Old 01-12-2009, 06:31 PM   #1
Seen your member
Default Spot the Violations
Installed a range circuit & recep today. Opened the panel and found some goodies
To anything!
Old 01-12-2009, 06:31 PM   #2
Seen your member
Default One More Pix
To anything!
Old 01-12-2009, 06:51 PM   #3
Ah, the new quick grounding method. Similar to a very loose push in.
I see you have a variety of breakers, might as well have a variety of wire colors to go along with in.
Just out of curiosity is that screw that is holding the main in a factory installation? Is it legal?
SmithBuilt is offline   Reply With Quote
Old 01-12-2009, 07:06 PM   #4
Seen your member
Of all the branch-circuit breakers in that panel, the only Bryant is the one I installed for the range.
Yes, the screw in the main is factory, and it's not only legal, but required.
To anything!
Old 01-12-2009, 07:54 PM   #5
gilbequick's Avatar
Gotta love those hots that are colored GREEN! That's an accident waiting to happen to somebody working on wherever that wire goes.
Old 01-12-2009, 08:12 PM   #6
You did what you contracted to do. Did you suggest you would make things right?(for an extra)
bobelectric is online now   Reply With Quote
Old 01-12-2009, 08:19 PM   #7
Seen your member
Well, I did fix the hack grounds. I also fixed another violation (One that hasn't been mentioned yet, so I'm not gonna say what it is). As for the green wire used as a hot, and the other stuff, I commented on it, and got the old "We can't afford it right now since we're spending $10,000 on our kitchen."
At least they're aware of the problems and have my card. It may become more work sometime in the future.
To anything!
Old 01-12-2009, 08:36 PM   #8
The locknut on top looks a little loose and it appears they took out too big of a knockout. Whats with the insulation extending so far into the panel. Lack of properly labeled breakers, and I'm going to ASSume that you took the door off the cover?
crazyboy is online now   Reply With Quote
Old 01-12-2009, 09:03 PM   #9
Seen your member
Yea, I tightened it up before I closed the panel back up. Not too big of a KO, just got sloppy when they pushed it out.
No violation there.
At least on the inside. On the front of the door was an 8½x11 printout of every breaker labeled.
Well, yea, kinda have to in order to work inside the panel.
To anything!
Old 01-12-2009, 09:21 PM   #10
Thumbs down
What else are you referring to Ken, the doubled up neutral lands? That concentrical knock out looks just fine from my house
That's one h*ell of an EGC land method, is that a new kind of conductive powder coat??? I knew I was lacking something, that's just grand
Old 01-12-2009, 09:25 PM   #11
Seen your member
Originally Posted by 76nemo View Post
What else are you referring to Ken, the doubled up neutral lands? That concentrical knock out looks just fine from my house.....
Well, that's one violation. There's still more.....
To anything!
Old 01-12-2009, 10:07 PM   #12
Question
What is the brown colored rubber insulated conductor landed on the grounded bar????
Old 01-12-2009, 10:19 PM   #13
I think their bare, think its just the lighting that is making them look insulated. Hopefully 480 can clarify!
Old 01-12-2009, 10:36 PM   #14
Seen your member
They're the #4 bare GECs.
That's not green. It's a new color regocnized by the NEC for ungrounded conductors...... Iwitt.
Acronym for It's What's In The Truck.
To anything!
Old 01-12-2009, 10:48 PM   #15
Is this a sub-panel? Sorta looks like it with a back-fed main.
Old 01-12-2009, 10:51 PM   #16
Seen your member
No. that's the 100a main panel. That's just the way Bryant used to do them. It's held in place properly.
To anything!
Old 01-13-2009, 09:33 AM   #17
The receptacle on the left hand side of the panel is upside down.
knowshorts is online now   Reply With Quote
Old 01-13-2009, 09:51 AM   #18
Seen your member
This one?
I flipped it over before I wrapped up just for you.
To anything!
Old 01-13-2009, 10:40 AM   #19
Oops, I made a mistake. Receptacle is actually on the right hand side. I have the Receptacle Flipper 1.07 plug in for Firefox that automatically shows pictures of receptacles the proper way and the way it shows on my screen is like above with a nice red hue. I always forget to right click and see picture as original.
Seriously, what about 110.16? Was this a resi?
I gotta go. Time to flood Craigslist with electrical ads for $20 an hour for electricle service with all my competitors phone numbers.
Old 01-14-2009, 02:51 AM   #20
rexowner's Avatar
Where did they get the third screw from the bottom
in the last picture? Looks like the manufacturer
screw fell out, and they improvised.
rexowner is offline   Reply With Quote
Spot the Mistake frank Off Topic 12 11-16-2009 11:12 PM
Major violations Bkessler General Electrical Discussion 13 09-26-2007 12:14 AM
Look here for some code violations! Joe Tedesco Code Violation Discussion 0 05-18-2007 12:55 AM
A few violations brian john Code Violation Discussion 11 03-25-2007 08:27 PM
Spot lamps wesser General Electrical Discussion 1 02-14-2007 12:33 PM
