Old 10-28-2009, 04:33 PM   #1
Default Unqualified Person is now defined in 70E
"Unqualified Person. A person who is not a qualified person.
Commentary:
Workers who might be exposed to an electrical hazard as a work task is performed must be trained to recognize that a hazard exists and how to avoid that hazard.
Any person who has not received specific training is an unqualified person.
A worker who has been trained to perform a task might be qualified to perform that task and still be unqualified to perform any other task.
The characteristics of being qualified and unqualified are task dependent."
Courtesy: 2009 70E Handbook www.nfpa.org
Violation #1 - Temporary bulb, shock hazard!
Violation #2 - Keyless lampholder in closet.
Violation #3 - In one receptacle out to the other.
Violation #4 - A well destroyed junction box.
Violation #5 - Non covered, overcrowded, and partially damaged J-box.
Violation #6 - LB totally disconnected from rest of raceway.
Violation #7 - Defective GEC to ground rod.
Violation #8 - Electrical Metallic Tubing (EMT) hanging in the breeze, wires exposed.
Violation #9 - Working clearance problem for disconnect.
Violation #10 - Cord coming out of cord-connected plug.
Violation #11 - Overcrowded junction box in a hospital?
Violation #12 - Damaged junction box in a front lawn.
Violation #13 - Working space violations in a rest home.
Violation #14 - Junction box in an attic with many violations.
Violation #15 - Work done by an Unqualified Person using paper bags?
Violation #16 - Exposed live energized bus in a hotel panelboard.
Violation #17 - Sheet metal screw is no good for EGC, and open KO's.
Violation #18 - Hotlegs, many of them and exposed they are!
Violation #19 - Can you tell what's wrong with this?
See #15
Joe Tedesco is offline   Reply With Quote
Old 10-28-2009, 05:15 PM   #2
B4T Scotchkote installer
Black4Truck's Avatar
Joe.. I am in an ongoing battle with untrained maintenance men doing electrical work.
These are guys who do painting or fix toilets and have no formal training, but are told to do electrical work.
I am trying to find everything I can in writing and give it to management before someone gets hurt or killed
Any info you have on this subject would be helpful
Old 10-28-2009, 05:37 PM   #3
Default Problems!!
I will help and if you look here you wiill see some here who seen to have other ideas about the issues you have to deal with! I too think that we have a problem!
The bottom line is the almighty dollar!
NFPA 70B is a good source for you too.
Old 10-28-2009, 05:45 PM   #4
I will check NFPA 70B.. thanks Joe
Old 10-28-2009, 05:48 PM   #5
Check the NFPA site you may be able to download a copy in a PDF format. I will check for more information on this issue.
Is there a specific person to whom you can attribute your becoming an electrician? 480sparky General Electrical Discussion 66 11-02-2009 09:25 PM
Not the type of person you want fighting for your right to bear arms... Mr. Sparkle Off Topic 22 10-11-2009 01:34 PM
What is the effect of voltage and amperage on a person? Frasbee Workplace Safety 28 04-21-2009 11:27 AM
