Old 04-13-2012, 11:23 PM   #1
Resi Service Electrician
electrictim510's Avatar
Default Service call; Breaker tripping still
Customer said "I replaced the breaker and it still will not stay on"
I unplugged all the stuff in the house and reset breaker. Everything came on. Turned on the switch to front entry light, worked fine, switch next to it for the exterior light mounted to the house, worked fine, after switching the one next to it (pole light with receptacle) the lights inside dimmed a little so i figured short has to be out there. Opened the door and saw fireworks coming from the plug mounted on the pole. This is what I saw after opening it.
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
electrictim510 is offline   Reply With Quote
Old 04-13-2012, 11:25 PM   #2
Cable underground was some kind of romex type wire that looked to be aluminum clad. Rarely see that.
Old 04-13-2012, 11:25 PM   #3
Phosphate Coated as of 05
dronai's Avatar
Wow !!!
Old 04-13-2012, 11:27 PM   #4
Probably lead sheath. I've really only seen it used for pole lights, street lights, and feeds to detached garages with a very light load.
electrictim510 (04-13-2012)
Old 04-13-2012, 11:30 PM   #5
funny thing is; This stuff was installed 40+ years ago! It was a handybox with metal plate, set screw connectors, round metal box with plate, nothing about this install was weather resistant except the cable underground. Amazed me it lasted that long! Pole was in open yard with no cover at all.
Old 04-14-2012, 12:18 AM   #6
wendon's Avatar
Never know what you'll find!! I had a friend once told me every time it rained he got shocks off his screen door. Finally, I went over there and started tracing things. Took a long time but finally found the problem. On the opposite side of the house was a porch. When they resided the house with metal siding, they installed aluminum soffit in the porch area. Some hackster didn't bother moving the light box but instead just drilled a hole in the aluminum and stuck the wires through. Then he hooked up a porcelain fixture and screwed it to the soffit. Imagine what happened when the screw contacted the aluminum!!! It actually had burned a notch in the siding where the ground wire was contacting it!! It had been that way for a number of years!!
Ive seen burnt up outlets, chard neutrals, and shorted wires.
Uncfesta
Old 04-14-2012, 12:21 AM   #7
Chief Electron Relocator
Old 04-14-2012, 12:26 AM   #8
cog
stuiec's Avatar
A little off topic I know, but my curiousity just got the better of me and I started typing just to see if maybe, just maybe I could type forever in this thread without using the second line I mean that would have to be some kind of accomplishment, and it is low risk (I have dependents after all) and hell, maybe I could even inspire others to reach for greater heights. Okay, this is 6 lines in the reply window. Here goes....
Old 04-14-2012, 12:30 AM   #9
Looks like just 3 lines to me.
Old 04-14-2012, 12:32 AM   #10
cog
stuiec's Avatar
I didn't even get 1/2 way across on my screen Utter failiure
Old 04-15-2012, 01:49 PM   #11
Podagrower's Avatar
1 line with 4 words on the second line on my 17" laptop. Zoomed out to smallest size.
Podagrower is offline   Reply With Quote
Old 04-15-2012, 01:56 PM   #12
Nice job. How long did that take you to create?
Proof and exoneration http://www.latimes.com/news/politics...,7305052.story
Old 04-15-2012, 02:15 PM   #13
Mebbe 5 minutes.
Old 04-30-2012, 11:50 PM   #14
Scared Electrician
Saturday Cowboy's Avatar
I love Pi
Saturday Cowboy is offline   Reply With Quote
Old 05-01-2012, 02:23 AM   #15
PGW Professional
Magnettica's Avatar
Old 05-01-2012, 06:24 AM   #16
Good at being Evil
Shockdoc's Avatar
My first UG repair before I became a trade electrician involved a buried T box with splices.
Old 05-01-2012, 07:22 AM   #17
976-EVIL
mcclary's electrical's Avatar
B4t still does that as a professional!
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
mxslick (05-02-2012), Shockdoc (05-01-2012)
Service call. 600A breaker tripping every 48 hours zwodubber General Electrical Discussion 86 04-09-2012 04:25 PM
Breaker Tripping Aegis General Electrical Discussion 23 12-16-2011 11:08 PM
Service Call Tripped Breaker dronai General Electrical Discussion 20 10-17-2011 09:21 PM
Service call for main breaker tripping fescon Code Violation Discussion 17 08-24-2010 10:56 AM
breaker keeps tripping donna13350 General Electrical Discussion 1 01-28-2009 09:19 PM
