04-21-2012, 10:06 PM
parallel conductors
do 2 parallel 12's=30A?
04-21-2012, 10:08 PM
Probably, at least, but I'm sure you know it's a violation.
04-21-2012, 10:09 PM
depends
04-21-2012, 10:10 PM
Originally Posted by 360max
depends
Sure, it could be serving two motor loads, but I doubt it.
04-21-2012, 10:11 PM
yes i know and if i had to guess which one id say 310.10 (h) but thats without looking so i cant be sure.
04-21-2012, 10:12 PM
and then it would be fine?
04-21-2012, 10:13 PM
Not to mention, this appears to be a 3 phase loadcenter, fed with 4 wires, with the 'neutral bar' bonded, and more than 6 throws.
04-22-2012, 10:02 AM
Meathead
As long as you twist the 12's, it's legal.
Go away!
04-22-2012, 12:54 PM
I seriously doubt if that breaker is listed for more than one conductor at its terminals.
04-22-2012, 01:19 PM
Exasperating Member
Did you install that panel? Wow what craftsmanship.
04-22-2012, 02:22 PM
Good at being Evil
That panel is a violation using SER bare neutral bond to ground.
04-22-2012, 02:34 PM
"Mainstreet"
The Craig's list lectrician can be resourceful.
Work like you don't need the money
04-22-2012, 02:49 PM
It's single phase......The conductor on the right has a white stripe....
04-22-2012, 03:50 PM
Around here, when the utility was load building and did off peak meters for water heaters, in quite a few cases they ran 14-4 to the water heater. I think they originally had them connected to different elements, but in many cases, when the water heater was replaced, the electrician (or whoever was doing the connections) paralleled the 14s and ran it off of a double pole 30 breaker. Sure, it was a code violation, but the water heater didn't know the difference.
04-22-2012, 03:54 PM
Good at being Evil
I did the same exact thing back in 89' for the same exact appliance. It was the end of the day.
04-22-2012, 05:36 PM
nope just happened to be the lucky guy to open the panel.
04-22-2012, 10:45 PM
Suuure.....
04-23-2012, 08:18 AM
#18
Sub
That sure looks like a sub-panel? Is that the nuetral and egc on the isolated neutral bar ??
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Al/cu parallel
Cletis |
NEC Code Forum |
11 |
02-24-2012 06:20 PM |
Parallel Conductors
backstay |
NEC Code Forum |
32 |
05-15-2011 09:40 AM |
Parallel #10/2
Abcanfield |
23 |
04-30-2011 01:31 AM |
600 amp parallel feed
industrialboy |
Services and Service Equipment |
9 |
07-10-2010 10:31 PM |
parallel conductors
wirepuller |
14 |
11-29-2009 07:30 PM |
