Old 10-07-2009, 10:11 PM   #21
Rat Extraordinaire
Originally Posted by randas View Post
You silly kids and your 480. Come up north and play with some 600
Who is 600?
Old 10-07-2009, 11:12 PM   #22
Apprentice
Frasbee's Avatar
I still don't f*cking get this amperage/voltage thing.
Does voltage even matter at all?!
Philly Carpetbagger
Old 10-07-2009, 11:14 PM   #23
Rat Extraordinaire
Not when it comes to killing people, no. It's the amperage that kills. You could have a million volts go through your body and if the amperage is low enough, you would never know it.
This is why GFCI's are set to trip at 4-6 mA.
Old 10-07-2009, 11:15 PM   #24
Apprentice
Frasbee's Avatar
Go through you to ground?
What about the resistance your body possesses?
Philly Carpetbagger
Old 10-07-2009, 11:19 PM   #25
Rat Extraordinaire
...........What about the resistance your body possesses?
That will determine how much amps are allowed through your body. The lower the resistance, the more amps that will flow.
Old 10-07-2009, 11:21 PM   #26
Been there, done that.
I used to work in a cotton mill where everything but the lights were 600 volts.
GO JACKETS!
jbfan is offline   Reply With Quote
Old 10-07-2009, 11:26 PM   #27
steelersman's Avatar
The other thing to understand is that for whatever the given resistance your body happens to be at the time of the shock, the higher the voltage, then the more amps you will take as well. That's why higher voltages are more dangerous even though it's the current that does the "killing".
steelersman is online now   Reply With Quote
Old 10-07-2009, 11:28 PM   #28
Apprentice
Frasbee's Avatar
But wouldn't a higher resistance also increase the chance of burning internal organs?
Philly Carpetbagger
Old 10-07-2009, 11:32 PM   #29
Rat Extraordinaire
No, a lower resistance would. If you have a high enough resistance, the current flow will be reduced, and if you reduce it enough, you'll never feel it.
It's Ohms law.... draw it out, punch in some numbers and do some calcs.
Old 10-07-2009, 11:36 PM   #30
Apprentice
Frasbee's Avatar
So why is it that using say, 16 awg wire on a 30 amp breaker would cause it to overheat?
Sorry, we're finally getting to theory in class but this teacher doesn't seem to know anything outside what's written word-for-word, in the book.
Philly Carpetbagger
Old 10-07-2009, 11:39 PM   #31
Journeyman Wireman
crazymurph's Avatar
I would guess 120 as it is the most common voltage the general population is exposed to. Very few housewifes have 277 volt coffee makers, or 480 volt espresso machines.
My wife has a 480 volt device she keeps in the bedroom
crazymurph is offline   Reply With Quote
Old 10-07-2009, 11:39 PM   #32
I'd say because it has been determined that it's not large enough to safely carry that amount of current for a sustained amount of time without overheating.
Old 10-07-2009, 11:43 PM   #33
Rat Extraordinaire
It's not the higher resistance of a 16-ga wire that causes it to overheat... it's the fact that 30 amps being forced through it by the load on the circuit is what causes it. Hook a 16-ga wire to a 30-a breaker, turn it on and sit back to watch with total amazement when......... nothing will happen.
Old 10-07-2009, 11:44 PM   #34
Rat Extraordinaire
It uses 320 AA batteries?
Old 10-07-2009, 11:47 PM   #35
Damn if it uses that many batteries, imagine how big it must be?
Old 10-07-2009, 11:48 PM   #36
Rat Extraordinaire
I'd rather not, really.
Old 10-08-2009, 12:05 AM   #37
Rat in a Dress
BCSparkyGirl's Avatar
ya it will put some hair on your chests.....speaking of which, time to go shave mine again.........
I can drink you pretty.......
BCSparkyGirl is offline   Reply With Quote
Old 10-08-2009, 12:07 AM   #38
Rat in a Dress
did she say where she got it perhaps?
Old 10-08-2009, 02:43 AM   #39
That is like asking does a wedding ring mean anything. brief answer sometimes yes. firstly we look at the overall effect or outcome, this is best described as power. the formula states that p=VI, since V is an incumbent part of the power formula it must be taken into consideration. We know that the human body and its nervous system react to micro amps, therefore we require minimal current to interact with the natural body functions these include the heart and brain. This then begs the question what must we have for an external stimulii to be able to interefere with our own natural electrical system. This answer is a circuit, what then stops a circuit becoming a circuit? this answer is resistance, resistance can be Air between two live wires or that of the human body.
This is where Voltage comes into it, we as electricians will surely die if any wire we touch that has a route to ground through us and sufficient voltage to push the circuit through us.
Voltage is the driving force or pressure to make the circuit, consider it rhe most critical element in the equation.
slow cooker is offline   Reply With Quote
Old 10-08-2009, 02:53 AM   #40
Sheees!!!!, Do I know your or your wife? whats your address and phone number again? I guess you work long hours like me? I tend to work a half hour less than most good looking busy sparkies. By the way its the fistatron thats 480v and the ring puncher thats 120v what ever you do man don't confuse them
Low Voltage/ High Voltage MikeD NEC Code Forum 18 02-19-2009 06:17 PM
high voltage low voltage dain Other Codes and Standards 2 02-10-2009 11:12 PM
Low Voltage/ High Voltage MikeD Structured Wiring 1 07-09-2008 05:49 PM
us voltage mtom General Electrical Discussion 7 04-27-2008 01:20 PM
Line voltage and low voltage makita1 Structured Wiring 1 03-27-2008 08:06 PM
