Male shore power outlets - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
Old 09-05-2015, 03:07 PM   #1
Rewards Points: 255
Default Male shore power outlets
http://forums.prosoundweb.com/index.php?topic=156105.0
Yes, those are male outlets. Yes, they are 3 phase with no neutral.
fdew is offline   Reply With Quote
Old 09-05-2015, 03:22 PM   #2
Service Call's Avatar
Rewards Points: 6
That doesn't seem safe.
Sent from my house using 2 cans and a string!
Old 09-05-2015, 03:39 PM   #3
Rewards Points: 13,622
They look exactly like male INLETS.
You're expected to bring power TO them.
If correctly installed, they should be dead cold.
I'm nearly blind, buy they look like they're designed for 50A twist lock cord caps -- Ground, Hot, Neutral -- with a bonding contact at the edge, to boot on the left. The inlet on the right looks to have a Ground, Hot, Hot, Neutral pin-out.
But, I don't trust my eyes any more.
Second opinions ?
Old 09-05-2015, 03:44 PM   #4
Rewards Points: 255
They are HOT! with 3 phase no ground.
Old 09-05-2015, 03:55 PM   #5
Some idjit has installed them backwards.
And these were expensive, too.
The situation screams for pin&sleeve.
Old 09-05-2015, 09:54 PM   #6
Rewards Points: 3,855
What are they installed on? They look like they're bolted on the panel of a padmount transformer, maybe?
Man, that's an awful lot of money to do it wrong. The two Hoffman boxes alone were probably 300 bucks.
Teach a man to fish and youve ruined a good business opportunity.
Old 09-05-2015, 10:10 PM   #7
Rewards Points: 5,198
Why???
Old 09-05-2015, 10:19 PM   #8
NRA Member
backstay's Avatar
Rewards Points: 794
Originally Posted by RIVETER View Post
Why???
I guess because the male ends are energized and should only be that way when plugged into a female receptacle.
backstay is online now   Reply With Quote
Service Call (09-06-2015)
Old 09-05-2015, 10:27 PM   #9
ppsh's Avatar
Rewards Points: 348
Its not 3 phase, it should be 120/240 split phase ungrounded. 3 phase shore power is typically 100a wye 3 phase with a big pin and sleeve connector.
ppsh is online now   Reply With Quote
Old 09-05-2015, 10:27 PM   #10
I see your point.
Old 09-05-2015, 11:03 PM   #11
corn-fused
papaotis's Avatar
Rewards Points: 322
i have one of those suicide cords form my portable gen at the garage. im the only one who uses it. 3 times. for not more than 3 hours. usually only about an hour. with the lights on across the street. long story.
Old 09-05-2015, 11:52 PM   #12
NRA Member
backstay's Avatar
Rewards Points: 794
Maybe these were put in without an interlock breaker(with the main)by mistake. That would explain them being hot.
Old 09-06-2015, 07:56 AM   #13
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 274
I agree they're seriously wrong, but it looks like they're California s style with the equipment ground on the outside of the twist-body.
j johnson likes this.
donaldelectrician (06-08-2016)
Old 09-06-2015, 11:50 AM   #14
Rewards Points: 590
I've seen the California style made for both 250 and 480 volt 3 3 wire as well as the standard 125/250 volt.
They look the same, but the tab on the prongs are different so they cannot be connected to the wrong voltage type.
406.6(B) states that prongs cannot be energized unless inserted into a receptacle. But since it's entitled 'Attachment Plugs', it might not apply here.
406.4(F) states that receptacles shall be enclosed so that live terminals are not exposed to contact. I wonder if the cover qualifies as 'enclosed'?
donaldelectrician likes this.
Old 09-06-2015, 01:55 PM   #15
IMHO -- No way.
A flip lid is no dead front.
Old 09-21-2015, 09:00 PM   #16
Rewards Points: 185
Yes, those are inlets. Receptacles are outlets and have the terminals enclosed to prevent contact with human appendages. Inlets are just like the male end of a cord cap. The exposed terminals should never be energised while exposed. Those look like stainless steel to me. I wonder how much they cost?
Satch is offline   Reply With Quote
Old 01-19-2016, 12:41 PM   #17
Rewards Points: 56
I would guess that the (obviously unqualified) ?electrician? was trying to jack up the charges by installing the most expensive materials in a Cost Plus project.
seelite is offline   Reply With Quote
Old 01-19-2016, 01:25 PM   #18
I've seen worse....the sound company I worked for in Nor Cal used to use standard 20amp twistlocks on their SPEAKER cables.....it took a few incidents of frying speakers and amplifiers with 240v before the boss listened to me and let me change the connectors out to this:
These are Neutrik Speakon style connectors.
Speedy Petey likes this.
The Following User Says Thank You to guest For This Useful Post:
Speedy Petey (03-10-2016)
Old 03-10-2016, 02:24 AM   #19
professional redneck
Rewards Points: 187
i've seen the exact opposit, speakon sp4 use for 20amp120/240 power, because youknow they are so much cheaper than the appropriate set of twist lock plug inlet and outlet
guest likes this.
metalpats is offline   Reply With Quote
The Following User Says Thank You to metalpats For This Useful Post:
guest (03-10-2016)
Old 03-10-2016, 02:10 PM   #20
Neutrik does make a power connector very similar to a Speakon..called the Powercon..but it is spendy and I think it is only three terminals (Line-Neut-Gnd) . I have a few of the cord ends somewhere...
But it would not surprise me in the least that someone used Speakons for power..since a chassis recept is about $5 and the cord plug about $7-8 per.
Shore Power Problem runningdog General Electrical Discussion 37 08-02-2015 06:57 PM
Jersey shore on fire again Shockdoc Off Topic (Non Trade) 12 04-20-2014 01:30 AM
Wiring outdoors at the shore Joefixit2 General Electrical Discussion 20 04-07-2014 10:45 PM
Jersey Shore Work Magnettica General Electrical Discussion 31 12-07-2012 11:05 PM
OK, who hooked up the shore power to the Miami ? wildleg Off Topic (Non Trade) 10 05-24-2012 03:40 PM
