Old 04-19-2012, 08:25 AM   #21
BBQ
BBQ's Avatar
Originally Posted by 360max View Post
....we are required to be 100% tied off regardless of lift type, I'd have to see that OSHA standard to believe it. Note, when you are on any lift and even put your foot up on the toe rail, that requires 100% tie off or it is an OSHA violation
Fedearal OSHA treats sissor lifts as staging and just like staging you do not need to be tied off if there are full rails.
I do agree with you that if you want to climb the rails tie off is needed.
BBQ is online now   Reply With Quote
Old 04-19-2012, 08:26 AM   #22
BBQ
BBQ's Avatar
Originally Posted by chicken steve View Post
Osha fined a worker here , 'manlift on concrete no saftey harness'
and other than an on line resource (which many are not privey to, or eshew) there are no local Osha realted courses
bit of a Guaqmire imho......~CS~
Of course they could fight the judgment and win, it happens often.
Old 04-19-2012, 09:47 AM   #23
Boomer's Avatar
I've had those scenarios run through my grape from time to time as well...falling while tied off to lift and having it tip on top of me. But, when you think about it, you'd be falling straight down the side of the lift. The weight transfer would be totally vertical, limiting the possibility of the lift to be pulled down side-ways.
Good post though, even though I can't find the OSHA regulation that says you have to be tied off on the lift, we are told it is required any time you step foot on the lift.
Boomer is offline   Reply With Quote
Old 04-19-2012, 09:53 AM   #24
BBQ
BBQ's Avatar
Certainly some areas, bussnesses etc require tie off but fed OSHA does not.
The following is from OSHA
In regards to your specific question, when working from an elevated scissors lift (ANSI A92.6 series), a worker need only be protected from falling by a properly designed and maintained guardrail system. However, if the guardrail system is less than adequate, or the worker leaves the safety of the work platform, an additional fall protection device would be required. The general scaffolding fall protection provision found in 1926.451(g)(1)(vii) reads in part, "[f]or all scaffolds not otherwise specified in this section, each employee shall be protected by the use of personal fall arrest systems or guardrails systems."
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=22611
Old 04-19-2012, 07:23 PM   #25
While the OSHA information is pretty handy, it doesn't apply here(Canadian). Also, regardless of what the Canada- or Alberta-wide safety protocols are(and I couldn't tell you what they are off the top of my head), it is a rule for the site. That being said, while a safety guy may nag you about it from time to time, they don't actually do anything about it. Same goes for my boss.
However, I'm interested to hear if you guys use lanyards while on these things, and if you actually tie off to them.
CanadianBrad is offline   Reply With Quote
Old 04-19-2012, 07:42 PM   #26
angryceltic's Avatar
Manufacture states that if there is a tie off point it is to be used. This covers their liability. The tie off is fall prevention to where it's a leash to keep u in the bucket/ basket. Does not matter the style of lift.
The gc on this site has a mandatory tie off rule on anything over six feet. On the staging for the masons there is fall arrest protection as well. My employer has the same rules. Anything over 6 feet.
angryceltic is offline   Reply With Quote
The Following User Says Thank You to angryceltic For This Useful Post:
s.kelly (04-20-2012)
Old 04-26-2012, 09:42 PM   #27
Dhfisher's Avatar
Sometimes things that OSHA requires makes no sense, the plant I worked at required a tie off above 6ft. The " monkey tail" was 10ft long, the idea is that the tail consists of material pleated together with thread that in case of a fall rips out and slows down the speed of the fall before reaching the end of the tail, what good is the tie off if it's longer than the fall and the rip stop is not even into play yet? We get back to the question of liability at this point, if we are using the required equipment the liability falls not in our lap, the Co. Is clear, OSHA is happy, all Edicts have been followed, common sense is lacking, but that's ok, all edicts have been followed. It is up to us to use common sense to protect ourselves also, not just our employer. I will absolutely not do anything that would jeopardize my well being, although I dislike the safety harness if I am off the ground at a height I will wear it, same thing goes for other safety apparatus if common sense tells me to wear it I shall. Too often we bring on these regulations by not using common sense, then big bro. Steps in and is willing to protect us from ourselves. As Pogo said " I have met the enemy, he is us." well this is the end of my " rant" Keep Safe.
Dhfisher is offline   Reply With Quote
Old 04-26-2012, 10:42 PM   #28
acebradley's Avatar
My understanding was always that if the manufacturer of the lift requires it (tie-off) in the operating manual, then it is required by OSHA. OSHA requires every person that uses the equipment to read the manual, be trained, and be familiar with the operating instructions contain therein.
acebradley is offline   Reply With Quote
Old 04-27-2012, 04:47 AM   #29
BBQ
BBQ's Avatar
Actually using too long a lanyard is a violation in it self.
Old 04-27-2012, 04:52 AM   #30
BBQ
BBQ's Avatar
Again, this is not fed OSHA policy, you certainly may have been told that but what I posted above is a official fed OSHA interpretation
It does in fact matter what kind of lift, scissor lifts are mobile scaffolds.
Old 04-27-2012, 05:18 AM   #31
1,000,000th Poster
Big John's Avatar
Sometimes things that OSHA requires makes no sense, the plant I worked at required a tie off above 6ft. The " monkey tail" was 10ft long, the idea is that the tail consists of material pleated together with thread that in case of a fall rips out and slows down the speed of the fall before reaching the end of the tail, what good is the tie off if it's longer than the fall and the rip stop is not even into play yet?....
