Old 08-23-2008, 06:04 AM   #1
Default fish tape
recently we had 15 yr. electrician push fish tape(steel) into a 277V lighting panel. he was 100% sure it was going to a j-box in corridor out side elec. rm. WRONG!!! FLASH!! BOOM!! lucky nobody hurt. had fiberglass fishtape AND blow/vac close by. comments
Old 08-23-2008, 09:02 AM   #2
Wyome
Way back, when I was a first year apprentice, one of the journeymen on the job pushed a steel fishtape into a hot panel with another apprentice standing there. Huge explosion, everything went dark. No one was hurt. After power was restored the electrical superintendent showed up and fired the journeyman on the spot.
Old 08-23-2008, 11:10 AM   #3
Thank goodness no one was hurt and live and learn hopfully.
Old 08-23-2008, 11:54 AM   #4
Seen your member
I did the same thing years ago when I was an itty-bitty 'lectershun. Only I managed to push a steel tape into an energized 300kVa transformer. Not only did I experinece my first Big Blue Zot, but the entire buildings electrical went off for a split second (lights blinked off, all computers rebooted, etc).
Mysteriously, two weeks later, that transformer's windings went bad.......
Old 08-23-2008, 01:25 PM   #5
Licensed Journeyman
nolabama's Avatar
i own the only nylon fish tape in my company ( shop is a very ratty shop, whatcha gonna do?) i purchased it after two seperate incidents with a disney foreman we had - thank god he's gone - hopefully not pretending to be an electrician eleswhere - i refuse to do dumb things because im suronded (sic) by the stupids
Old 09-24-2008, 11:48 AM   #6
IBEW Local 970 Member
sparky970's Avatar
If your not 100% sure where the other end of the conduit stops, use a vacuum and verify there is suction on the other end. I alway tape the leader of my fiberglass fish tape and make sure someone is on the other end to catch it, especially in a hot panel.
Old 09-24-2008, 05:14 PM   #7
The vacuum suggestion is a great tip! I've never heard of such a thing.
AWKrueger is offline   Reply With Quote
Old 09-24-2008, 09:14 PM   #8
blowing/sucking lines with a vac is much more efficient anyhow. i always have one on a job.
steve134 is offline   Reply With Quote
Old 09-25-2008, 01:07 AM   #9
"Euro" electrician
This part if you dare get a small air horn and blow it in the conduit where ya want to fishtapped in and someone on that end can able tell which conduit as long that person don't stand too close to the conduit opening otherwise this reaction will be like this >>
Merci,Marc
Old 09-25-2008, 01:26 AM   #10
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
I would say if you dont know where the other end goes, you should vac it. Blowing it could lead to a bunch of water in a live panel.
~Matt
Old 09-25-2008, 01:55 AM   #11
Bkessler's Avatar
When the conduit is metal and you blow up a fish tape it is scarry as hell, I have never heard of anyone getting shocked from it though l suspect some one out there knows someone who slid a metal fishtape through an underground pvc and got blasted.
When ls lunch
Old 10-04-2008, 11:11 PM   #12
Merci,Marc
I have an old Sonalert taped to a 9V battery in my toolbox. I tape it over the end of an unknown conduit and plug the battery in. Then I can go to the other unknown conduit ends and listen for the beeps.
grich is offline   Reply With Quote
Old 10-05-2008, 05:48 AM   #13
Got little easy toy ya can make yourself GRICH !! ,think about utra sound transmitter most security sensors have a ultra sound transmitter/reciever or a electronic bug plug we use in our homes . its a ultra sound transmitter sends out a 40,000 cycle wave at that freq ,now we made one 3 years ago for laughs .it works like this you cant find a conduit so take the transmitter and hang it directly over the pipes or pipe you are trying to find then you take the receiver to the panel or panels and wa la it works great it works thur water better than a clean conduit because water is a better conductor of sound waves .i built one and my boss flipped out , but in the real world of our work its only for times when your in a jam not to be used everyday , its so easy to make one its a joke and when i brought it to work they were laughing , but when it worked everyone shut up and had that look like what the f---. it works so good it will go miles in a pipe and can pin point down any conduit lost ya cant find in seconds . it saves pushing a tape in and your not going to get zapped safety number one .take care best to ya
Last edited by nick; 10-05-2008 at 06:11 AM. Reason: cant spel can write but i can do electrical work
Old 10-05-2008, 07:23 AM   #14
Tuckahoe Sparkplug's Avatar
Really the only way to go on a long pull, like parking lot pole lights, for instance.
Tuckahoe Sparkplug is offline   Reply With Quote
true tape problems nick General Electrical Discussion 13 02-07-2009 10:50 AM
colored tape question. k2x NEC Code Forum 15 09-14-2008 07:39 PM
Fish out of water here Appraiser Alisa Introductions 2 07-15-2008 04:36 PM
save a fish calimurray General Electrical Discussion 2 05-11-2007 05:00 PM
Steel fish tapes and hot panels. MDShunk Workplace Safety 13 04-07-2007 12:48 PM
