disagreement with inspector - Electrician Talk - Professional Electrical Contractors Forum
Like Tree32Likes
Old 06-20-2016, 01:45 AM   #1
Default disagreement with inspector
I just tried to get a electrical final on a house today and the inspector who had already done the rough in inspection and said nothing. failed me because there is about a 6ft counter in the kitchen that has a window right behind it the whole length of the counter so there is no wall or back splash behind the counter for me to put a plug in. I told him the code said (wall counter top space) the key word being WALL. Code 210.52 c 1. No point along the the (wall) line is more than 2 ft from a plug. He said it's based on the counter top it's self and not the wall. So what do yall think am I right in my argument?
TX mhelectric is offline   Reply With Quote
Old 06-20-2016, 02:44 AM   #2
Deplorable-Electrician
Rewards Points: 9,016
This is why I have seen plug mold on similarly described counters.
telsa likes this.
20 Jan 2017 Truly a great day in American history!
End of an ERROR!
Old 06-20-2016, 02:54 AM   #3
NRA Member
backstay's Avatar
Rewards Points: 520
He's right as far as I know. There is receptacles that are placed in the counter top, two styles I've seen. One rises up vertical and the other rotates up.
telsa likes this.
backstay is online now   Reply With Quote
hardworkingstiff (06-20-2016)
Old 06-20-2016, 02:56 AM   #4
NRA Member
backstay's Avatar
Rewards Points: 520
Or this
chicken steve likes this.
Old 06-20-2016, 07:42 AM   #5
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 3,466
Good. Do they make those in TR?
The Following User Says Thank You to Suncoast Power For This Useful Post:
Old 06-20-2016, 08:22 AM   #6
Rewards Points: 132
IMO, the op has a good argument. If there is a doorway that doesn't count nor do cabinets. I believe ec&m had an article on this very issue.
sbrn33, cuba_pete and Majewski like this.
macmikeman (10-07-2016)
Old 06-20-2016, 08:25 AM   #7
drewsserviceco's Avatar
If it were conditional upon "wall" we wouldn't have requirements for islands or peninsulas, right?
Old 06-20-2016, 08:27 AM   #8
NRA Member
backstay's Avatar
Rewards Points: 520
http://www.garvinindustries.com/elec...fbcvss-gtr-kit
Majewski likes this.
Old 06-20-2016, 08:43 AM   #9
motherplucker
chicken steve's Avatar
Rewards Points: 2,034
Default for clarity...>
(1) Wall Countertop Spaces. A receptacle outlet shall be
installed at each wall countertop space that is 300 mm (12 in.)
or wider. Receptacle outlets shall be installed so that no point
along the wall line is more than 600 mm (24 in.) measured
horizontally from a receptacle outlet in that space.
It does say 'wall' ,not sure if glass falls under the def of it.....~CS~
chicken steve is online now   Reply With Quote
Old 06-20-2016, 08:53 AM   #10
NRA Member
backstay's Avatar
Rewards Points: 520
The non moving part of a glass door does.
Old 06-20-2016, 08:58 AM   #11
Rewards Points: 708
A 4" square or Wiremold box can be stuck to glass with the right epoxy.
backstay and daveEM like this.
Old 06-20-2016, 11:29 AM   #12
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 298
so the window is sitting there and it's not in a wall ?
I agree he is a douchebag for not saying something on the rough, though.
backstay, telsa, Majewski and 1 others like this.
Old 06-20-2016, 11:52 AM   #13
Yea I knew about the plugs that come out of the top of the counter but but based on thr fact that the code didn't say counter top only but rather than wall counter top didn't think it was necessary. Also not sure if they work when you have drawers under the counter. But this guy has been a pain the whole way he has been treating this job like is was a Brad new open stud house. On the rough he failed it 3 times kept coming back after I changed whatever he said and he would tell me to add more plugs saying it's the 12ft rule. I know the code but this house is a remodel and the walls are closed. Idk if there is a code for remodel situation or not but with all the remodels I've done I've never had that problem with a inspector. Also had me remove all of the old wire from the house. I finally had to go over his head to his boss and tell them this guy keeps adding crap with every inspection and cutting my profit every time. Side note he didn't even look at the service was to worried about the damn plugs.
lighterup likes this.
Old 06-20-2016, 12:33 PM   #14
I'd use Velcro. That way if the HO wants to move it, they could.
Old 06-20-2016, 12:59 PM   #15
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
What section did he cite for a reference?
gold is offline   Reply With Quote
Old 06-20-2016, 01:09 PM   #16
He didn't
Old 06-20-2016, 01:11 PM   #17
Rewards Points: 132
I can see the argument either way but if there were windows in a living room that went to the floor then we are required to install floor receptacles. I have never seen anyone allow you to omit a space because of a window.
shocksystems likes this.
Old 06-20-2016, 01:12 PM   #18
Rewards Points: 132
210.52(C) but that still depends on whether you consider the window a wall or not.
Old 06-20-2016, 01:12 PM   #19
gold's Avatar
Then tell him to come back and do his job. It isn't your job to read his mind. Make him cite a reference then you will either understand it or dispute it. Always get a reference.
Old 06-20-2016, 01:38 PM   #20
Rewards Points: 68
You're going to lose this fight. Push too hard about the wall minutiae, and the counter will become an island with zero clearance
Rock knocker is offline   Reply With Quote
Inspector BS re 250.104B joe cool General Electrical Discussion 23 06-21-2016 06:39 AM
Home Inspector Bad Electrician Off Topic (Non Trade) 49 06-12-2016 11:31 PM
Waiting for the inspector.... Power21 Residential Electrical Forum 4 04-22-2016 12:33 AM
