08:31 PM
