Staple problem - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Electrician Apprentice Forum
Like Tree23Likes
Old 11-05-2016, 01:12 AM   #1
Rewards Points: 8
Unhappy Staple problem
Hey everyone,
Do you have any trick for stapling Romex cable? For example, I run the wire from the breaker panel to the kitchen, so I have to staple the them every 4'6''
. The problem is every time I try to staple them (especially on the ceiling), my hammer always miss the staple and hit my hand. I cannot hold the staple still because of the Romex's weight, and my hands are always get tired when I hold there too long ? I am a new apprentice. ( Sorry for my bad English)
trungtran4177 is offline   Reply With Quote
The Following User Says Thank You to trungtran4177 For This Useful Post:
privateryan24 (01-10-2017)
Old 11-05-2016, 01:16 AM   #2
Rewards Points: 1,976
Originally Posted by trungtran4177 View Post
Hey everyone,
Young Padawan, Needle nose pliers till you develop the muscles properly.
Old 11-05-2016, 01:47 AM   #3
wcord's Avatar
Rewards Points: 580
Like Micky says,use pliers of some type , Needle nose, or Linesmen.
Be careful what you wish for, you just may get it.
Old 11-05-2016, 01:51 AM   #4
Rewards Points: 372
It depending on what type of staples ya using.,,
needle nose or linesman will do the trick to get it start .,,
but once you know how to deal with staples in ceiling area espcally if going inverted postion aka upside down.,
one thing I useally do is lightly tap it just enough to hold it in place then pull the romex a little to tighten up or keep it straight while ya drive the staple in.
shocksystems likes this.
Old 11-05-2016, 02:03 AM   #5
NRA Member
backstay's Avatar
Rewards Points: 454
And put them closer together. On the run from the top plate to a switch box, I use 3 staples.
frenchelectrican (11-05-2016)
Old 11-05-2016, 02:14 AM   #6
Rewards Points: 88
Practice-practice-practice. On your own time of course. I wouldn't recommend telling anyone at work, either. This trade can be physically demanding and you must prove your worth the commitment to be trained. If stapling is tiring, trust me it won't get easier. Are you young(under 45)? Can you start working out?
350X is offline   Reply With Quote
Old 11-05-2016, 02:24 AM   #7
My first training session for my son was to set him and his new hammer in front of a six foot long 4'' x 4'' and a box of 500 staples, and a bunch of 6' long `12-2 romex . Told him to put in all 500 staples and after that we would do a megger test to see how he did. By the time he got all 500 done he was very competent. The op of this thread should try that.
BrettC likes this.
350X (11-05-2016)
Old 11-05-2016, 02:33 AM   #8
Rewards Points: 88
Yep. My boy is 7 and loves doing that. Also, when I first started bending pipe, boss dropped me of at my place that first weekend with a bundle of 1/2 and said "have fun, son".
Old 11-05-2016, 02:51 AM   #9
Rewards Points: 4,142
Try tapping them in with your linesman pliers. I apprenticed with a guy who never used a hammer on staples.
Old 11-05-2016, 09:13 AM   #10
wcord's Avatar
Rewards Points: 580
I thought that's how everyone did it?
4 or 5 linesmen in the truck, but no hammer
hardworkingstiff and 99cents like this.
Old 11-05-2016, 09:29 AM   #11
Yeah Toast!!
Roger123's Avatar
Rewards Points: 1,190
Choke up on the hammer to set the staple then you won't hit your hand.
Old 11-05-2016, 10:09 AM   #12
Mr. Awesome
Rewards Points: 85
Halex quick strap. Tell your boss to quit being a cheap ass and buy one it will pay for itself in a year.
http://www.homedepot.com/p/Halex-Qui...1900/204739329
knomore is offline   Reply With Quote
Old 11-05-2016, 10:35 AM   #13
Yeah Toast!!
Roger123's Avatar
That looks good. What are the pros & cons?
Also, looks like the product has been discontinued.
Old 11-05-2016, 10:56 AM   #14
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 1,284
Hey everyone,
If you're literally stapling to the ceiling, that's part of the problem.
Shouldn't be stapled there anyways as the cable would be prone to
damage from nails/screws from above.
You'll pull the romex in one direction and then staple in the other. In your
example, pull from kitchen to panel (assuming panel is lower than kitchen),
then staple from panel back to kitchen. The romex shouldn't have a lot
weight hanging as it'll be pulled through joists, X members, and over
plumbing etc.. When there is weight on the romex, press the romex
against the joist (or whatever) with the heel of your palm.
In some situations it works better to hold the staple like roofers hold
nails; with palm facing you and staple between 2 fingers, not finger
and thumb. In this case the back of the wrist pushes the cable against
the stapling surface.
One more thing, I like drilling more than stapling so I'll use drill holes
as supports wherever I can.
btw, I use a hammer.
Now do it with gloves on in sub-zero weather
P&L
edit: Don't drive the staple in tight. Far enough in so it'll never fall
out but still loose enough that it's easy to remove without damaging
the cable.
As far as possible, without surrender, be on good terms with all persons. Speak your truth quietly and clearly; and listen to others, even to the dull and the ignorant; they too have their story. Avoid loud and aggressive persons; they are vexatious to the spirit. ~Desiderata
Old 11-05-2016, 12:28 PM   #15
So some kid can't staple and suddenly it's his boss's fault for being a cheap ass?
That thinking is why I refuse to hire .
The_Modifier and Helmut like this.
Cow (11-05-2016)
Old 11-05-2016, 12:33 PM   #16
Click Here
Rewards Points: 894
I wish Milwaukee would make an M12 romex stapler.
Graphene likes this.
skittles (11-05-2016)
Old 11-05-2016, 02:52 PM   #17
Cow
Rewards Points: 2,128
I agree.
Instead of learning a skill, like proper hammering technique, let's use a crutch instead. What happens when the cordless stapler can't fit into a spot that he needs a staple? Should he call his boss over to hammer one in for him so he doesn't smash his fingers?
I tell you, it's the dumbing down of America.
Old 11-05-2016, 04:02 PM   #18
Signal1's Avatar
Rewards Points: 162
^^^Agree with Mike and Cow^^^^
It's a basic skill every apprentice needs to learn.
Signal1 is online now   Reply With Quote
Old 11-05-2016, 05:01 PM   #19
Click Here
Rewards Points: 894
Many of us went thru apprenticeships that didn't include residential work.
John Valdes likes this.
Old 11-05-2016, 05:05 PM   #20
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Tags
#staple#romex#miss
Need help with a voltage divider problem Angelpooz General Electrical Discussion 3 10-06-2016 07:13 AM
Small Problem Mr. H Residential Electrical Forum 11 06-08-2016 03:51 PM
Another arc fault problem Paul S. General Electrical Discussion 2 06-04-2016 02:29 PM
Got a problem Flytyingyaker Residential Electrical Forum 11 01-20-2016 10:02 PM
