10-01-2009, 04:38 PM
Tips for someone entering the field
Im in school now graduating march 2nd and entering this field ne tips for an upndcoming Electrician
10-01-2009, 04:55 PM
don't text on the job
10-01-2009, 05:50 PM
Even better, leave your freakin phone in your car!!!!
Proud Father of a US Army Solider
10-01-2009, 09:45 PM
Show up on time, pay attention, ask questions.
John from Baltimore
"One day at a Time"
10-06-2009, 11:06 PM
Seen your member
Show up on time.
Keep accurate records of the times and places you worked.
Keep accurate inventory records if this is your job.
Stock the truck after using something.
Maintain company tools.
Constantly improve your knowledge and mechanical skill.
Clean up your work area.
Minimize mistakes.
Use scrap material where possible.
No side jobs except for your mom.
Study if enrolled in apprenticeship.
Keep up with the latest NEC and local code amendments.
Don't borrow tools or anything from other workers without permission.
If you borrow something and break/lose it, buy them a new one.
Inform the shop of changes in your contact information.
Learn how to read and understand blueprints, job specs, etc.
Don't bring pets, children, or friends to the job.
Don't leave early without permission.
Don't miss days without a good reason.
Ask for time off well in advance.
Schedule vacation in writing. Keep a copy.
Advise job supervisor when you can not work overtime.
No working on live circuits if you're not qualified.
Don't expect much in the way of gratitude from anyone.
Be pleasant to customers regardless. Or leave.
Don't quote a price to anyone for anything.
Plan your work. Work your plan.
Evaluate your work each day on the way home.
Help load and unload the trucks bringing material.
Don't use the couple top steps of a ladder.
Do not climb up the ‘back side’ of a ladder.
No smoking. Period.
Do every job the best way you know how.
Observe the work of other trades.
Look over electrical work wherever you can.
If you’re not sure, ask.
Read trade publications and manufacturers literature.
Attend trade shows.
Check material against invoice before signing for it.
No swearing, vulgar language or off-color/racist remarks.
Thank your boss for your job now and then.
If you ever get a bonus, say thanks.
Drive safely with seat belt in place.
Store material in the truck so the load will not injure you.
Tie down all ladders and other objects on the roof.
Cover material to protect it from the elements.
Wear appropriate clothing for the elements.
Have a spare set of work clothes just in case.
Keep your first aid kit stocked and readily available.
Tools are not disposable. They are intended to be used more than once.
Know the location of the nearest emergency clinic and how to get there.
Update your first aid and CPR skills.
Notify the supervisor when damage is caused.
If you’re the last one out the door at the end, lock it.
Observe daily weather reports to anticipate hazardous changes.
Drink fluids to avoid heat stroke. Wear a hat in the sun.
Use tools only for the use they were intended.
Do not over-extend break and lunch periods.
Have several pair of dry gloves ready in winter.
If you find a lost tool, try your best to locate the proper owner.
Keep your job car in good working order.
Keep your hand tools in good working order.
No vulgar or offensive clothing (t-shirts, hats, etc.)
Be truthful when responding to supervisors.
Try to get a variety of work experience.
Volunteer for a difficult job now and then.
Go along to get along.
Put everything back where you got it.
The floor is not your personal garbage can.
Neither is the top of drop-ceiling tiles.
Care for your injuries. Stay healthy.
Own up and admit to your mistakes.
Don't take chances on ladders or scaffolding.
Don't take chances with live power.
Build up a backup set of hand tools for the day when yours are taken or lost.
Keep all company material and tools secure.
Do not use unsafe equipment. Report it immediately.
Replace hacksaw blade as often as needed.
Replace utility knife blade as often as needed.
Don’t be afraid to report theft /abuse / illegal activity.
Don't wear jewelry.
Don't antagonize or fight with other workers. Walk away.
Help other workers as needed.
Keep the radio volume at a reasonable level, if a radio is allowed.
Alcohol and drugs are absolutely forbidden.
