Further to the address I just posted, before using it remember once you start this there will be no turning back (if you want to ever work in Alberta again). Be very sure you have proof of non compliance and inspection violations that were not enforced.
If your doing this because your working for someone that will take major liberties with the code and you fear for someones safety then you should by all means look into this. If you are just p___ off with your bosses and want to start trouble my advice is quit and move on, there are too many jobs out there to stay where your unhappy. Remember this is still an area with more work then electricians
