Smurf Tube - Electrician Talk - Professional Electrical Contractors Forum
Old 12-07-2008, 07:49 AM   #1
Default Smurf Tube
This is a new one for me. Have always seen it but do no know a whole lot about it. It is my understanding that it is a flexible conduit for low voltage meaning speaker, Cat 5 etc not temporary power installations etc. Anyone have any ideas?
John Maiorano is offline   Reply With Quote
Old 12-07-2008, 08:27 AM   #2
Speedy Petey's Avatar
Rewards Points: 2,266
See NEC 362.10 & 362.12. Uses permitted and no permitted.
While strictly regulated there is no problem with using it for line voltage wiring.
Old 12-07-2008, 05:07 PM   #3
Master Electrician
electricalperson's Avatar
Rewards Points: 2,002
in my vacation to bermuda, i noticed this is pretty much the only wiring method they use in those stone buildings. i love using smurf tube and think its great.
Old 12-07-2008, 05:41 PM   #4
Bkessler's Avatar
Rewards Points: 2,000
I worked in USVI for a year and used smurf for everything, here in socal I have used it in concrete in a all concrete highschool football stadium. I think the stuff is great as well.
When ls lunch?
Old 12-07-2008, 05:44 PM   #5
nap
a real PITA
it sucks when it is cold and pulling it through steel studs sucks equally.
Old 12-11-2008, 05:56 PM   #6
Master Electrician
so does pulling MC through steel studs. especially the 250 foot coils of it. i dont think they make a reverse wound little coil. when i buy 1000 foot rolls of MC i make sure its reverse wound. thats probably the standard now anyway
Old 12-11-2008, 06:37 PM   #7
gilbequick's Avatar
Rewards Points: 1,000
You can get 250' rolls reverse wound. I can't understand why that isn't the way it is sold normally.
Old 12-11-2008, 09:56 PM   #8
Rewards Points: 300
The "blue smurf tube" is called ENT and it works good if used for the right applications. The one downside is that it is not UV resistant, which means you cant use it if it will be exposed to sunlight.
Old 12-11-2008, 10:40 PM   #9
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,014
i used it in a stone building - works fine - has a pita memory
Old 12-14-2008, 09:26 AM   #10
Cheetah Speed System
electrician1957's Avatar
I love ENT.
electrician1957 is offline   Reply With Quote
Old 12-14-2008, 09:47 AM   #11
nap
a real PITA
Originally Posted by electrician1957 View Post
I love ENT.
Yousa crazy!!
Old 12-14-2008, 12:54 PM   #12
Rewards Points: 524
Is this smurf tube like coreline? gray or blueish plastic flexible pvc pipe, made by Ipex (the stuff we use anyways).
If yes then I love it, and we use a LOT of it, I have personally put 140k feet of it down.
Jeff000 is offline   Reply With Quote
Old 12-14-2008, 02:17 PM   #13
Rewards Points: 3,800
I've used it for years now. Just remember the limitations on it. Not for exposed work, not for sunlight exposure( the first one seems to me to sort of negate the second one don't you think?) Not to be in direct contact with soil. I use it on second floor and above slabs alot. Also for feeding kitchen islands on grade floor when there is a gravel layer above the soil. The fishtape will sometimes hang up a bit when pushing thru.
Old 12-20-2008, 09:46 AM   #14
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 1,624
In the jurisdiction I work for I'm seeing a ton of that gray flex made by IPEX. It seems all the larger EC's around here are installing it in their concrete slabs. Saves a ton time on slab work. I'm also seeing pvc coated mc cable being used in the slabs.
I myself have never used the stuff. I have spent some time on one job site with a very intelligent electrical contractor discussing these two items. They are approved for concrete encasement and I can see the advantages to using them the way these EC's are. I even spent some time talking with another electrician who works in a different part of the state. They still use schedule 40 pvc for slabs. I was telling them to check out the flex and pvc coated mc.
Old 12-20-2008, 12:21 PM   #15
just pulled some #12 (5) in 3/4 smurf about 150'-200'. took 3 of us to pull it.yes. we lubed it all the way. any of you guys got some better ideas to make it easier?? paul
Old 12-20-2008, 12:49 PM   #16
nap
a real PITA
sure (but you won't like it)
EMT
Old 12-20-2008, 01:01 PM   #17
EMT
its in the slab. and we got miles of this sh!t to pull thru!!!! oh well.
Old 12-20-2008, 01:33 PM   #18
nap
a real PITA
sucks to be you.
not trying to infer you do not know what you are doing but just in case:
you do have somebody actually pushing the wire in as well, right? and I don;t mean merely feeding the wire but actively pushing the wire in.
Old 12-20-2008, 03:07 PM   #19
Rewards Points: 524
The one problem with running tec in the slab is you have to make sure no one is coring later, a lost core line is a LOT cheaper then a lost mc in the slab. It would seem the MC that you would put in the slab would be best suited to a rack, this way you can make sure it doesnt get damaged at all.
5 #12 isnt much for a 3/4 run at all, even 6 #12 over 200 feet you can get away with one guy pushing and one guy pulling without lube even.
When you pull the coreline out on the rebar make sure its as straight as possible and tie it down enough to make sure when they are pouring the mud that it doesnt move. If its not tied down enough it will snake 12 degrees one way then 12 the other... and before you know it there is 1000 degrees of bends over the 200 feet.
But the core line could have got stepped on and crushed a little bit too. Make sure you have someone watching, especially if its real hot or real cold.
Old 12-20-2008, 03:47 PM   #20
yeah nap , we had a good man feeding. and jeff i think you id'ed the problem EXACTLY. them slab guys ran the tube around , up and down, and put a " goose-neck at the stub up. i was told we used smurf because it was faster than PVC pipe. putting the string in and pulling the wire took 4 hrs. oh i forgot, the string was a bitch to get in too.
Knob and tube and 3-prong outlets!! wirehead General Electrical Discussion 6 04-17-2008 05:21 PM
Need opinion on grounding old knob and tube house 00Funk General Electrical Discussion 14 02-17-2008 10:19 AM
Ballast/tube temperature rating JohnJ0906 Lighting Design 4 12-03-2007 09:09 PM
Smurf tube JohnJ0906 Code Violation Discussion 18 05-20-2007 06:34 PM
