Roll around receptacles on wheels? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 3 Post By macmikeman
  • 4 Post By macmikeman
  • 3 Post By just the cowboy
  • 1 Post By splatz
  • 3 Post By telsa
  • 2 Post By Signal1
  • 3 Post By 360max
Old 12-08-2016, 03:09 PM   #1
Default Roll around receptacles on wheels?
This big guy rolls around to all of our jobs plugs in via a 60amp blue plug and it receives single phase 208 . My questions is. Is this the proper way for grounds and neutrals to be hooked up ? Knowing good and we'll that there isn't a neutral to be had from single phase 208 they insist on using this thing as is. Should I isolate the neutrals that go to the 11p outlets and just use a local bonding ground to the panel and cart?
Sent from my SAMSUNG-SM-G935A using Tapatalk
steampunk2309 is offline   Reply With Quote
Old 12-08-2016, 03:17 PM   #2
Rewards Points: 4,422
Looks like a rolling Osha issue to me. Where is the gfi protection for those outlets?
circuitman1, telsa and Majewski like this.
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Old 12-08-2016, 03:19 PM   #3
This was put on my plate for redesign so that's one thing I've mentioned to my supervisor
Old 12-08-2016, 03:21 PM   #4
You might also tell him the whole thing needs to be sunk in the lake. The deep lake.
Old 12-08-2016, 03:26 PM   #5
Any idea about the neutral issue though?
Old 12-08-2016, 03:33 PM   #6
just the cowboy's Avatar
Rewards Points: 194
Default It's wrong wrong wrong
First off it should be fed with 4 wire.
Grounds and neutral need to be seperated.
GFI is required for temp power.
Stop using it NOW someone is going to get killed, you have current flowing on the ground or no ground. What do you mean no netural on 208 single phase, When you have 120v receptials??????
circuitman1, telsa and splatz like this.
The Following 2 Users Say Thank You to just the cowboy For This Useful Post:
telsa (12-08-2016), wildleg (12-08-2016)
Old 12-08-2016, 03:34 PM   #7
I have lots of idea's and one is you need to have an electrician redo that.
Old 12-08-2016, 04:51 PM   #8
Agreed it's a death trap ! The only available power is single phase 208 on these jobs that they use it on . And 110 receptacles are far to come by so they emplemented this death trap. I was tasked to make it "compliant" . As I see by your answers that we cannot make this compliant unless we feed it with 4 wire
Old 12-08-2016, 05:00 PM   #9
Rewards Points: 3,010
If there was some kind of device that could transform the 208v to 120v ...
Majewski likes this.
The Customer is Always Right! - @Hackwork
Old 12-08-2016, 05:00 PM   #10
Rewards Points: 15,776
That puppy needs an extreme make-over.
1) 208 VAC is only available from a 208Y120 system. You'll need to bring a 4-wire conductor from that source to your 'floating' panel.
2) The neutral must be fully sized, but of course.
3) The usual drill is factory wired 'spider boxes.' These are OSHA complaint.
I find it HARD to believe that you can gin up a superior build for the same amount of $$$.
Don't you really want liability to fall upon the guys that manufactured the spider box ?
You can always put casters under the feet of your spider boxes.
Temp power is usually laid on by the GC. All of the trades are expecting spider boxes.
Hint, hint.
Go check out eBay, too.
Old 12-08-2016, 05:08 PM   #11
Hint, hint.
Prior employer used something similar I will behoove my supervisor to discontinue using this. All they need is a meaty drop cord and a gfci receptacle to get past this . The 208 receptacles aren't the problem it's them trying to use it also for 120v.
Old 12-08-2016, 05:39 PM   #12
Signal1's Avatar
Rewards Points: 812
What an embarrassing piece of junk.
circuitman1 and steampunk2309 like this.
Signal1 is online now   Reply With Quote
Old 12-08-2016, 05:45 PM   #13
drspec's Avatar
Rewards Points: 642
Im going to guess you work for a restoration company
Old 12-08-2016, 06:19 PM   #14
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 586
having seen how badly those spider boxes get pounded into junk, I have no problem with a home built one. But as others said, that one is a huge liability as it stands.
Old 12-08-2016, 07:31 PM   #15
360max's Avatar
Rewards Points: 818
Moderator-In-Training
360max is online now   Reply With Quote
Old 12-12-2016, 07:51 PM   #16
Rewards Points: 52
I've seen worse. Usually the worst of the worst are flooring prep guys or refinishers. I walked into an electrical room on a job that had the panel cover off with alligator clamps on the panel buses ........
TRurak is offline   Reply With Quote
Horizontal receptacles in Chicago? HackWork General Electrical Discussion 27 10-22-2016 06:54 PM
Minimum number of receptacles for commercial? Christopher Dedios NEC Code Forum 6 06-26-2016 10:50 PM
Garbage Disposal and Dishwasher Receptacles swimmer General Electrical Discussion 14 06-09-2016 06:15 PM
Kitchen counter receptacles 604nguyen Canadian Electrical Code Forum 31 04-10-2016 12:46 PM
