Old 11-19-2009, 08:59 AM   #21
Not Peter D
Originally Posted by cdnelectrician View Post
You like your plastic boxes over in the US eh? We don't use them much here hehe
Yes, we certainly do. We install them by the millions. Fast, cheap and they save lots of time. Once upon a time metal was the standard even in residential but those days are long gone.
Peter D is online now   Reply With Quote
Old 11-19-2009, 09:03 AM   #22
Seen your member
Originally Posted by TheRick View Post
No that is not a code compliant installation;
NEC 2008 -
110.3 Examination, Identification, Installation, and Use of Equipment.
(B) Installation and Use. Listed or labeled equipment shall be installed and used in accordance with any instructions included in the listing or labeling.
314.43 Nonmetallic Boxes.
Provisions for supports or other mounting means for nonmetallic boxes shall be outside of the box, or the box shall be constructed so as to prevent contact between the conductors in the box and the supporting screws.
I have never done it myself, but have seen it done dozens of time. That it has been done over and over does not however make it right!
So you put some tape over the screws and you're legal.
Old 11-19-2009, 09:10 AM   #23
child please.....
NolaTigaBait's Avatar
I countersink mine, when I violate the code.
NolaTigaBait is online now   Reply With Quote
Old 11-19-2009, 03:15 PM   #24
Jobless Extraordinaire
Grimlock's Avatar
I install my with PVC Glue, although sometimes there is enough tree sap on the studs to give a nice strong hold without requiring additional PVC cement...
Joking aside I have never met a service technician that has never installed a box using screws on the inside when they had to. What if you run the ground wire around the head of those screws, then it would be no different than the fasteners on a metal box; Grounded. I think a code revision is in order... Allow metal screws inside plastic boxes but ground them!
Problem solved...
Grimlock is offline   Reply With Quote
Old 11-19-2009, 06:14 PM   #25
child please.....
I think it has more to do with possible damage to the conductors than anything else.
Old 11-19-2009, 06:18 PM   #26
3rd Generation
MF Dagger's Avatar
I have done that quite a few times. Now I'm pretty well stocked on smart boxes and rarely have to. When I do it's usually that a box was knocked a little loose by the rockers or some other odd situation.
MF Dagger is online now   Reply With Quote
Old 11-19-2009, 06:23 PM   #27
child please.....
I really need to get some of those smart boxes.
Old 11-19-2009, 06:28 PM   #28
3rd Generation
MF Dagger's Avatar
They are awesome. The knockouts kind of suck in them and it can be a PITA if someone folded wires into one that wasn't neat about it. I use more Smart boxes now than bracket remodels. The fan smart boxes are the cats ass too.
Old 11-19-2009, 08:48 PM   #29
Licensed RAT
robnj772's Avatar
Smart boxes are the cat's ass I must agree. They are a little deeper then the slater boxes. You can put an extra conductor in them. Saved my butt on a renovation the other day by using a 3 gang smart box instead of a 3 gang nail on.
"I don't worry about terrorism. I was married for two years. "
Sam Kinison
robnj772 is offline   Reply With Quote
Old 11-19-2009, 08:53 PM   #30
gilbequick's Avatar
I'd rather screw into the stud than use the wings on an old work box. It holds a lot better and is more secure. If possible I'll use the wings and screw it to the stud. Done it hundreds of times.
If you think a bare part of an ungrounded or grounded conductor is going to touch the screw, wrap the device with a couple runs of tape.
Old 11-20-2009, 10:12 PM   #31
WIREDOG's Avatar
Send a message via AIM to WIREDOG Send a message via Yahoo to WIREDOG
that guy is a freaking hack. the worst thing is that he showed millions of people how to eliminate our jobs. CLOWN SHOES!
WORK SMART, WORK FAST, WORK HARD!
-TRADEMARK WIRING SOLUTIONS
WIREDOG is offline   Reply With Quote
Old 11-21-2009, 12:15 PM   #32
Is this the "smart box" you are discussing?
Old 11-21-2009, 02:19 PM   #33
Yes, comes in many versions:
http://www.smarthomeusa.com/ShopByMa...Box/Item/SB1G/
egads is offline   Reply With Quote
Old 11-21-2009, 02:38 PM   #34
Total blow hard.
Rudeboy's Avatar
fan rated smart boxes? haven't seen those.
Old 11-23-2009, 05:39 PM   #35
1st Year Apprentice
AaronJohnTurner's Avatar
Not the biggest fan of plastic boxes. If anything they're more expensive. When I DO like plastic boxes is for outside walls, that way you don't have to mess with getting a metal box and nails inside of a vapour barrier.
AaronJohnTurner is offline   Reply With Quote
Old 11-23-2009, 06:03 PM   #36
Licensed RAT
robnj772's Avatar
The vapor barrier would be the tar paper or tyvek wrap .
So your boxes on the outside walls aren't in the vapor barrier
Otherwise the sheetrock and insulation would be wet.
I pay like 55 cents for a plastic nail on,Thats cheaper then metal
The labor factor is less for plastic boxes also.
Sam Kinison
Old 11-23-2009, 06:29 PM   #37
3rd Generation
MF Dagger's Avatar
It's the exact same box as the normal round with different attachment screws and a metal bracket around the top. And it's 6 bucks more.
Old 11-23-2009, 09:10 PM   #38
That Guy
Mr. Sparkle's Avatar
Rob,
Is there a supplier in NJ that carries smart boxes or do you mail order?
"Whenever you find yourself on the side of the majority, it is time to pause and reflect."
Mark Twain
Old 11-23-2009, 09:21 PM   #39
Licensed RAT
robnj772's Avatar
Originally Posted by Mr. Sparkle View Post
Rob,
Cooper has them
Warshuar has them
Goodfriend has them
Feldman has them
Billows has them
Sam Kinison
Old 11-23-2009, 11:19 PM   #40
Licensed Pro
Magnettica's Avatar
Rahway Electric has them!
They work great!
http://gallery.me.com/electricianron...G_3388/web.jpg
Vince Lombardi
Butcher & Hack BIGRED General Electrical Discussion 23 07-26-2009 11:05 PM
New Hack Work walkerj Code Violation Discussion 67 07-04-2009 11:11 PM
I'm a hack! Peter D Off Topic 62 07-02-2009 09:50 PM
More Hack Pics NolaTigaBait General Electrical Discussion 53 04-07-2009 04:27 PM
Unlicensed hack Minuteman Off Topic 7 03-31-2009 09:51 AM
