Old 07-16-2007, 04:29 PM   #1
Unhappy wet coax & uhf connections??
does anyone know why my uhf connectors are wet? they have gathered a greenie coloured like matter around them. i discovered this when my freeview box was coming up with a message "no signal". when i investigated more, i found that there was a wet patch UNDER the freeview box and the wet connector. can anyone help?
crazy_campo is offline   Reply With Quote
Old 07-16-2007, 04:42 PM   #2
It happens if the cable gets water in it at any point, since the braid makes a fine wick. It will draw water through it by capillary action. The repair is to replace the water logged cable, and install good Snap-n-Seal type ends on it, and make sure they're made up good and tight outdoors.
I'm an electrician, not a magician.
Old 10-07-2007, 12:07 AM   #3
kbsparky's Avatar
Thumbs down
from your description, I'd say some varmit was peeing on your connection.
kbsparky is online now   Reply With Quote
Old 10-07-2007, 09:13 AM   #4
Wish I was in the water
Greg's Avatar
Compression fittings are a must and if they are outside I still sleeve them with heat shrink.
If you're gonna be stupid, you better be tough.
Old 11-25-2007, 04:57 PM   #5
There is no doubt it is water you might want to look at the outside connection (the one to the drop to the house) if the center conductor looks black and or green or the braid is brittle you have a water issue and the drop needs to be replaced.
Nub917 is offline   Reply With Quote
Old 11-26-2007, 09:25 AM   #6
Wyome
This is somewhat off topic but here goes. We are used to running one or two dual coax out to the dish location, along with a #10 ground wire. Have had problems with the sheath cracking on that stuff. I know it is because of very low temperatures. Is there anything out there rated for the cold? Minus 40 is usually achieved at least once or twice, if not more, here.
Old 12-26-2007, 07:44 PM   #7
I'd recommend tracing the line, perhaps an animal has chewed on it somewhere along the way. If you do find bites I'd look into it further because you wouldn't want that kind of fire hazard running around
Majumamass is offline   Reply With Quote
Old 12-27-2007, 01:43 AM   #8
try comscope cable been installing satellite for 12 years its the only cable that wouldnt crack on me. I have tried them all and serviced all the offshore stuff like what rat shack sells
Old 12-27-2007, 03:38 PM   #9
Cool Wet wire
Could it be condensation?? If this is in a bathoor, laundary or outside wall this could be the problem
You keep doin' what you're doin, you will keep gettin' what you got.
Idaho Abe is offline   Reply With Quote
UK: Variable frequency inverter connections charlietech UK Electrical Forum 5 11-02-2009 02:07 AM
code compliance on buried connections llamedos General Electrical Discussion 2 11-25-2008 02:44 PM
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 07:21 AM
12V Lighting Connections megavolt Lighting Design 11 04-18-2008 06:42 PM
You Just Gotta Tighten Those Connections! brian john Workplace Safety 8 03-20-2007 05:02 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
