Old 04-28-2009, 07:40 PM   #21
Unlimited Lic.Electrician
william1978's Avatar
I got a nickel that says that's the ends of the lines pulled into the pipes tied off through the nipples.
I'm not going to bet you on that because your exactly correct.
Old 04-28-2009, 07:41 PM   #22
Go Tigers
walkerj's Avatar
Originally Posted by knowshorts View Post
I don't think this defines the word hack. Now if the guy made the offsets with a fat chick's legs or nippled in small chunks of flex, then maybe you can use the word "hack".
Now that you bring it up, it wouldn't suprise me if he did
Originally Posted by BDB View Post
That has the look of someone not caring what their work looks like.
I can't agree more
Jason
walkerj is offline   Reply With Quote
Old 04-28-2009, 07:51 PM   #23
Surridge Electric
Originally Posted by Peter D View Post
I don't think anyone other than a few people on this forum are going to care the slightest bit that the offsets don't match. It's not the greatest workmanship but in the grand scheme of things I don't think it's much to worry about.
Oh I agree. Just an observation. Something that was drilled in my head sinces one, sorry. When I first started the commercial contractor I worked for was very anneal about things like that. Seen people fired if the pipes were not straight and if coupling didn't match.
1991 Storm Trooper is offline   Reply With Quote
Old 04-28-2009, 07:56 PM   #24
Surridge Electric
Originally Posted by walkerj View Post
The offsets aren't the problem, it's the 4" piece of conduit at the panel AND the offsets don't match.
I didn't catch the 4" pipe, guess so
Old 04-28-2009, 08:00 PM   #25
Sounds like we worked for the same guy,but I loved it. I've allways liked working for a hardass.
Old 04-28-2009, 08:02 PM   #26
Surridge Electric
Originally Posted by william1978 View Post
You'r the first person I've ever heard call a panel can a tub. It must be a regional thing I guess.
Ya,, it is... or a shop thing. Just then guts are out. Tub is just a pc of the panel. Also heard it called a pan.
Old 04-28-2009, 08:03 PM   #27
Not Peter D
There's a time and place for neat work, and there's a time and place for "get r done." If you apply the same rules to every job regardless of time/cost constraints, you are going to be in trouble really fast ($$$.)
Old 04-28-2009, 08:07 PM   #28
Well we've made good money on every job that the general contractors pay up on.
Old 04-28-2009, 09:59 PM   #29
drsparky's Avatar
They call them "tub" in Maine and Ohio. It's not a panel 'till the guts are installed.
Old 04-28-2009, 09:59 PM   #30
redbeard43's Avatar
the pvc looks great, but why are they not buried? it only leaves a small amount of room for concrete. If they wonder why the concrete is cracking, dont show them this picture. I see the gravel they are spreading but you still are thinning the concrete. I know you can do better Dogg..hehe
You have the ring, and I see that your schwarz is as big as mine.May the schwartz be with you!
redbeard43 is offline   Reply With Quote
Old 04-28-2009, 10:01 PM   #31
Seen your member
Originally Posted by redbeard43 View Post
the pvc looks great, but why are they not buried? it only leaves a small amount of room for concrete.......
Sometimes, that's the plan..... excavate enough so you can lay your pipes on the rough grade, then fill over them with sand.
Old 04-28-2009, 10:02 PM   #32
Yes that is correct. Thats why I called it a panel can.
Old 04-28-2009, 10:02 PM   #33
redbeard43's Avatar
oh yea, i call them cans instead of tubs. we used to have a 1000 amp can and used to throw dice! CRAPS!!!
Old 04-28-2009, 10:05 PM   #34
Some jobs around here they rough the slab first and then bring in a conveyer belt truck and spread the gravel over the conduit. The conduit is usually about 8" to 10" deep.
Old 04-28-2009, 10:10 PM   #35
redbeard43's Avatar
i know thats a plan but he pipes are "strapped" in place, there is no excavating here. plan ahead on paper then dig. ive done the emt thing before and ive also went to the trouble to make a horeshoe out of the emt. Im not degrading the work, it does look great.
Old 04-28-2009, 10:18 PM   #36
Why dig if your under the 4" of gravel.
Old 04-28-2009, 10:28 PM   #37
redbeard43's Avatar
in Texas, mostly, we dont use gravel, hard clay is our game with 100%+ compaction. if your base is 10'' lower than finish grade and you use 4'' of fill with 6'' of crete, then no, i wouldnt dig either unless its bigger pipe.
Old 04-28-2009, 10:37 PM   #38
redbeard43's Avatar
this is some of what we have to work with, the pvc's are not a finished product before the crete, it gives you an idea how we have to do it here.
Old 04-29-2009, 05:53 AM   #39
gilbequick's Avatar
In Picture #2 what's spacing the tops of the service from the wall? The bottom is on the brick which looks to be sticking out 3 or 4 inches from the stucco'd wall above it....
Old 04-29-2009, 08:52 AM   #40
'Tubs' in Ma. too. The conduits from the 'tub' to the splice can.. 'Gunners',that I think was more of a contractor term.
More Hack Pics NolaTigaBait General Electrical Discussion 53 04-07-2009 04:27 PM
Unlicensed hack Minuteman Off Topic 7 03-31-2009 09:51 AM
Hack Heaven NolaTigaBait General Electrical Discussion 11 03-31-2009 09:05 AM
How many of you work out of a van? daddymack General Electrical Discussion 11 11-13-2008 05:43 PM
personal cell phones at work (for work) BP_redbear Union Topics 49 10-01-2008 08:17 PM
