Old 10-17-2009, 07:42 PM   #21
Apprentice
Frasbee's Avatar
Originally Posted by crazymurph View Post
I still do not understand SER in conduit. Is this for temporary power?
Yes.
Philly Carpetbagger
Old 10-17-2009, 07:43 PM   #22
child please.....
NolaTigaBait's Avatar
It's New Orleans, no telling what kind of hack wired the school 20 years ago.
NolaTigaBait is online now   Reply With Quote
Old 10-17-2009, 07:43 PM   #23
child please.....
Originally Posted by Frasbee View Post
Yes.
Nevermind.
Old 10-17-2009, 08:35 PM   #24
I'm calling in OSHA. This is bu@@@@@. Unsafe work pratices at are our expense.
Old 10-17-2009, 10:06 PM   #25
wildleg's Avatar
well, I just hope you learned something. you shouldn't have been in the ditch in the first place. there might have been a really nice current path in the vicinity of the fault (enough to kill you, but not enough to trip the breaker due to earth resistance). you jump in the ditch, you got no place to go but 6 feet under if that is the case, and noone is getting you out in time. please be more careful.
Chuck Norris sleeps with a night light. Not because Chuck Norris is afraid of the dark, but the dark is afraid of Chuck Norris.
Old 10-17-2009, 11:22 PM   #26
Mad Skills
Celtic's Avatar
February 2008 until now...so that's 1 year and 8 months?
There is a reason helpers/apprentices are not allowed to work hot/on temporary. [...may be an IBEW line item]
Count your blessings.
Old 10-18-2009, 09:56 AM   #27
Fredman's Avatar
Yes.
So these temp feeds are buried 3' down?
(I'm learning here...)
Fredman is offline   Reply With Quote
Old 10-18-2009, 11:12 AM   #28
My thoughts exactly
Old 10-18-2009, 11:53 AM   #29
Apprentice
Frasbee's Avatar
People seem so confused by this thread.
Did I use incorrect terminology?
Cables come off utility pole into two panels (disconnects?) outside. The one on the left had to have its' fuses and cables replaced because it burnt up after the PVC was broken open and became damaged fed the first panel on the first floor on one side of the building.
The one on the right, where two of us got shocked, which they used SER cable sent through PVC, fed a panel on the other side of the building.
Both were buried 3' down.
All of this is temporary power.
Philly Carpetbagger
Old 10-18-2009, 11:58 AM   #30
wildleg's Avatar
as bob pointed out, these cables are illegal. article 590 clearly states that unless 590 allows temporary, it must meet other portions of the code. 590 says that branch ckts and feeders "IN" buildings for temporary can be nm, it does not say that nm or se can be used for outside or underground. this is a violation, and I think you found out first hand why.
Old 10-18-2009, 12:10 PM   #31
Apprentice
Frasbee's Avatar
I wonder if that was why they weren't worried about taking pictures.
They kept mentioning about proving they weren't at fault, but they didn't seem interested in showing the GC or taking photos of the damage.
Philly Carpetbagger
Old 10-18-2009, 12:46 PM   #32
No, there were two panels feeding two separate panels on opposite sides of the building.
We knew the pipe feeding the right side was probably damaged. That disconnect was already off. That one was also ran with aluminum cable.
The other still had juice and was powering the left side of the building, but it turns out, the PVC pipe that the SER was fed through, was also damaged, leaving the SER exposed.
I'm less inclined to think I'm a dumba$$ if only because I was under the impression that if electricity found a good path to ground, it would take it, and therefore burn the fuse. Considering it was caked in wet mud for weeks, and we had no problem on that side of the building, I thought it was fine.
One of the electricians was saying that a high enough voltage could be felt outside of the jacket. I'm not sure if that's true, but now I'm really confused. Is that true?
You're lucky you did not become that "path". You would not be here typing.
Old 10-18-2009, 02:41 PM   #33
Apprentice
Frasbee's Avatar
Yes, I was lucky considering I was surrounded by several supposedly more qualified individuals who even provided the bucket of water and cloth to clean off the cable.
I don't know what you guys want from me, I've never tried to hide my ignorance on how electricity works with the amount of questions I've posted on the topic. It's still very much an anomaly to me.
Philly Carpetbagger
Old 10-18-2009, 04:09 PM   #34
Total blow hard.
Rudeboy's Avatar
Don't worry about it. More than likely people here are simply worried about workers safety regardless of level of experience. It sounds like your understanding of electricity may be on even a higher level than the "more qualified individuals" who made the apprentice jump in the ditch. Just because a guy has more field experience than you doesn't make him smarter. in many cases you may find that journeymen and supervisors and foremen and bosses and general contractors and site supervisors and engineers are complete idiots. Don't trust idiots with your life.
Old 10-18-2009, 04:38 PM   #35
Mad Skills
Celtic's Avatar
I don't know what you guys want from me....
Frasbee,
I think we all want you to be able to unlace your own boots every night.
Old 10-18-2009, 04:46 PM   #36
Not Peter D
Bob Badger's Avatar
Originally Posted by Celtic View Post
Frasbee,
The data is a bit old but still
A total of 5,348 workers were electrocuted in 5,180 incidents from 1980 through 1992.
That is more then 2 workers per work day for 12 years.
How old are you Frasbee?
Seriously, be careful
Bob Badger is online now   Reply With Quote
Old 10-18-2009, 04:56 PM   #37
Not Peter D
Bob Badger's Avatar
Some more info to bring it right home to us (electricians)
Old 10-18-2009, 06:13 PM   #38
child please.....
Interesting stats. I fall in the highest rate of deaths bracket. Wheres the plumbers?....I love when a plumber tells me his job is much more important b/c toxic gases can get into a house an kill. How many times have you heard that happening?
Old 10-18-2009, 08:02 PM   #39
Apprentice
Frasbee's Avatar
I'm 23.
Lesson thankfully, learned. I can assure you all that something like this will never happen again. It's kind of amazing since there was still quite a load on those panels with the drywallers and framers still working. And I was wet and covered in mud.
I still don't quite understand it.
But I guess if the power is off, I don't really have to.
Philly Carpetbagger
Old 10-18-2009, 09:40 PM   #40
Total blow hard.
Rudeboy's Avatar
I love when anyone acts like their job is more important. i also like it when someone says that being an electrician is easier than all the other trades.
PVC MC Cable plc noob General Electrical Discussion 41 06-11-2009 05:15 PM
SWA cable use ? marty General Electrical Discussion 9 06-10-2009 06:23 AM
NM cable in EMT outside? Xknob&Tube NEC Code Forum 14 08-14-2008 11:38 PM
Se Cable JO SMYYT General Electrical Discussion 9 05-24-2008 09:15 AM
