Staple problem - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Electrician Apprentice Forum
Like Tree23Likes
Old 11-06-2016, 11:29 PM   #41
Rewards Points: 3,928
Originally Posted by TRurak View Post
I catch one staple at the beginning of the run and pull romex right and hold it with my left. Push staple into wood so it doesn't fall out then hammer it in.
When I was a brand new apprentice we were roughing a 2 car garage. We had a dead short on the lighting circuit!!!! I drove a staple in so hard I broke 2 of the conductors .........
Good trick. Try that in my state, every piece of structural wood is pressure treated.
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Old 11-07-2016, 12:14 AM   #42
Rewards Points: 8
Thanks everyone for replying, I'll keep practicing. Hopefully, after a few time of hammering into my fingers, I might get used to it.
trungtran4177 is offline   Reply With Quote
Old 11-07-2016, 12:19 AM   #43
Rewards Points: 8
Young Padawan, Needle nose pliers till you develop the muscles properly.
This is the staple we're using: https://www.amazon.com/Gardner-Bende...=romex+staples
A needle nose plier? I mean HOW?
Old 11-07-2016, 12:21 AM   #44
Rewards Points: 8
Originally Posted by frenchelectrican View Post
It depending on what type of staples ya using.,,
needle nose or linesman will do the trick to get it start .,,
but once you know how to deal with staples in ceiling area espcally if going inverted postion aka upside down.,
one thing I useally do is lightly tap it just enough to hold it in place then pull the romex a little to tighten up or keep it straight while ya drive the staple in.
What's your method?
Old 11-07-2016, 02:48 AM   #45
I try not to buy anything made by Gardner Bender , except I'm a fool for those cute emt benders with the bubble levels in them. I'm the same way for pony tails. And Filipina's .
Old 12-10-2016, 02:23 AM   #46
Rewards Points: 397
You grab the staple across both legs above the cable with the pliers. You just need to use the pliers until the staple is set then you drive it home.
PS: Wow I didn't know they made a loomex staple without a shoulder.
Old 01-14-2017, 07:42 PM   #47
Wiresmith
hd13's Avatar
Rewards Points: 266
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
or at least an apprenticeship where we didn't wire residential with glorified extension cords. conduit will work in them walls.
hd13 is offline   Reply With Quote
The Following User Says Thank You to hd13 For This Useful Post:
MechanicalDVR (01-14-2017)
Old 01-14-2017, 07:45 PM   #48
Wiresmith
hd13's Avatar
Rewards Points: 266
What's your method?
i recommend looking for another contractor to work for if they use those staples on that flat extension cord, i mean romex.
Tags
#staple#romex#miss
Need help with a voltage divider problem Angelpooz General Electrical Discussion 3 10-06-2016 06:13 AM
Small Problem Mr. H Residential Electrical Forum 11 06-08-2016 02:51 PM
Another arc fault problem Paul S. General Electrical Discussion 2 06-04-2016 01:29 PM
Got a problem Flytyingyaker Residential Electrical Forum 11 01-20-2016 09:02 PM
