Originally Posted by RH1
It's clear you haven't a clue what skin effect is. Skin effect has nothing to do with voltage, it is a function of frequency and it only happens at frequencies above VHF.
There is a different type of skin effect, which is present at all frequencies in an AC system, this is refering to the increase in conductor effective resistance from the eddy currents developed in AC systems, these eddy currents (More apparant in the center of the conductor) are directly related to frequency so the effective resistance of a conductor will increase as frequency increases.
Skin effect from high voltages is a different concept and is accounted for in the design of every high voltage system
