Old 04-23-2009, 10:02 PM   #41
Seen your member
Originally Posted by mattsilkwood View Post
you shouldnt be ashamed at all. standing on the top rung is a bad habit of mine
All of them? All the time?
Old 05-03-2009, 03:30 PM   #42
Professional Nit Picker
I have to confess-
I have done the pallet on the fork lift thing like in post #36
There was a time in my career I lived and worked by the motto:
Do WHATEVER it takes to make it happen! I worked ( and lived) stupid.
It was like every day was my last and I didn't care
Now years later I'm much smarter and happier then I've ever been!
Of course I have bad knees,and 2 ankles that not worth a dam to remind me of my past.
Old 05-03-2009, 09:28 PM   #43
NO high voltage here
Old 05-04-2009, 06:47 AM   #44
That's simply incredible! All of the posts and pics. I've seen many of these over the years but many are new to me. I think OSHA should cure the unemployment problem by hiring a few thousand inspectors, and give them the power to arrest the clowns that do things like this. I've always felt that stupidity should be illegal, or at least painful!
www.faultlocating.com
Faultfinder1 is offline   Reply With Quote
Old 05-04-2009, 03:50 PM   #45
Originally Posted by mikeh32 View Post
Are those two ladders on a couple of saw horses to get a couple more feet out of them?
Jeff000 is offline   Reply With Quote
Old 05-16-2009, 06:10 PM   #46
How 'bout this one?
To be honest, I wouldn't mind going up and then falling off of that one, looks like a nice slide into the snow. You can see by how far he is leaning forward that it really isn't all that steep, I've walked up hills like that.
EDITED TO CLARIFY: I wouldn't WORK like that, I'm just talking about weekend fun
1900 is offline   Reply With Quote
Old 05-16-2009, 07:04 PM   #47
anything over 4ft requires a harness. climb up and tie off, best solution
sparkyboys is offline   Reply With Quote
Old 05-16-2009, 08:21 PM   #48
What law is that?
I've heard 7 feet, but I have never seen that enforced other than once at the powerhouse and with a 14' stepladder.
Old 05-16-2009, 09:37 PM   #49
Originally Posted by 1900 View Post
What law is that?
local one. we can make it six inches if you would like.
but anyways, if you do not feel safe wear a harness and tie off. you are supposed to wear one as soon as you enter a scissor lift and boomlift.
always safety first.
Old 05-16-2009, 09:54 PM   #50
local one.
Oh, cause when you outright say "anything over 4ft requires a harness." it makes it sounds like it's a law that the person you are talking to has to follow as well. Just like when you said "you are supposed to wear one as soon as you enter a scissor lift" you made it sound like we all are supposed to abide by that rule, when in reality it's not true by OSHA or any law local to me.
Old 05-16-2009, 10:34 PM   #51
If I am not mistaken the OSHA reg is 6 feet from your feet to the ground you must be in a harness and secured. Includes scissor lifts and bucket trucks.
Old 05-16-2009, 11:25 PM   #52
point proven. thanks faultfinder1.
Old 05-16-2009, 11:29 PM   #53
Proven by what?
Old 05-16-2009, 11:32 PM   #54
Proven by what?
that a haness is required over 4 ft. oh my bad, 1.8 meters or 6 ft.
osha.gov fall protection
read it
The OSHA rule clarifies what an employer must do to provide fall protection for employees, such as identifying and evaluating fall hazards and providing specific training. Requirements to provide fall protection for workers on scaffolds and ladders and for workers engaged in steel erection of buildings arc covered in other subparts of OSHA regulations.
The rule identifies areas or activities where fall protection is needed. These include, but are not limited to, ramps, runways, and other walkways; excavations; hoist areas; holes; formwork and reinforcing steel; leading edge work; unprotected sides and edges; overhand bricklaying and related work; roofing work; precast concrete erection; wall openings; residential construction; and other walking/working surfaces. The rule sets a uniform threshold height of 6 feet (1.8 meters), thereby providing consistent protection. This means that construction employers must protect their employees from fall hazards and falling objects whenever an affected employee is 6 feet (1.8 meters) or more above a lower level. Protection must also be provided for construction workers who are exposed to the hazard of falling into dangerous equipment.
Under the new standard, employers will be able to select fall protection measures compatible with the type of work being performed. Fall protection generally can be provided through the use of guardrail systems, safety net systems, personal fall arrest systems, positioning device systems, and warning line systems, among others.
fall protection includes harnesses
Old 05-17-2009, 01:00 AM   #55
I knew that OSHA 30 hour certificate would come in handy one day!! LMAO!
Old 05-17-2009, 08:33 AM   #56
But not limited too. Fall protection includes "guardrail systems" which scissor lifts have already installed.
So what point was proven, that you were wrong about the height or that you were wrong about scissor lift requirements?
Old 05-17-2009, 09:05 AM   #57
I realize that it is difficult to determine the "tone" of a message on a discussion board, but you seem to me to be aggressively defending your right to work unsafely. I was going to get my OSHA book out and provide the different regulations for you - but I think that you would still try to argue the point. YES, in bucket trucks (where the bucket comes almost to chest level), and in scissor lifts you are required to wear fall protection. Maybe you should take an OSHA class if the facts and the actual regulations are so important to you.
That's it for me - I use the boards here for better reasons than arguing.
Old 05-17-2009, 10:46 AM   #58
I'm not defending the right to work unsafely, I'm trying to uncover the facts. Having someone make a blanket statement of fact, and then later admit it's just local law, and then later admit that even the height was wrong is not a fact.
If you could actually prove it, then I wouldn't argue it. But that last time someone said "point proven" it was in response to you saying "If I am not mistaken the OSHA reg is...". Your possibly mistaken recollection doesn't seem like strong enough evidence to prove a point, does it?
Can you cite that? I have been told, not only by an OSHA inspector but by numerous insurance inspectors, that in most case you are not required to have a harness on scissor lifts. Boom lifts are a different story, if the hydraulic line breaks the bucket will tip and the worker can slide right out of the bucket, which is why the inspectors, GC's, etc. always push this rule pretty hard.
I took Osha 30.
I'm sorry for opposing you, and forget about me asking for you to cite the regulation, I wouldn't want to hurt your feelings anymore than I already have. Again, I apologize.
Old 05-17-2009, 10:48 AM   #59
To stir the pot a little, how do you properly protect yourself from a fall when changing a light fixture in a small stairwell at Joe Homeowner's house?
Old 05-17-2009, 12:01 PM   #60
its still local law where i am dummy, 4ft. i proved my point above. NOW take it........in the ASS
Ladder safety randomkiller Off Topic 10 05-01-2008 11:28 PM
Some Saftey-First Photos 480sparky Workplace Safety 14 12-13-2007 08:38 PM
Tie down ladder geeyathink Tools, Equipment and New Products 20 09-29-2007 05:59 PM
What a Ladder! JohnJ0906 Workplace Safety 2 06-05-2007 08:37 PM
Ladder Safety! Joe Tedesco General Electrical Discussion 22 03-29-2007 04:56 PM
