Old 07-30-2008, 09:00 AM   #1
Default Worker Electrocuted
http://www.ajc.com/gwinnett/content/...ge_tab_newstab
This was in todays paper.
No other details!
Water and women are in short supply! There's not enough dope for us all to get high! Jimmy Buffett!
jbfan is offline   Reply With Quote
Old 07-30-2008, 11:45 AM   #2
"A" inside wireman
randomkiller's Avatar
Accidents happen that is why we all need to be careful out there, especially when working hot or troubleshooting.
"One Nation Under God"
Old 07-30-2008, 11:59 AM   #3
JohnJ0906's Avatar
What RK said.
John from Baltimore
"One day at a Time"
Old 07-30-2008, 09:44 PM   #4
Former sparky
I heard today that a jw here in nj was trying to pick up a light pole with a strap to his bucket, the strap snapped and he was catapulted out of the bucket to the parking lot below and didnt make it.
Old 08-02-2008, 06:21 AM   #5
Another good reason for fall protection.
Old 08-02-2008, 08:58 AM   #6
stop pickin on Peter D...
BP_redbear's Avatar
"400". "Approximate number of deaths attributed to workplace electrocutions per year." from June 2008 edition of EC&M magazine.
Working hot intentionally, and troubleshooting, which needs to be hot much of the time are definitely dangerous, especially in an industrial setting, which is where I have the majority of my experience.
Proper use of LOTO cannot be understated. Already in my apprenticeship I have seen JWs "Tag Out" circuit breakers with electrical tape.
I pulled a piece of surface metal raceway accidentally off the wall when removing data cable from one side of it (the 120V duplex recs were separated by a internal divider). I pulled the cover off and found wire nut splices for the 120. I told the JW I could disconnect them here (hot), so that I could 'safely' re-attach the raceway to the wall.
Knowing my industrial experience, he said OK, I will watch, go ahead "Do you have your side cutters?" (to untwist the 12AWG solid wires). I said "Yes, but they are not my insulated ones".
He said "It doesn't matter". Well, it matters to me. Just an added measure of safety. What if your plier grips are not insulated, and you are inadvertently grounded?
There was no load on the circuit, so no current flowing in the conductors, no arc when disconnecting. I have done this many times before, so was comfortable doing it.
That's probably the most dangerous thing we can do in our biz. Comfortable is okay, you can't be scared. You DO have to be respectful of the danger, and DO NOT be careless, or reckless, or lackadazical.
PAY ATTENTION to where your hands are!!! (And your elbows), When working Hot: Wear Insulated gloves, Use Insulated tools, Wear safety glasses, CONCENTRATE.
Sometimes, things happen that are out of our control. Most of the time we control our own fate.
It is terribly unfortunate that people die at work. Everyone should be able to go home at the end of the day.
BP_redbear is offline   Reply With Quote
Old 08-02-2008, 10:32 AM   #7
i work for that company that this happenend at it was at a different job then i'm on. he had been with the company for many years. i personally never met the guy. but it was a wake up call for everyone.
the_full_monty is offline   Reply With Quote
Old 08-04-2008, 06:47 PM   #8
joeyuk's Avatar
People were talking about it at work today. The only details I know of are that it was a 164 member working for Allen-Briteway. They said he had been with the shop 25 years.
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!."
- Benjamin Franklin
joeyuk is offline   Reply With Quote
Old 08-04-2008, 08:55 PM   #9
102 member he and i were in the same local and work for the same company
Power company worker hit by car on Christmas; driver flees Celtic Workplace Safety 6 12-27-2007 05:39 PM
electrocuted bear bigredc222 General Electrical Discussion 15 10-30-2007 07:32 AM
Seach Google for "remodeler electrocuted" Joe Tedesco Workplace Safety 0 04-08-2007 01:13 PM
Worker killed on the job Recruit4Meisner Workplace Safety 0 02-01-2007 08:23 AM
