Today's SPOT THE VIOLATIONS! - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
Old 05-07-2016, 04:40 PM   #41
NRA Member
backstay's Avatar
Rewards Points: 794
Q0 panel.
backstay is online now   Reply With Quote
Old 05-08-2016, 08:08 PM   #42
Rewards Points: 8
Why is there only 5 neutrals landed for 9 breakers? And where are the grounds?
Sent from my VS985 4G using Tapatalk
jriederer is offline   Reply With Quote
Old 05-08-2016, 08:16 PM   #43
Rewards Points: 340
My guess is it is a homeowner replacement for a much older panel, a lot of our older residential panels have the neutral bar up at the top which would explain that really short neutral
Sent from my SM-G900R4 using Tapatalk
emtnut likes this.
Anathera is offline   Reply With Quote
Old 05-08-2016, 08:42 PM   #44
I own stock in FotoMat!
Rewards Points: 6,520
MWBCs.
It's called EMT.
Sent from MyOuthouse via ToiletPaper
emtnut likes this.
Old 05-08-2016, 08:46 PM   #45
Band Member
emtnut's Avatar
Rewards Points: 7,420
<~~~ three of them, just to abide the Peter D rule
I swear to Drunk ... I'm NOT God
Old 05-09-2016, 12:04 PM   #46
Rewards Points: 22
It's called EMT.
Does anybody actually use EMT for their ground? Genuinely asking. Not being a smart ass.
cagresham85 is offline   Reply With Quote
Old 05-09-2016, 01:45 PM   #47
I generally do since I've actually researched it and found it's a far superior ground than a copper conductor.
Old 05-09-2016, 01:59 PM   #48
Rewards Points: 812
You just have to make sure all of your connectors and couplings are approved for grounding.
Old 05-09-2016, 02:12 PM   #49
Very few aren't.
Old 05-09-2016, 10:58 PM   #50
corn-fused
papaotis's Avatar
Rewards Points: 322
only problem is making sure everyone tightens everything. including both ends of a ground wire run through a conduit!
Old 05-12-2016, 01:00 PM   #51
Rewards Points: 306
I was in the middle of this argument a while back....you will be considered an idiot and money waster and anti-code if you pull a separate EGC (at least by some), even if your AHJ requires it.
Sparkchaser1 is offline   Reply With Quote
Old 05-12-2016, 07:10 PM   #52
wcord's Avatar
Rewards Points: 702
Almost all of the specifications on our commercial/industrial projects have ground wires in the conduit.
I have noticed lately a number of loose set screws and lock nuts, on both new and old work. Obviously sloppy workmanship
This could be why the engineers are adding the grounds.
Be careful what you wish for, you just may get it.
Old 05-12-2016, 08:06 PM   #53
Using a green copper conductor is no guarantee either. One can be just as sloppy installing it.
Majewski likes this.
Majewski (05-12-2016)
Old 05-14-2016, 02:09 PM   #54
Rewards Points: 306
Is there actually researchable scientific data concerning this? Did they take data from the field concerning EGC failures, pitting EMT versus an actual conductor? Did electricians in the field actually submit this data?
Old 05-14-2016, 02:28 PM   #55
Soare's Book on Grounding and Bonding.
Can you spot the lineman? Borgi Linework 14 07-12-2016 02:36 AM
Not much electrical work on today's job. Kaffeene General Electrical Discussion 1 02-04-2016 08:45 PM
