05-11-2009, 09:10 PM
Re-useing old conduit.
Found this today while working in a local grain facility.  Somebody cut a 2 1/2" rigid and bushed it down to 3/4. Didn't even bother to cap the peice after they cut out the chunk. Bad part is I cant garantee it wasn't one of our guys.
05-11-2009, 09:30 PM
Got'ta give him some credit for get'er done thinking. What size conductors? Or how many ,that this was his option.Tried something very similar with a pvc install going from 2 1/2 to 1 and got slammed .Had to use a 12x12. Was in the ground though.I didn't want to 90 up then 90down to complete the install.
05-11-2009, 09:33 PM
Unlimited Lic.Electrician
How did you get slammed?
05-11-2009, 09:34 PM
I didn't open the box to see what was up. I was just workin next to it and thought you guys might get a kick out of it.
05-11-2009, 09:45 PM
I got a kick out of it. Put that one in the back of the head for a later day.
05-11-2009, 09:46 PM
Couldn't provide UL on cap i used. Went to HD and got a plug cap and popped a center hole. Looked great till inspection. Still saved about 250' of trenching.
05-11-2009, 09:52 PM
Should have used some pvc RE's.
07-04-2009, 11:01 PM
nothing wrong with using old conduit.... saves money..yous till can charge the customer for conduit never run...unless they ask to see the work..
07-04-2009, 11:39 PM
Apprentice
Yeah, that's quite the issue.
07-04-2009, 11:43 PM
Not Peter D
I don't see a single problem in the picture.
If you do see a problem can you provide a code reference other than 110.12?
07-05-2009, 01:27 AM
Don't know about PVC but if it's old EMT or RIGID STEEL forget it. unless it is over sized.
Old metallic conduit did not have the coating inside.
I can remember when pushing three #12 twh solids though 20ft of 1/2" with two 90s was imposable.
07-05-2009, 01:37 AM
you can always lube it a tad bit and well if that conduit will save me from needing to make new holes in a concrete wall or foundation... you bet I'm gonna reuse that old pipe... just spray it with cold galvenize.. tell the customer I swaped the old for new  hahahahahaha
07-05-2009, 03:49 AM
I have done this before, I really don't see a problem with it. I would have taken the length of conduit that is cut out to the last coupling and plugged it there though.
07-05-2009, 09:05 AM
If you used stranded and you would have been fine.
10-30-2009, 06:09 PM
Local 150 Lake County,IL
doubtfull.... same insulation, size, but less rigid? how does that make sense. Pushing solid wires is 10 times easier than stranded
10-30-2009, 07:24 PM
Maybe he was thinking of pulling the wire, and in that case stranded would be easier, but like you said solid is easier to push.
10-30-2009, 07:39 PM
Re-using conduit
I agree. Those who really want to PRETTY things up may want to remove the old conduit, but the bottom line is if it doesn't have wire in it, it is just a piece of pipe.
11-01-2009, 10:37 AM
#18
IBEW Local 970 Member
Fitters run pipe, electricians run conduit.
11-01-2009, 12:57 PM
#19
Mamaluke
that is a pretty nifty idea it aint pretty but its functional
11-01-2009, 06:14 PM
#20
Burger Flipper
So who runs EMT?
~Matt
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Conduit carrier....
wraiths |
23 |
02-17-2009 06:41 AM |
Conduit for UPS
bman4523 |
Code Violation Discussion |
7 |
02-05-2009 12:08 PM |
ice in conduit
te12co2w |
34 |
01-23-2009 09:47 PM |
moisture in conduit.
k2x |
11 |
06-07-2008 09:30 PM |
Anyone useing these
frank |
Services and Service Equipment |
3 |
06-12-2007 08:13 PM |