Wear safety glasses and ear protection as appropriate.
Check your shoes/boots before entering the finished area of a building.
Be cautious working on new buildings during lightning storms.
When lifting, observe proper back position.
If something is too heavy for you ask for help.
Wear proper footgear to protect ankles from uneven ground.
Wear hard sole shoes where sharp objects like nails are present.
Wear a hard hat as required or where sensible.
Maintain GFCI in good working order.
Return phone calls promptly.
Use all safety equipment when required to.
Your cell phone is no excuse for not working.
Put on a belt and pull up your pants to your waist.
10-07-2009, 08:17 AM
Head Grunt
Thats a good list sparky  . Build up a backup set of hand tools for the day when yours are taken or lost.
I found out the other day how important this one is. I towed my trailer to the job about 30miles from home only to realize i forgot my Tool Bag in the other truck. I was lucky enough to scrounge enough tools out of the trailer to get the job done.
No free man shall ever be debarred the use of arms.-Thomas Jefferson
12-10-2009, 11:40 PM
Thanks 480Sparky. I am brand new (about to apply for an apprenticeship) and appreciate your advice.
01-02-2010, 08:35 PM
1st Year Apprentice
Show up on time.
Minimize mistakes.
No smoking. Period.
Attend trade shows.
Don't wear jewelry.
The only side jobs I've ever done were for my mom.
01-02-2010, 08:43 PM
1st Year Apprentice
And as a first year 5 months in the trade the most important piece of advice I can give you is ask ask ask questions. Hopefully you have a smart boss or supervising journeyman that will appreciate you taking the inititative to ask a million questions and pay dilligent attention to the answers. I know my boss sure does, and it's how I've done most of my learning. Also no minor mistake is a failure as long as you learn from it.
01-02-2010, 11:15 PM
Unlimited Lic.Electrician
Does anyone miss user5941?
01-02-2010, 11:57 PM
Seen your member
No. ..........
01-03-2010, 12:00 AM
Not Peter D
I don't miss his almost maniacal ranting about unionism but I don't understand all the hatred for the guy either.
01-03-2010, 12:11 AM
Thats Good AJT!
And remember: The only stupid question is the 1 you don't ask.
(meaning you think you know)
But to compound that---- THINK- before you ask- then get confirmation.
Most times you will have the answer- just confirm.
01-03-2010, 12:50 AM
1st Year Apprentice
Originally Posted by leland
Thats Good AJT!
I like your clarification! Often times I'll ask questions that I'm fairly sure I know the answer to, just to be sure, because as far as the CEC is concerned, I don't know code for anything really. And it SUCKS when you gotta redo one hour's worth of work when you could have taken 5 minutes to check something quick with the man in charge. Gotta get to school first and learn some code, until then, just gotta ask the questions..
01-03-2010, 01:18 AM
1-Always a good idea.
2-Another GREAT idea.
Both will lead you in a good direction.
BUT..... Always question Authority!
This is where learning the code comes in,it will intersect with experience and knowledge.
You both learn.
01-05-2010, 02:00 PM
Since you put this in the Safety part of the forum I'll start with that. Don't do stupid things that will get you hurt. Question the safety aspect of things that make you uncomfortable. Don't work live wires.
In general don't get your hopes up to much. Just show up ready to work and do the best you can. No running on the job, just work hard. You are going to run into some real morons out there but remember you'll likely work for a lot of companies in your career. Don't take crap from anyone and keep on trucking.
02-08-2010, 10:57 PM
As someone trying to enter the field I was wondering if anyone knows where I could find information on a recent injury/mortality rate?
02-09-2010, 04:41 AM
#18
Try here - http://www.osha.gov/oshstats/work.html
Welcome to the forum.
John from Baltimore
"One day at a Time"
02-17-2010, 10:16 AM
#19
Learn how to spell NE, punctuate and spell UPNDCOMING!
02-17-2010, 03:53 PM
#20
If you have to use a fork or spoon to eat it then its not break.
