Closed Thread
Old 09-11-2009, 07:35 PM   #1
Default Thermostat wiring question.
First just a little background: Years ago I replaced electric baseboard radiators with an oil boiler and hot water baseboard system. All the line voltage wiring was, of course, disconnected from the electric panel and made dead. Thermostat locations stayed the same and we used the pre-existing romex as control wire into the unfinished basement where we connected thermostat wire which we took to the boiler (we also pig-tailed thermostat wire to connect to the new thermostats). So I have a two wire thermostat wire rough-in.
Now I want to install new thermostats that require three wires (Z-Wave thermostats, for remote control) and my question is this: can I use the unused ground wire as the required C wire, a live 24V wire to power the new stat. My concern is it's a "bare" wire but not really as it's inside the romex housing. Any input would be greatly appreciated.
Yail Bloor is offline
Old 09-11-2009, 07:38 PM   #2
-Marc, ABC, XYZ, PhD, 1-2-3
MDShunk is offline
Closed Thread
Small cover for pulled throw thermostat wire, thermostat to be installed in fall personalt Structured Wiring 9 08-02-2009 11:02 PM
thermostat wiring sourmash Residential Electrical Forum 1 07-18-2009 05:44 PM
Hot Tub Wiring Question bender1993 General Electrical Discussion 26 06-06-2009 09:55 PM
THHN Wiring Question holyearth General Electrical Discussion 13 03-09-2009 08:30 PM
Wiring device question 220wire General Electrical Discussion 6 08-28-2008 08:24 AM
