Pulling through 14.4kv live - Electrician Talk - Professional Electrical Contractors Forum
Like Tree51Likes
Old 05-17-2017, 08:36 PM   #1
Rewards Points: 24
Default Pulling through 14.4kv live
Hey. I was asked by Fm to pull secondaries through 14.4 kv to 208v xmr live. Anyone done this before? Any safety tips would be nice.
gamer is offline   Reply With Quote
Old 05-17-2017, 08:46 PM   #2
Rewards Points: 1,304
14.4 KV ???
Hummm .,, no way in hell if this is a convetail dry transfomer type .,,
someone did lost the ball on that.
I would just shut the primary source first before you fool around this kind of crap.
there is basically zero margin of error on that kind of voltage level.
I done alot of MV works but ya need proper tools to do this.
Roger, micromind, wildleg and 1 others like this.
Old 05-17-2017, 09:20 PM   #3
Rewards Points: 24
It's a oil insulated type, padmount. He said they would put a blanket over terminals.
Old 05-17-2017, 09:25 PM   #4
NRA Member
backstay's Avatar
Rewards Points: 1,438
Are you qualified to work on the level of voltage? Here in the states, you shouldn't get near that without training. I was asked to vacuum out a live 14.4kV transformer once long ago. I didn't just say no, I pulled the manufacturers manual, and read the procedure to the boss that clearly stated you could not enter the transformer live, couldn't remove panels from the primary compartment live. He was the typical "I know everything " boss that didn't know squat. I raised enough hell that he dropped it. I was worried he would try to BS someone else. At the end of the day, I was willing to go home for good if need be. Everyone on that kind of pull is in danger, not just the guy at the transformer.
backstay is online now   Reply With Quote
gamer (05-17-2017)
Old 05-17-2017, 09:31 PM   #5
Do that company did have some type of training to dealt with that kind of voltage ?
a blanket may do a squat.,, sorry be harsh but 14.4 KV is something ya dont fool around with it.
The Canada safety dept will be instering on your sistuation on that voltage level.
Is that padmount is POCO side or customer owned transfomer ??
if that is on POCO side .,, just stay the heck out of that!!!
glen1971 and circuitman1 like this.
Old 05-17-2017, 10:27 PM   #6
Rewards Points: 24
No Training... not even sure we have a company standard procedure for it thats why I am looking for some info. I think the xmer is POCO, consumer starts after that termination if i recall correctly.
I think there is going to be representative of a sub contractor for POCO on site when we pull in. Pretty sure we need someone from POCO to open it for us.
Old 05-17-2017, 10:38 PM   #7
Ahhh I see.,,
no training on that part.,, I am sure there is something in the safety dept in your country do have some type of guideline to follow.
However the POCO will basically turn that transfomer off or boot it off ( make it safe ) depending on what their plan is.
if that is single transfomer to feed that customer location the chance they will just deengerized it by boot it off or turn the fuse off at the riser one of two. which that is the SOP on the POCO part.
plan ahead with POCO for details and meeting to set up a plan to deal with it.
that one reason why most POCO rather turn the transfomer off in first place due the arc flash is pretty insane at transfomer location. I have see it blasted few time before and I just saw one not too long ago not far where I am standing.
gamer (05-17-2017)
Old 05-17-2017, 11:52 PM   #8
Rewards Points: 2,442
Who is putting "a blanket" over the terminals? If it isn't someone from the Utility, I wouldn't go near it with a 10' pole.. And that might be just long enough..
No training? No procedure for working around live 14.4 kv? Has the FM read or know anything of Z462 or know about Arc Flash? Limits of approach? If it is a pad mount, you'll be underneath the bushings..
Why can't this transformer be shutdown? Secondary feeder replacement? IMO it's too big of a risk that I'm betting no one can justify keeping it energized...
Any job can be done, until something goes sideways, something happens or someone gets hurt.. Then, as you're sitting in a courtroom, you'll be able to see "who told who what was ok to do.." I believe the term you'd be looking for is "hung out to dry" or "guilty as charged your honor"...
Old 05-17-2017, 11:56 PM   #9
Rewards Points: 14,728
Medium voltage feeders MUST be treated with total respect.
They can be only touched when they are cold.
After any work is completed, all elements need to be megged// hi-potted.
Only THEN can you think about re-energizing conductors.
frenchelectrican and glen1971 like this.
Old 05-18-2017, 12:03 AM   #10
Rewards Points: 232
they would either shut it off or i would walk away.like other's have said 14.4 is nothing to mess with. so it's going to inconvience them,i rather do that than go home in a box!i like to see my family when i go home.let us know how it goes!
circuitman1 is offline   Reply With Quote
Old 05-18-2017, 09:03 AM   #11
Rewards Points: 2,397
What's OSHA got to say about that?
Old 05-18-2017, 09:15 AM   #12
Joe.,,
The OP is from Canada so there is a Canadain verison of OSHA so the Dept of Safety and Labour is the one if I recall it correct.
I think their rules is simauir to the OSHA.
Old 05-18-2017, 09:31 AM   #13
Originally Posted by frenchelectrican View Post
Joe.,,
Yeah.....I wasn't sure what youz guyz called it either, but I figured there's gotta be a similar entity up there.
In any case, what are they planning on telling the insurance/bond company if it doesn't work out so well?
Voltages that high will reach out and touch you.
I would drag up first, that's just nutso.
Old 05-18-2017, 10:34 AM   #14
I agree with that Joe.,,
I been wonding about that related to the insurance/bond company and if anything go heckva mess they will be not too thrilled with it.
joebanana likes this.
Old 05-18-2017, 11:08 AM   #15
just the cowboy's Avatar
Rewards Points: 176
Don't do it!!!!
Old 05-18-2017, 11:26 AM   #16
Rewards Points: 1,106
Have the POCO verify it is DEAD & they put & leave their shorting cables on it until you are finished & have cleared the area.
frenchelectrican (05-18-2017)
Old 05-18-2017, 12:32 PM   #17
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 296
Just worked a paramount fault that started as a failed loadbreak: The blast vaporized most of the 1/8" steel divider between high and low sides and the doors where blown almost all the way off. Blankets wouldn't have done chit.
There's absolutely no way I'd agree to pull through a hot transformer.
Old 05-18-2017, 01:06 PM   #18
Rewards Points: 386
Nope. Unless your company has a written procedure on this and everyone involved is properly trained on that procedure, this is exactly the sort of thing the law that allows you to refuse unsafe work is written for. You aren't even allowed to plug buckets into live MCC cubicles at 600V in the mills around here any more.
mitch65 is offline   Reply With Quote
Old 05-18-2017, 01:44 PM   #19
Flying carpet, anyone ?
Old 05-18-2017, 01:49 PM   #20
Rewards Points: 386
Neither Fortis or Atco will allow anyone inside their transformer unless it is safe.
Pulling the plug on Alberta... 99cents Canadian Electrical Code Forum 22 03-11-2017 01:56 PM
Mike holt live ElectricalArtist General Electrical Discussion 0 12-18-2016 03:51 PM
Trick for preventing PVC conduit pulling apart? mike9666 General Electrical Discussion 42 08-02-2016 05:17 PM
