Betting on 100% Tie Off - Electrician Talk - Professional Electrical Contractors Forum
Old 01-22-2012, 12:38 PM   #1
petek57's Avatar
Rewards Points: 166
Default Betting on 100% Tie Off
Ok, so my coworker and I have a friendly wager regarding the OSHA tie off rules. If I win he has to put a bumper sticker on his car of his least favorite politician.
When climbing a 20' scaffold using the provided scaffold ladder , are you required to tie off to the rungs as you go up. Double lanyard would allow you to be 100% tied off as you go.
Now if you were able to provide me with reference to the rule...I would greatly appreciate it!!
petek57 is offline   Reply With Quote
Old 01-22-2012, 12:40 PM   #2
BBQ
Salty Member
BBQ's Avatar
No tie off needed if the staging has all the safety railings in place.
nitro71 (01-23-2012)
Old 01-22-2012, 12:46 PM   #3
petek57's Avatar
Rewards Points: 166
Default Scaffolding ladder is affixed to scaffold
No railings...just rungs. You climb 10' and slip you are flat on the ground
Old 01-22-2012, 12:54 PM   #4
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,302
Good question.
jza is offline   Reply With Quote
Old 01-22-2012, 01:56 PM   #5
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Fall protection or fall arrest systems -- Each employee more than 10 feet above a lower level shall be protected from falls by guardrails or a fall arrest system, except those on single-point and two-point adjustable suspension scaffolds. Each employee on a single-point and two-point adjustable suspended scaffold shall be protected by both a personal fall arrest system and a guardrail. 1926.451(g)(1)
tom-in-newalla (02-16-2012)
Old 01-22-2012, 08:51 PM   #6
NacBooster29's Avatar
Rewards Points: 1,018
This is a billboard my company services. The owners require 100% tie off when on the cat walk, but getting there is not so easy..usually we have a lift if we must reach above working height on the cat walk. But not for this particular call. This kind of goes hand in hand with a previous thread I started, asking if a 2 man crew is appropriate for such work.
Old 01-23-2012, 12:01 AM   #7
s.kelly's Avatar
I am remembering a rule that changes with height, somewhere in the 20' range, but I think it was a site specific, not OSHA. I will try and look later.
Maybe McClary got the ref I was thinking of, but I swear it was around 20' and this was at a powerhouse that was usually no nonsense.
s.kelly is offline   Reply With Quote
Old 01-23-2012, 07:23 AM   #8
Rewards Points: 1,214
Not sure if the ladder on a scaffold is a portable ladder, but if it is, no tie off is required while climbing. OSHA does not require tie-offs on portable ladders, but many site safety programs do.
Old 01-23-2012, 07:35 AM   #9
BBQ
Salty Member
BBQ's Avatar
But not on a ladder.
leland (01-24-2012)
Old 01-24-2012, 07:17 PM   #10
head cheese
electric mike's Avatar
Is it OSHA that requires 3 body points contacting ladders at all times or is that another jobsite legend?
faster horses, younger women, older whiskey, more money
electric mike is offline   Reply With Quote
Old 01-24-2012, 07:40 PM   #11
Rewards Points: 250
You might be thinking of the rule that states if the scaffolding is 3 times as high as it is wide you must tie the scaffolding off to a tie point. Something like that I think.
buddhakii is offline   Reply With Quote
Old 01-24-2012, 08:38 PM   #12
Rewards Points: 2,000
I can't tell from my phone, but that looks like a Lamar board. Their employees are required to have a double lanyard but tie off is not required for the accent. On boards greater than 50', they typically have a vertical safety cable.
Old 01-24-2012, 09:02 PM   #13
It is in fact a Lamar board we service the led displays. Interesting niche work
Old 01-26-2012, 10:03 PM   #14
I took the OSHA 30 class. Twice. and I still cant quote OSHA rules word for word. I really hated that class.
slickvic277 is offline   Reply With Quote
Old 01-26-2012, 10:25 PM   #15
s.kelly's Avatar
Looking, BBQ says not on a scaffold ladder. I think he is right and that the requirement I was thinking of was plant specific rule requiring tie off on a scaffold ladder 20 or greater.
But yes the three times height does sound like where the requirement for outriggers or tie off to structure is required.
Old 02-02-2012, 08:56 AM   #16
LightsOn81's Avatar
Rewards Points: 548
It is OSHA required 3 pt of contact. They will jump your crap on camp lejeune if you are caught otherwise.
If it gets any better, I won't be able to stand it!
LightsOn81 is offline   Reply With Quote
Old 02-03-2012, 10:37 AM   #17
Electrical Janitor
Shazbo inc.'s Avatar
Is the exstention ladder at least tied off to the vertical ladder?
Shazbo inc. is offline   Reply With Quote
Old 02-03-2012, 12:31 PM   #18
It was I was in the process of taking it down. Figured I'd snap a pic. I know the guys here love pics.
Old 03-28-2013, 03:06 PM   #19
Fixed ladders do not fall under the scaffold standard hence scaffolding requirements do not apply. You will find fixed ladders under sub part X of 29 cfr 1910.
Jack-Howland is offline   Reply With Quote
Old 03-28-2013, 03:45 PM   #20
Quick clarification. By "provided scaffold ladder" are you referring to the factory made ladders for tube and coupler scaffolding? Or the end frames of tubular, welded-frame scaffolds frequently called system or framed scaffolding. The latter are only allowed to be used during erecting and dismantling of the scaffolding, according to OSHA. Additionally, does George follow Federal OSHA regulations or have their own agency?
Legion is offline   Reply With Quote
