Old 09-27-2009, 12:30 PM   #21
Toronto Sparky's Avatar
Better than duct tape..
Seems to be the choice on most temp panels I've seen
Don't fight .. Play nice!
Old 09-28-2009, 11:14 AM   #22
goose134's Avatar
As I became more aware of the shoddy work being done on every scale, in all parts of the country, and in all fields, it makes me sad that people pay good money and get results like this. I mean the cover plate will cost less than a dollar. Maybe I'm just too tired to get angry.
Old 09-30-2009, 10:56 PM   #23
Originally Posted by Bob Badger View Post
No, I am not joking and would do it again under the same conditions.
There is no requirement that filler blanks be listed for the purpose or that I must use cheap plastic that often falls out.
That panel isn't a temp panel. It's also not an excuse to use the wrong part for the job. That panel is inside a mechanical room of a new addition. There is no reason to remove all the spaces.
Correct panel fillers do not fall out. If you're not sure it's correct you should contact the manufacturer to verify.
Let electrical engineers design the products; and you install those products correctly.
Mastertorturer is offline   Reply With Quote
Old 10-01-2009, 04:08 AM   #24
Ratus Maximumus
Bob Badger's Avatar
Thats a line of crap.
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
Old 10-01-2009, 05:17 AM   #25
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Ill second that for sure. Even the residential filler blanks fall out.
~Matt
Old 10-01-2009, 07:40 PM   #26
Can you post the make and model of panels you're talking about? It ain't a line of crap when I've never had them fall out.
So if it's BS then please tell me which panel fillers you're refering to.
Old 10-02-2009, 07:15 AM   #27
Ratus Maximumus
Bob Badger's Avatar
Almost any brand that uses 'snap in' fillers.
I personally prefer the screw in fillers like I-Line and some other larger panels use.
As far as the panel in your picture I would have ordered the correct fillers and installed them but I also might have put 4" square blanks in as a temporary measure until the correct fillers where on hand.
Bob Badger
MA, RI, CT
Old 10-02-2009, 07:12 PM   #28
The panel probably came with all spaces open. The installer didn't order or lost the factory blanks.
The 4S fillers look to be about the right size. It just looks hacked because you know that they are 4s blanks. Maybe it was a temp fix?
I'll do almost anything to avoid a snap in filler. I will install a few spare $3 single pole breakers instead of panel blanks.
The other stuff is pretty bad. Even Peter wouldn't stoop to that level............ maybe the AC flex
Old 10-02-2009, 10:54 PM   #29
Hack and Rat all in one
Peter D's Avatar
Well, actually...yeah. I wired some A/C units about a month ago that required 10 foot whips because I had to put the disconnects way off to the side (clearance issues.) I just laid the whips right on the ground. I'll get back there and secure them....yeah, sure, right.
Old 11-01-2009, 02:13 PM   #30
Member Liuna local 689
ryanapplequist's Avatar
wows guys that is just friggin crazy i am a helper and i wouldn't do stuuf like that in fear of the ass chewing i would get later on and just what the hell is the cord for in pic 5
ryanapplequist is offline   Reply With Quote
survey money mattsilkwood Off Topic 20 08-22-2009 05:56 PM
EZ money 220/221 General Electrical Discussion 82 07-27-2009 09:04 PM
UK: Oh woe is me, for I have wasted my life [getting qualified and all that malarky] Trimix-leccy UK Electrical Forum 11 05-15-2009 12:46 PM
Where to Spend Money? twicebright Business, Marketing, and Sales 0 04-02-2009 02:38 AM
no money for safety edelec General Electrical Discussion 1 02-17-2008 09:48 AM
