Torque speicfications needed for lockrings on PVC T/A? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 03-16-2017, 10:53 PM   #1
Rewards Points: 40
Unhappy Torque speicfications needed for lockrings on PVC T/A?
I have an AHJ that is insisting I provide him with the manufacturers recommended torque specifications for the lock ring on a male PVC terminal adapter, or he will not allow it to be used. His position is that the lock ring can not be torqued to the manufactures specifications if those specifications are not known, and thus it is not possible to verify proper installation, so improper installation must be assumed.
Anyone run into this one before? I've got a query into Carlon, but no response yet. Their probably still scratching there heads asking WTF. Maybe I need to ask Thomas and Betts directly, as the lock ring is not marked Carlon.
Rodger is offline   Reply With Quote
Old 03-16-2017, 10:55 PM   #2
Rewards Points: 40
FYI he is using 2014 NEC 300.12 as his justification.
Old 03-16-2017, 11:04 PM   #3
Rewards Points: 626
Does this dufus have a boss? I don't have a codebook handy, but, connectors (fittings?) only need to be tight or wrench tight. Lastly, only electrical connections are required to be torqued. There is no grounding/bonding issue.
googled this...
The NEC requires raceways, cable assemblies, boxes, cabinets, and fittings to be securely fastened in place [300.11(A)] and provides a few specifics.
FWIW google Mike Holt on this.
Old 03-16-2017, 11:05 PM   #4
Rewards Points: 12,596
He's messing with you.
Of course, you screwed up.
Donuts and coffee would've cleared this matter up... from the first.
Old 03-16-2017, 11:12 PM   #5
Rewards Points: 40
I'm probably going to find out who is boss is, He also wants me to install electrical outlets behind permanently installed cabinets because it "will be needed if the cabinets are removed in a remodel."
... What the hell?!! I didn't bid for wiring every possible future variation of use for the space! I was hired to wire it for the presently planned use.
Old 03-16-2017, 11:15 PM   #6
Rewards Points: 4,330
The torque specs for a locknut are TAS... Hit the hell out of it and stop one strike before it snaps....
Old 03-16-2017, 11:25 PM   #7
Rewards Points: 40
This section seems to be for Racewasy ect. in suspended ceilings. But the application in question is a 2.5" PVC T/A on the end of a pronto-bend stuck into the bottom of a meter box. Any tighter and it will strip! I don't get his problem.
Old 03-16-2017, 11:55 PM   #8
Rewards Points: 548
Tell him you are going to use a JBA and don't worry about it ever again!
Cheers
John
Datawise Solutions Inc
Old 03-17-2017, 04:44 AM   #9
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,314
Cheers
John
I use these everywhere I can. They are especially useful on larger conduits. They eliminate both the locknut and the bushing from an installation inventory.
Old 03-17-2017, 04:54 AM   #10
Semper Fidelis
The Carlon catalog shows 1/2" to 1" PVC locknuts. I would have to assume from that the expiration is that you would be using a steel one above that size.
Page 221 calls out termination methods but is silent on torque beyond the word "secure".
We should then Look to the Merriam-Webster dictionary:
a : to relieve from exposure to danger : act to make safe against adverse contingencies.
I would announce, in my best Buzz Lightyear voice, " I have relieved the termination from exposure to danger and adverse contingencies per manufactures specifications"
I would repeat that every time he said anything about it.
http://www.carlonsales.com/techinfo/...og_low_res.pdf
Second, tell
Him if he is asking for money, the company will send him a 1099 like they did the last guy
MechanicalDVR and Rodger like this.
Old 03-17-2017, 06:39 AM   #11
RePhase277's Avatar
Rewards Points: 2,554
There's a homemade tool for this. Here's how you make it: Cut off a piece of 3/4" or 1" pipe, doesn't mater what type, 18" to 24" long. Gripping the pipe firmly, beat the inspector until he pisses blood. The end.
Old 03-17-2017, 08:39 AM   #12
still in business
sbrn33's Avatar
Rewards Points: 2,276
Is this that new Philadelphia electrical inspector? I have heard he is a real pain in the pudge.
RePhase277 likes this.
Old 03-17-2017, 08:42 AM   #13
Click Here
Rewards Points: 5,084
Facebook.
Old 03-17-2017, 11:11 AM   #14
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,226
Being a pr1ck, I'll have to say this:
.....and you guys like to go on about the ridiculous requirements up here....
P&L
Old 03-17-2017, 11:23 AM   #15
Rewards Points: 626
P&L
This isn't about ridiculous requirements, but, a ridiculous inspector.
brian john, telsa and RePhase277 like this.
Old 03-17-2017, 03:17 PM   #16
Rewards Points: 40
I might just switch to these. I've used them on occasion in a tight spot where I could not get my hand on both sides to tighten a lock ring or something, but never considered using them more often.
Old 03-17-2017, 03:23 PM   #17
Rewards Points: 40
My apprentice from Florida said: "Back home we have gators for just this sort of thing."
Service Call and RePhase277 like this.
Old 03-17-2017, 04:05 PM   #18
Deplorable-Electrician
Rewards Points: 19,348
I didn't know you were a NJ-NY guy!
The old adjustment tool!
DJT, making libtards cry since 20 Jan 2017
Old 03-17-2017, 04:08 PM   #19
P&L
Naw, this is an inspector looking to get a bribe not that there is an actual NEC code requiring this.
You guys are still over regulated up there.
Old 03-17-2017, 04:27 PM   #20
RePhase277's Avatar
No, just a ol' Georgia boy. We use the same tools, just a different accent.
Tags
ahj, pvc conduit, torque
2017 Torque Requirements Semi-Ret Electrician General Electrical Discussion 28 02-28-2017 11:17 AM
2017 changes-- Torque Tools Majewski Tools, Equipment and New Products 43 02-21-2017 08:20 AM
Torque driver Anathera Tools, Equipment and New Products 34 06-04-2016 11:00 AM
Average amount of wire needed question AWD1052 General Electrical Discussion 5 04-06-2016 05:36 PM
GE THQL Breaker Lugs Splitting at Specified Torque Mr. Skookum General Electrical Discussion 16 03-11-2016 01:53 PM