The problem there isn't OSHA, it's just another case of a half-assed safety department.
This is an OSHA interpretation
that answers a lot of the common questions about work from ladders, and fall arrest when working at low heights.
Long story short: OSHA doesn't require fall protection on portable ladders, and if fall protection is required, but you can still hit the ground while wearing it, it is definitely an OSHA violation.
-John
Big John is online now   Reply With Quote
BBQ (04-27-2012)
Old 04-27-2012, 05:21 AM   #32
BBQ
BBQ's Avatar
We often complain that there is no way to get official NEC interpretations but with OSHA it is usally as easy as a quick search of their site.
Old 04-27-2012, 05:24 AM   #33
1,000,000th Poster
Big John's Avatar
How awesome would it be if the NFPA started giving official interpretations? It makes a hell of a lot of sense: What good is a rule nobody understands?
-John
Old 04-27-2012, 08:05 AM   #34
This amp goes to 11
We have OSHA into our GE facility every year for two weeks to do safety inspections. "DIRECTLY" asked an OSHA official if tie off is required in scissor lifts and been told NO. As long as there is railing and toe lip there is no OSHA requirement to tie off. If you step on the rails then tie-off is required. Which is great because some of the safety requirements we have at this facility are crazy. Have you ever read the OSHA requirement for ladder safety? By their standards you can't even go up the ladder to tie off. 3 points of contact at all times, no carrying tools, and when and if you get to the top of the ladder you have to work with one hand to maintain 3 points of contact!!
TimChaput69 is offline   Reply With Quote
Old 05-20-2012, 10:10 PM   #35
MaxFuse's Avatar
We also are required to be 100% tied off on scizzor lifts over 6 ft.
Their argument was the manufacturers supplied the lifts with attachment loops, therefore, they were designed to be used per manufacturer's suggested operating procedures.
Sounds like a bunch of bull***t to me, just another way to point the finger at someone else.
My question is why the heck are the point of attachment so low? They aren't this way on a boom lift. When you turn around the lanyard wraps around your ankles, doesnt seem too safe to me.
But really, what do they care, they aren't going to be wearing them.
Kind of like our congress and the rules they force upon us that don't apply to them.
MaxFuse is offline   Reply With Quote
Old 05-20-2012, 10:25 PM   #36
MaxFuse's Avatar
That three point contact is a joke.
1. How many men does it take to mount one stick of emt on a 8-10 ft flat ceiling with 1 hole straps.
(Takes 2 men to mount one 1900 box ?)
2. Can you even get that many ladders that close together?
3. Who is going to pay the added cost for this insanity?
Certainly not the Bats***t crazy rule makers.
Old 05-20-2012, 10:40 PM   #37
1,000,000th Poster
Big John's Avatar
Originally Posted by MaxFuse View Post
That three point contact is a joke....
Honestly, I think so, too. And I have never seen the OSHA reg that actually requires it.
-John
Old 05-20-2012, 10:42 PM   #38
Electron Flow Consultant
sparky970's Avatar
Originally Posted by Dhfisher;[URL="tel:699640"
699640[/url]]Sometimes things that OSHA requires makes no sense, the plant I worked at required a tie off above 6ft. The " monkey tail" was 10ft long, the idea is that the tail consists of material pleated together with thread that in case of a fall rips out and slows down the speed of the fall before reaching the end of the tail, what good is the tie off if it's longer than the fall and the rip stop is not even into play yet? We get back to the question of liability at this point, if we are using the required equipment the liability falls not in our lap, the Co. Is clear, OSHA is happy, all Edicts have been followed, common sense is lacking, but that's ok, all edicts have been followed. It is up to us to use common sense to protect ourselves also, not just our employer. I will absolutely not do anything that would jeopardize my well being, although I dislike the safety harness if I am off the ground at a height I will wear it, same thing goes for other safety apparatus if common sense tells me to wear it I shall. Too often we bring on these regulations by not using common sense, then big bro. Steps in and is willing to protect us from ourselves. As Pogo said " I have met the enemy, he is us." well this is the end of my " rant" Keep Safe.
That's where you would use a yo-yo. You need to use common sense if your fall arrest device won't stop you before you hit the ground, then you need to use other methods, Remember you have fall restraint and fall arrest systems.
Old 05-21-2012, 11:27 PM   #39
"Mainstreet"
Wireman191's Avatar
Not on scissor lifts. When we are in a snorkel lift we always tie off.
If I'm going to be leaning over the handrail I will put on a harness and tie off. I really think I would rather take my chances of the lift toppling over on me vs a free fall. I'm sure it could possibly happen, but were probably talking 1 in a million chance.
I bet your lift tie off point is 100xs better then the anchors your putting in the concrete celling to tie off to.
Work like you don't need the money
Wireman191 is offline   Reply With Quote
Old 05-21-2012, 11:30 PM   #40
"Mainstreet"
Wireman191's Avatar
You use a yo-yo then, And the yo-yo does not hook to a lanyard, It hooks directly to the ring on your harness.
Safety Toe Work Boots PsiMan84 General Electrical Discussion 20 03-13-2011 07:16 PM
Safety glasses : They work! 480sparky Workplace Safety 25 11-22-2010 10:51 PM
Elevated down lighting , help please Shockdoc Lighting Design 4 09-30-2010 06:17 PM
Electrical safety at work JackClay Commercial Electrical Forum 5 09-23-2010 10:55 AM
