Old 08-26-2007, 01:52 PM   #1
JohnJ0906's Avatar
Angry #4 stranded won't fit.
Now, why the lug RIGHT above this couldn't be used, I don't know. I guess someone couldn't be bothered getting their allen keys.
Busbar screw was cross-threaded, and the "add-a-lug" wasn't even close to being tight to the bar.
John from Baltimore
"One day at a Time"
Old 08-26-2007, 02:07 PM   #2
You know what's funny? #4 WILL fit in that bar.
Old 08-26-2007, 06:07 PM   #3
JohnJ0906's Avatar
I added 2 #4s, and had a HELL of a time making them fit. It will take 4 solid no problem, but 4 stranded is a bear.
John from Baltimore
"One day at a Time"
Old 08-27-2007, 02:55 PM   #4
curranelectric's Avatar
I have used Breaker Box Neutral Lug. They go from #4 through 0 wire size
They come with the Square D Panels and you can get extra one at Homedepot
curranelectric is offline   Reply With Quote
Old 08-27-2007, 05:20 PM   #5
The one pictured is a QO70AN, and has a 70 amp limit. I see this used sometimes noncompliantly. The QO100AN bolts right on top of the bar (doesn't have the two fingers) and is rated at 100 amps.
Old 08-27-2007, 06:09 PM   #6
JohnJ0906's Avatar
Seimens panel.
However, the point is well taken.
John from Baltimore
"One day at a Time"
Old 08-28-2007, 11:33 AM   #7
frank's Avatar
Often wonder when checking out your USA stuff why you folks don't sleeve your earth (ground) wires. It is great way to ensure some insulation around the bare conductor to help against accidental contact with hot (live) parts.
Looks pretty neat too
Old 09-04-2007, 06:56 PM   #8
joebell's Avatar
Send a message via Skype™ to joebell
John,
What is the wire below the lug ( in the top photo) is that how seimens is tieing the neutral bars together? It used to be a bar bolted at the bottom.
joebell is offline   Reply With Quote
Old 09-04-2007, 07:10 PM   #9
I bet it would look cool, but it's kinda pointless when the panel is metal too.
Old 09-10-2007, 10:49 AM   #10
JohnJ0906's Avatar
Originally Posted by joebell View Post
John,
Yes. It is factory installed.
John from Baltimore
"One day at a Time"
Old 09-10-2007, 06:03 PM   #11
In commercial the ground wire is generally insulated. In most parts of the USA(not all, Chicago, Ill being one example) we are allowed to use non-metallic sheathed cable, commonly called "romex" in residences. The ground is never insulated in the cable assembly. That being said, I agree. It can be sketchy adding circuits in homes.
Andy in ATL is offline   Reply With Quote
Old 12-13-2007, 05:06 PM   #12
Where's the noalox?
sguinn is offline   Reply With Quote
Old 12-13-2007, 07:08 PM   #13
Fluke Skywalker
walkerj's Avatar
Yes, that is the neutral bar. We use siemens exclusively for panels. I NEVER put neutrals on that side.
walkerj is online now   Reply With Quote
Old 12-13-2007, 07:40 PM   #14
Mad Skills
Celtic's Avatar
Originally Posted by sguinn View Post
Where's the noalox?
Where is the requirement to use Noalox?
póg mo thóin
Celtic is online now   Reply With Quote
Old 12-13-2007, 09:41 PM   #15
May I ask why?
Old 12-16-2007, 07:28 PM   #16
Are they trying to get 3 circuits out that 12-4 in that single phase panel??
duckhunter is offline   Reply With Quote
Old 12-16-2007, 09:03 PM   #17
JohnJ0906's Avatar
Actually, that's 14-2-2. black, white, red, white/red stripe. 2 AFCI circuits.
John from Baltimore
"One day at a Time"
Old 12-16-2007, 10:39 PM   #18
I call it 12-4 because it's easier to say that than 12-2-2, I'll be more specific in any future posts. Reason I ask, is I just went on a service call the other day where some idiot ran all their home runs into the attic with it and branched off from them. Needless to say most of the neutrals were burned up from doubling up the same phase on them.
Old 02-11-2008, 07:59 AM   #19
Master Electrician
Matt's Avatar
looks to me like the electrician that installed that panel forgot the bonding screw right beside the lug not used at the top of the neutral buss.
Matt is offline   Reply With Quote
Old 02-11-2008, 09:50 AM   #20
Thomp's Avatar
That installation has one word written all over it- "jake-legged"
Thomp is offline   Reply With Quote
Stranded or solid 12 awg wire? calimurray General Electrical Discussion 89 04-23-2009 12:30 AM
