Old 10-08-2009, 07:22 AM   #41
drsparky's Avatar
Originally Posted by randas View Post
You silly kids and your 480. Come up north and play with some 600
I thought you hosers used 575.
"Pay attention son, this is for your own good." - Foghorn Leghorn
Old 10-08-2009, 11:32 PM   #42
Default What voltage kills most
Sometimes by the time I get my thoughts into writing it looks different than what I thought. If you were wondering if more people are killed by lower voltages than higher, I would say YES. It is the lower voltages that we are most involved with. However, more attention has to be paid to the neutrals. Though they are at GROUND potential,they are deadly. In a properly grounded electrical system there is no potential from the neutral to ground but if you become in series with the neutral by BREAKING a joint, you are the load and therefore the DIFFERENCE OF POTENTIAL.
QUOTE; Electricity is absolutely useless without a difference of potential.
RIVETER
Old 10-08-2009, 11:36 PM   #43
steelersman's Avatar
Do you rivet a lot of things, hence the name?
steelersman is online now   Reply With Quote
Old 10-09-2009, 12:38 AM   #44
Rat in a Dress
BCSparkyGirl's Avatar
I found his post to be riveting!
I can drink you pretty.......
BCSparkyGirl is offline   Reply With Quote
Old 10-09-2009, 12:45 AM   #45
Rat Extraordinaire
Old 10-09-2009, 01:08 AM   #46
347/600 and the odd place might have 277/480.
Mike_586 is offline   Reply With Quote
Old 10-09-2009, 09:57 PM   #47
Rat in a Dress
thats neat, where didja dig that up from?
Old 10-10-2009, 01:12 PM   #48
Toronto Sparky's Avatar
13.8 KV will take you out cleanly.
I'm told that the 600 vdc that we use for the subway here really bites hard too.
I've got 575 vac many times over the years.. Just messed up my heart for a bit..
Don't fight .. Play nice!
Old 10-10-2009, 02:59 PM   #49
Do a google search for Rosie the Riveter.
Roger
Roger is offline   Reply With Quote
Old 10-10-2009, 03:41 PM   #50
Rat Extraordinaire
Roger
Here, let me Google that for you.
Old 10-10-2009, 08:29 PM   #51
cdnelectrician's Avatar
A welder at work got hospitalized after he got between the ground electrode and the work he was welding. 50 volts at 200 amps. He is lucky to be alive i'm told.
Old 10-10-2009, 08:42 PM   #52
347 is like being hit in the head with a 2 x 4 it will take a few of your brain cells.
sparky105 is offline   Reply With Quote
Old 10-10-2009, 09:03 PM   #53
Yea, 347 hurts like hell.
Old 10-10-2009, 09:15 PM   #54
Here is a lesson for the young and dumb
When entering a ceiling always go up the ladder looking up and have a good light and hard hat
I stepped into a ceiling with a ball cap on and there was an old 347 volt light feed bx hang down. took both wires off the top of my nut and broke the last step on the ladder (the voltage over stimulates muscle movement That's what holds you or throws you) That was 20 years ago and I still have a feeling of falling when i close my eyes some nights
I woke up on the floor with a throbbing head and a sore ass. It could have been way worse if I had grabbed the t bar and it was grounded anywhere I hate to think about that senerio
Old 10-11-2009, 12:42 AM   #55
Hack and Rat all in one
Peter D's Avatar
Have any of you guys ever seen or know someone who has experienced an arc flash incident on a 600 volt system?
Old 10-11-2009, 03:00 AM   #56
Rat in a Dress
we just had a kid hurt bad up here....12k went phase to phase, or something like that, Im hearing second hand....not on my site, but up with our hydro crew. My dad says he had 3rd degree burns to the top 20% of his body....poor guy, in a med induced coma........he waswearing a fire suit, probably the only reason he wasn't killed. But he's in for a rough recovery.
Be careful out there boys!
Old 10-11-2009, 05:02 AM   #57
Vaporized a couple of screw drivers on 600v 400a splitters. And blew up a watt/hr meter once (not my fault)
It was prewired and someone wired the pot. transformer backwards.
Wiring a 600-120v tranny backwards tends to make stuff go poof.
Never really had a bad flash. Seen the aftermath a few times.
Worst was a flopping about #12 ground wire in a 600v 2000a switchgear, they had to replace the whole switch gear. And the guy spent months recovering..
Old 10-11-2009, 10:26 AM   #58
got a service call on a 200 amp buss plug for a chiller
the hacks at the plant found a blown fuse so they replaced it with out testing
hit it again and blew the buss plug door off the rack
the a and b phases fused together in the buss system and it was a 2 day rebuild verticle buss from floor to floor hot moulting steel and copper ran down 6 or so feet glad i wasn't on that switch handle that clown will still be deaf I think
and the feeder cable needed to be redone because it was pulled tight to the connections and burnt to a crisp
THe fuces went off we think becuase they were having problems with the o.l.'s and by passed them to keep production up but by the time we left it was a new intall thank you hacks 16 hrs straight and 15 hrs dbl time
Old 10-14-2009, 02:29 AM   #59
semi-electrician
We should do a test on the most lethal voltage, wonder if we could get the two Aussies to volunteer for the test?
Old 10-14-2009, 03:05 AM   #60
Rat in a Dress
stick one wire up their nose, and the other up their ass?
Low Voltage/ High Voltage MikeD NEC Code Forum 18 02-19-2009 06:17 PM
high voltage low voltage dain Other Codes and Standards 2 02-10-2009 11:12 PM
Low Voltage/ High Voltage MikeD Structured Wiring 1 07-09-2008 05:49 PM
us voltage mtom General Electrical Discussion 7 04-27-2008 01:20 PM
Line voltage and low voltage makita1 Structured Wiring 1 03-27-2008 08:06 PM
