Old 03-19-2007, 04:49 PM   #1
Default You Just Gotta Tighten Those Connections!
While it is hard to see the hardware for this CT, it was loose, never tightened. check the temperature of the spot, the hottest spot (not in this text was 266.6 F) The picture has been edited to remove the customer information. The black marks are magic marker and is utilized to obtain the temperature without the copper emistivity effecting the reading.
Old 03-19-2007, 04:54 PM   #2
Can you talk a little more about that? That is, what is copper emmisivity, and how does it affect the reading if you don't scribble black marker on the buss tang?
Old 03-19-2007, 06:01 PM   #3
Marc:
I am not an IR thermographer and have limited knowledge on this subject, but basically it has to do with reflection of the surface which can skew the temperature. If I use the camera and look an a galvanized can I can see my image in the IR camera even though with a real time camera or my eye nothing is visible. Every substance (I believe) has an emissivity number.
From IEEE Dictionary:
Emissivity - The ratio of power radiated by a substance to the power radiated by a blackbody at the same temperature.
Old 03-19-2007, 06:04 PM   #4
rod213's Avatar
Ah, I get it I think. You mark on it first with your marker so it doesn't reflect and you get a true temp reading with your IR? Otherwise itwould look like the rest of the area on that buss without the sharpie.
Interesting stuff there.
-Rodney
rod213 is offline   Reply With Quote
Old 03-19-2007, 06:50 PM   #5
Is this a special di-electric marker? Or an ordinary one from the office supply store? You don't have to answer that if it's a trouble making question. I was just wondering.
Old 03-19-2007, 08:14 PM   #6
Marc:
I'd rather not know...But yes it is a regular marker and I have warned him before..........But Steve says he has to do it to get a clear real picture. NOW PLEASE DO NOT REPEAT THIS it is strictly between you me and the rest...
I should have figured you'd pick up on this.
Old 03-20-2007, 03:18 PM   #7
InControl's Avatar
We have yearly IR scans at the plant where I work. I've never heard of the black magic marker thing. I would think that it would give false high readings because the black would absorb heat.
InControl is offline   Reply With Quote
Old 03-20-2007, 04:48 PM   #8
Just the opposite, it minimizes the reflection.
Are your thermographers Certified and electricians? Many thermographers are not electricians and while heat is heat have NOT A CLUE regarding electrical issues. Ie why there are thermal issues with a particular piece of equipment, Induction, bolted pressure switch issues...ECT.
Old 03-20-2007, 05:02 PM   #9
InControl's Avatar
We used to outsource our IR scans but our company is big enough that we had one of our electricians get sent out to get certified and the whole nine yards. I'll have to pick his brain when I get back to work.
now we gotta compete with wiki nolabama Business, Marketing, and Sales 14 02-25-2010 04:46 PM
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 07:21 AM
12V Lighting Connections megavolt Lighting Design 11 04-18-2008 06:42 PM
You gotta pay attention brian john General Electrical Discussion 2 08-13-2007 04:38 PM
Handymen, gotta love em 3phase General Electrical Discussion 16 02-24-2007 07:45 PM
